basic questions : What is gain? & zebra settings
Would someone please explain what is happening when you increase the gain.
Are you just increasing the sensitivity of the chip? and what is the penalty for increasing the gain. Would a good analogy be a faster film speed in a still camera? Zebra settings, what do they represent 85, 90, 95 what? What setting should I be using and how do I decide? Thanks for the help. |
I might not be able to answer everything, but I can give you
some basic explenations. Gain: gain is an electronic amplifier. It amplifies the signal by a given amount (making it thus lighter - if you have a +db). The downside is that this introduces NOISE. Which you can easily see and test for yourself. I always shoot at -3db to get the cleanest image possible. Zebra stripes: these stripes are here to warn you of overexposed parts of the image (ie, too bright). You can set your own level. If you choose 95 or 100 everything above that will be CLIPPED HARD (since digital can not go over 100). I have it set at 90 as to have a bit more headroom. I know when I start to see zebra stripes that I must be careful (unless I want to have blown out parts) but that I'm not loosing any information... YET. Some other people will tune in with exact discriptions and such, I hope this will help in the mean time. |
Hi Rob,
now you've got me........always shoot at -3db. Could you please elaborate for me. Thanks Andrew |
You want the cleanest signal possible, so that is why you want
-3 dB gain (less noise as possible!!). I usually shoot at a shutter of 1/25 or 1/50 and adjust my iris for different amounts of lights (I also have ND filters to help). I'm starting to use additional lights as well. Basically I do not touch my gain knob (unless it is the absolute last thing I can do to get the image brighter, which happened only once). The more you dial up the gain, the brighter, but also the more grainier the image becomes. It might be a look your after, but I'm not. If I want grain I'll ad it later during editing and post processing. Just play with the settings and see what you like. Everyone agrees on -3 dB gain though, as far as I know. |
Now unless I'm missing something the GL2 lowest setting for gain is 0. Is that correct?
You shoot at 1/25 and 1/50? that seems slow to me but I'm thinking in terms of stills does this create a particular effect you like? Where do most people judge their image a computer screen, studio monitor, TV screen is there an actual standard? Thanks for the help! |
To judge you video properly you should use a hi res CRT studio monitor that has bean Properly calibrated. I find it hard, and next to impossible to judge my footage on a standard TV. Usually if your footage is being seen on a computer monitor then it (the footage) has bean compressed which dose not give a you the viewer a true view of what the footage will look like uncompressed.
alex |
Hi Rob,
now you've really got me. I thought dB was related to a reference signal level of 0. Any +dB setting would amplify and any -db seting would attenuate a given signal. Further to this, as dB is plotted on a log / lin graph it stands to reason that the function is based on the principal of the square, this applies to both lighting and audio. Generally a change of 3dB would represent a halving / doubling of the signal. So in mind I am trying to understand why by attenuating a signal you would get a better picture. You also seem to intimate that a slow shutter speed will also help matters. How so? Do the same principles as for 35mm photography apply i.e. the relationship between shutter speed and aperture. F5,6 at 1/125 is the same as F8 at 1/250. Could you please explain in a bit more detail, my fundemental beliefs are being rocked. Thanks Andrew |
Correction
F5,6 at 1/125 is the same as F8 at 1/60. DUH Cheers Andrew |
Well... I'm not an expert on dB's by a long way. So I cannot tell
you what it means exactly. I just know that everyone is shooting in -3 dB and that it is what is advised. Ofcourse you lose 1 or more stops of light. The advantage is that you are reducing the noise the CCD chips are producing, ie, you get a cleaner image. Just try it for yourself. That works the best! As far as I understand the shutter issue (and remember, I'm not a professional) you do not want to change your shutter speed. Set it at something and keep it there. Otherwise you will see different motion signatures when the camera or something moves. Keep in mind that this is a VIDEO camera not a STILL camera. You can get away with changing shutter speeds in between photo's, but not whilst your shooting video (in my opinion). I choose 1/50 or 1/25 because that closely resembles a FILM SHUTTER and I like the motion at the moment (I'm in a PAL country... hence the 25 and 50 instead of 30 and 60). I'm still experimenting with things though.... What shutters is everyone else using for movie making? |
Addendum:
" F5,6 at 1/125 is the same as F8 at 1/60 " This might yield the same photo image regarding with how much light enters etc. But it will definitely not produce the same motion signature on video. |
"What shutters is everyone else using for movie making?" (Rob)
Normally I try to get away with shooting at 1/60. It's not always possible, though. 1/30 is just too slow if anything in the shot is moving. |
Hi Rob
OK things are falling into place....to some degree. I understand what you are saying and what the general practice is. Why did'nt Canon just produce a -12dB setting, think of the quality then....Ha Ha.... yeah I know how many stops you would lose. I still would have thought that in terms of dB (in my poor understanding that is ) that the best setting would have been 0 i.e. no boost and no cut to the signal. I hear what you are saying and will certainly set mine to -3dB. As with you, I too am a PAL man. Had never thought of the 25 / 50 speeds for the film look. Would you suggest this for all filming like wildlife doccies? I have tended to shoot on aperture priority as a result of the diffraction issue (As documented on the watchdog under Soft Focus and Workaround). Can't figure out how to get 1/50th at F5,6 in the bright African light. Argh..there ain't no such thing as a free lunch. Cheers Andrew PS: Anyone out there with an understanding of the dB issue? |
Andrew,
Well... experiment. Best way always. I do think that low shutter speed helps in a more movie kind of look, since they use a slow shutter too (after frame doubling it is effective 1/48 ???) You should be able to get 1/50 F5,6 in bright african light with the help of ND filters. I have one in the lens and I can screw an extra one on if I need too. A circular polarizer might help too. For a documentary or wildlife documentary it is probably better to go with a higher shutter speed, because: 1. you want to see the animals perfectly sharp, not blurred 2. it doesn't have to have the "feel" of a movie. It is meant to be a documentary to watch on TV and get see as much as you can.... But as I said earlier, I'm no professional and am still fiddling with this myself. Just try and see what you like. Both with low and high shutters. Watch it on a TV (or high res monitor) though, do not depend on your viewfinder to see the difference. After a while you'll start to like a certain look and you can just leave it at that setting. 0 dB will get the closest original signal as possible. Look at -3 dB as an ND filter with noise reduction filter. And again, play with what you like. In the bright african sun you should not need anything higher than -3 dB anyway, which will give you very nice pictures. Good luck |
Hi Rob,
yeah...had not thought of additional filters, good point. Will be playing a lot in the next few weeks. Pity this thread was not 10 days ago as I have just returned from a week in the Kruger National Park where It would have been great to have tried these things out. Got some incredible sunrise footage which I now have on my desktop...as do another 20 odd people in my business. Would have been nice to have got it better with the tips. Thanks and cheers Andrew |
Sorry for the dumb question. Maybe I should check this out on www.canondv.com
The GL1's lowest manual shutter setting is 1/60. Does the new GL2 have lower manual shutter speeds? (1/30 and 1/15)? Thanks! |
Frank, yeah the GL2 does have the lower speeds. All the way down to 1/8th I think for the NTSC version. (I think the PAL is 1/6th) and clearscan too.
Thanks, Aaron. The GL2 is just looking sweeter and sweeter. Being a pessimist (because of a confused personality, strange culture and a sad childhood) (stupid smile gif, stick out tongue...), I can't find one thing wrong with this cam! Man, if I had the extra cash I'd grab one in a heartbeat. I think it's worth every penny. A cam like this 6 years ago would have sold for a fortune. Thanks, Canon! You were listening!
PS: Canon, when you bring out the GL2s, please add a slightly larger viewfinder. |
I think that despite having 1/4" chips, the GL2 is a serious contender for the VX2000. Canon seems to have hit a home run with the GL2. The Panny DVX100 is very interesting but more expensive than the GL2 by about $1200. It's difficult to come up with any legitimate gripes about the GL2.
Fellow pessimist, |
Yeah it's looking good from what I've heard. Can't wait til we get them here in New Zealand so I can test drive one on the old Depth of Field and all that, that I'm so interested in. Might go for that over an old XL1 in the end.
Good it is a serious contender for the VX2000, but we have to remember that the VX2000 is way older that the GL2. That said, apart from XLR and 1/3" chips it seems that the GL2 has a lot more to offer. Better sound, Higher resolution, Clearscan, Frame movie mode and more. Just hanging out to get my hands on one now...... |
| All times are GMT -6. The time now is 11:46 AM. |
