Transferring video into Flash
Hi!
I am new to all this video stuff so I'm hoping this is a stupid, easy to answer question. I tranferred a video file into Flash that I edited in Premeire and then saved in Quicktime, the Quicktime movie looks great but when I transfer it into Flash there's these lines through it everytime anything moves. Does anyone know how I can avoid this? I tried the different interlace settings when I saved it but to no avail. If you want to see an example of what I mean here's a friends wedding I was trying to do: http://www.eyesbryte.com/wedding/wedding-video.htm (The video is pretty bad but you'll get the idea.) Thanks for your help on advance! :) |
Brooke,
are you compressing the file in quicktime first, then importing and comressing it again in flash? you might want to try sorenson's squeeze. this is an incredible video compressor. It does a great job of compressing video (.avi, etc) into .flv files which are flash video files. Never had a problem like what you are describing when i use squeeze. ~Mike |
Thanks for replying! Yes I am starting with QT. I tried the squeeze trial version but didn't have much luck with it. Do you export from Premiere to QuickTime then have Sorensen "squeeze" it into a flash file?
Brooke:
You've got a 40mb Fash (.swf) file which, of course, takes forever to load. What you need is a Flash video (.flv) file, which can either be a progressive download or use a Flash streaming server to deliver the file. The artifacting you see is the result of flash trying to playback such a large file. In reality, trying to stream anything over about 20 seconds of video in an .swf file will cause problems. Sorenson 4.1 lets you encode most video formats into an .flv file, either as a progressive or streaming download. You should start with the best output file possible and then let Sorenson do the rest. If you're using Dreamweaver MX2004, Macromedia also offers a $99 Flash video kit that includes a lite version of Sorenson and a plug-in that creates the HTML necessary to load the .flv file and play it back. |
Brooke,
doug is right, you need to output the file in the best format, an avi file would be best. from there 'squeeze' the file with one of the presets in squeeze into an .flv file import that into flash and you're good to go. you may want to search around the internet on how to build a preloader as well. this way the preloader lets your audience know the file is downloading.\ ~Mike |
Thanks everyone! I went ahead and purchased Squeeze on your recommendation and the difference between it and their trial version is amazing! I was able to cut the file size in half.
| All times are GMT -6. The time now is 06:01 PM. |
