Oh boy! computer problems...
I've just installed an extra memory into the computer and now when I restarted it, it didn't start windows xp. Strange. Why not, I asked. The system seemed to just continused to restart itself until black screen with writings came on telling me the computer encountered a problem and presents me with choices, either go into save mode, start windows normally or at the point in time when everything worked fine.
Well, I've tried all and nothing works. The computer just restarts and restarts and then finally enters the same screen with the choices. Nothing is happening here. What's wrong? Then I decide to remove the new memory to see if that is the culprit. Did that help- hell no. The computer restarted itself twice then a blue screen comes up with writings that say, windows is starting up! I'm still waiting for windows to finishing starting up and it's been more than 20 mins. Simply put, nothing is happening. please, any advice? I really don't want to re-install from scratch again. I'm inclined to blame Microsoft - I know, I blame them for every little problem. :-? |
It probably isn't a software problem as it doesn't look like you changed anything. Also, BSODs (blue screen of death) are usually caused by hardware problems (although faulty drivers can be a cause too).
1- Maybe you knocked something loose? Check all the physical connections. Check that you haven't knocked the CPU heatsink loose. 2- Check that all fans are spinning. Check that there are no loose screws in your computer that is shorting out your motherboard. 3- Sure-fire way to diagnose hardware problems: Take your motherboard out of the case and lie it on something non-conductive. Strip everything off it (except for things like the CMOS battery and BIOS chip) and re-install the bare minimum parts it needs to POST: speaker LED CPU heatsink + fan LED plugged in (IMPORTANT!!!) CPU 1 stick of RAM power connector(s) from power supply power switch header (the thing that connects to your power switch) When you power it on, it should start beeping. The beep code should correspond to the one telling you need a video card. Add the video card and all your other parts on. 4- If you ever have to switch motherboards, try to get the same model motherboard. This way you don't have to reinstall Windows. see http://episteme.arstechnica.com/eve/...4&m=1400925745 |
Thanks. I'll try your methods. The funny thing this all happened after I installed the new 256MB memory.
One more thing though. When the computer tells me to switch off the computer it restarts immediately when I push the off button. I quickly have to push and hold the button in for a while until it finally cuts off. I even looked in the bios to see if there is a command that will allow me to choose a better function than this. None. It's a pain in the a** when I always to keep pushing and holding in the button for the second time around. I would have thought one push would be enough. |
That's really bizarre. Possible your BIOS settings are corrupt??? (just a wild guess)
You can clear the CMOS to reset your BIOS settings. Refer to your motherboard's manual. Copy down BIOS settings if you have changed them. |
Okay Glenn. I've just switched over the jumper switch while everything is off according to the manual. But it doesn't say I have to start the system with the jumer in it's discharge mode.
I'm assuming that by just removing the jumper cable while the computer and cable is off, it automatically discharges. Is it the same withn your motherboard? |
An Abit IS7 motherboard manual I looked at said not to boot with the jumper in its CMOS clearing position. It says it may cause strange behaviour.
2- Reading your motherboard's manual is most likely the best idea. What works for one motherboard may not work for another. You can get the manual off your motherboard manufacturer's website. |
Thanks Glenn, I have already done so. I just have to re-install. It's a shame because I'm force to eliminate some important files. Oh well. That's life.
1- You could try a repair install of XP. This will keep your important files around. Sometimes a repair install will give you a messed up version of Windows, but hopefully you can copy important files off and redo the installation (remember to reformat the partition when re-reinstalling).
If you might have bad hardware, the repair install has a good chance of messing up and you may not get a bootable version of Windows. 2- You can get another hard drive and copy the partition off. The hard drive manufacturers give out free utilities which will let you clone a partition. It's also good to have extra hard drive space, so now you have a good excuse to buy a new hard drive :P 3- I'm not too sure what exactly your problem is. You might want to nail your problem down first before doing anything drastic like wiping over important files. |
If your PC is freally screwed up, you could download Knoppix from another computer. It's a bootable disc version of Linux that gives you HDD read write capabilites. Put your PC back together, boot like you have, but with Knoppix in the drive and get your important files off of there, then reinstall...who knows it could work...good luck
Thanks guys. I'm already in the process of re-installing. I have given up on trying. I've been trying for 8 hours to no avail. Oh well. I think there is a problem with my motherboard or something. It's freezes on install at times.
Now what's all that about? It has been behaving strangely for sometime. I guess I'll have to go for the new P4. It's about time any way. |
Glenn or Jesse, I was wondering how often are you suppose to change the small lithium battery on the motherboard that keeps the cmos memory? 'Cos I can honestly tell you, I havn't replaced it since I bought it and we talking something like 7 years ago.
Could that be the problem or one of the problems? I was just curious. My installment didn't go well. I was force to remove the BX6 motherboard and replace it with another motherboard I had from another computer. It's an Asus p3b-F. Now I'm trying to firgure out how to discaharge the memory, mmmmmmmm! |
Charles,
Now would be a great time to switch to a Mac and say farewell to those kind of problems. |
I may just consider it. The only thing stopping me is that windows is so fllexible.
Just been having the same problem with my 2001 Epox 8KHA+ motherboard. I put 2 new 512Meg DDR400 dimms in and the machine cant boot into XP, just keeps rebooting.
Pulled them out and put the old 256Meg dimms in and its all happy again. Looks like the old board cant handle the newer modules - drat! looks like I'm stuck at 512Megs for awhile! |
Otherwise it lasts a few years or something like that. Quote:
http://www.apple.com/support/ibook/faq/ On a Mac you also don't have as wide a range of diagnostic utilities to check for bad hardware. 2- You should be fine if you replace the motherboard, CPU, and RAM. You might need to get a more powerful power supply, although you can use motherboard monitor + prime95 to check if you do. If you get a new hard drive, you can install windows on that and still access your old files. Or you can try the old windows and do a repair install over it in case you cant boot into Windows. |
Well, everything seems to be going fine with the installation. I'm stll in the process of installing and the motherboard seemed to have taken the new addition pretty well. Well, I would jinx it but so far so good. I'm installing XP now.
I knew thayt my comments would spark the inevitable "Mac vs. PC" debate. I almost didn't post it but figured since it was a legitinate option, it would be taken as such. The intitial poster did take it as a sincere suggestion.
I offer it as one who has more experience with PCs than with Macs, but who also has not had ANY hardware/software issues since switching to a mac, even with the iBook I own which is my main system, believe it or not. |
Glenn, I have a 300w power supply. I thought that would be enough for such an old system.
Thr installation went well so I'll see what happens next. Thanks for all tips guys. |
Just a thought here, are you adding RAM or replacing it. I once tried to add more RAM to my machine and it wasn't the same brand. Computer did exactly what you have been describing too.
I took the memory back and exchanged it for the same brand PnY I think it was and all was fine after that.... I just re-read your post, check and see if the RAM is the same as your old ones... |
Nope Greg. It is not. In fact, all of my 512Ram are of different brand. That could have been it but it doesn't matter now because I've changed motherboards and everything seem to be working fine, knock on wood.
For future referrence, has anybody used Knoppix for data recovery on a crashed system? I haven't had to yet (make that 2 knocks Charles), but I have the disc in case. Others have told me it's possible, but none of them have done it yet.
(Charles)
If your computer acts up again or if you suspect you may have a problem then run prime95's "torture test" and Motherboard Monitor at the same time: prime95 http://www.mersenne.org/freesoft.htm Say you are stress testing when opening the program for the first time. Torture test is under options. http://mbm.livewiredev.com/ Check that the 3.3, 5, and 12 volt rails are within +-5%. Wacky readings means you have to mess around with MBM settings of use your motherboard's monitoring utility (not all motherboards have these). |
Thanks Glenn for your help. Will do.
| All times are GMT -6. The time now is 08:07 AM. |
