-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Subtitle problem.. help! (https://www.dvinfo.net/forum/open-dv-discussion/31391-subtitle-problem-help.html)
Alfred Okocha September 4th, 2004 04:03 AM
Sorry posted these twice.. Just thought this forum would be more apropriate..
This is my problem.. I need to somehow put subtitles on a 30-minute show that is currently on Beta SP..
Could I ask the client to transform the tape to a quicktime file and then import it all in FCP? Then I could print a DVD copy for him.. Is this possible without losing too much quality? I'd rather lose no quality at all but..
Do you have any other suggestion how to do it? (My set up is a dsr 370 and FCP4.. using a DCR-trv 19 as a deck..) Would it be better to through DV perhaps? The original tape is in PAL and my gear is NTSC.. (we live in different countries..) Would my cameras playback PAL even though they are NTSC?
Rob Lohman September 5th, 2004 04:20 AM
No your gear will most likely not playback a PAL tape. I think the
easiest would be to go to a TV station for they have subtitling
machines there and a way to easily convert the tape to NTSC
most likely.
Otherwise there are houses that can transfer a Beta SP tape to
a DV tape for example and might be able to convert it to NTSC
for you as well.
It all depends on budget and your client ofcourse. If your client
is a TV station (most likely?) I'm wondering why they are asking
you for subtitling...
Alfred Okocha September 5th, 2004 07:45 AM
HI Rob, thanks for your reply. Your assumption is correct and not... It's a guy working for a TV station but the program is his, and the subtitling is a language not so commonly known there.. The is to be exported to new markets..
So I think I'll ask the guy to send it to me on a DVtae and then I can either play it back on my camera or somewhere else without too much hazzle..
Thanks.
Rob Lohman September 5th, 2004 10:39 AM
Or if you know the language and they have a titling machine
you could perhaps do the work there?
Alfred Okocha September 5th, 2004 01:14 PM
Physically were separated by the Atlantic but otherwise you are right.. I guess I could translate it and send it to them as a word doc.. But to be sure all the titles come on the right place, I think it's better to do it here..
Thanks anyway!
Ryan Spicer September 5th, 2004 05:28 PM
Since BetaSP has absolute timecode, so long as you can view the tape and timecode, you can probably just provide the folks at the station with a text file containing the in- and out-timecodes for each subtitle, and the text for each title. You can even work out the timing from a VHS w/burned in timecode, if they can ship you one, or if you can get one dubbed by somebody with a PAL BetaSP machine and an NTSC converter. Find out what hardware they use, get the specs, and prepare an input file for them to process locally, or barring that, just give them the titles and timings, and have them get it encode-ready. Its probably the simplest solution, if they have a subtitler over there already. I did some work for a company that did closed-caption encoding for various shows on Digibeta this summer, and that's more or less how our workflow went, minus the transatlantic gap..
