Lossless Viewing
I have trouble with lossless compression so once again excuse long note. How do I take high quality firewire output from DV camcorder, convert to analog with minimal quality loss, and view on TV at reasonable cost?? Without understanding it, I have been dancing around this question with many of my posts. Took a comment from Keith on NLE thread to trigger this, but I now understand the D/A converters on consumer level DV camcorders (Sony TRV 9 for me) are probably not great. So when I view DV tape using S-VHS output from camcorder to TV I could be losing a lot of the quality inherent in the DV tape due to poor D to A conversion of the TRV 9 chipsets.
Keith edits on NLE and outputs DV to DVD and then views DVD on TV thereby bypassing D/A converters on camcorder. But, this relies also on quality of D/A chipsets (and quality of DV to MPEG 2 conversion) somewhere in that process so do some hardware cards from Pinnacle, Canopus whomever have higher quality D/A chipsets and even higher quality DV to MPEG 2 conversion than others when outputting edited DV to DVD or their breakout boxes?? And, rather than buy DVD burner I have been thinking about buying a DVD stand alone recorder that has firewire input (like one from Phillips). I assume they convert firewire DV input to MPEG 2, burn onto DVD, and then use D/A converter chipsets to output using S VHS or component output. Is there a big difference in DV to MPEG 2 and D/A converter quality in these DVD recorders?? |
Without spending a boatload of money, the absolute only way is to print your edited footage back to a dv tape via firewire. That represents the least amount of loss.
Other methods include, printing to sp beta or digi-beta which would yield good results, if you print to dvd in mpeg2 fashion you will at the mercy of how good your encoding is. kermie ps. remember the only time it goes analog (correct me if i am wrong) is when you play it off the tape. Goin down the firewire from the tape to the pc, or from the pc to the tape, it remains digital all the way. |
Could you print to a digital format and then have a transfer house put it on analog? I thought I remembered from when me and a buddy had a movie dubbed, it was like 8 bucks a copy to put it to VHS. I've noticed that when I output from my camera, via RCA cables to a VHS tape in a VCR (that's the only way I can do it at home) that the quality of the VHS is pretty low, definitely lower than, say, a tape you would rent at a video store. I'm guessing a transfer house can do it better. But I have no real idea.
The highest image quality out of yr DV footage (which already has it's own limits) is optained by a direct conversion from DV into analog components (RGB or YUV) and input these signals into a TV, projector...DVI connection could under some conditions even be better for visualisation on pixel based displays, but this is I think, beyond this dicussion. The quality reduction when using composite (RCA) or Y/C is not so much the D/A conversion problem, but the color encoding step (PAL /NTSC) which is added for getting those standard outputs. Color encoding lowers bandwidths, generates color shifts, color leakge due to futher reduced chroma bandwidth, moire... and the image quality strongly depends on the performance of the display color decoder performance. Copying to VHS is of course a major quality reduction step and the existing Y/C or RCA outputs on camcorders are more than good enough as a source for this purpose. Pro copiers have proc amps not to correct the camcorder signals but to counteract as much as possible the (S)VHS degradation. For this reason, good tranfer houses can make better copies. Intermediate MPEG2 conversion is not bad, avoids the color encoding ( if the DVD is connected through RGB/YUV) but adds an extra MPEG2 compression/decompression ( extra motion artifacts)and is only advisable if a performant MPEG2 encoder is being used set on a low compression level.
The quality of the MPEG2 encoding has many variables. The best quality I have seen relies on seperate hardware processors (PCI board). They are also much faster than the software encoders. The Apple QuickTime MPEG2 encoder is a combination of speed and quality. Cleaner 5 and 6 (software encoders) are also available. Cleaner 6 is said to be much faster than 5. I use Cleaner 5 for my projects that require the best visual quality.
Jeff |
We used to be quite a bit involved in pro MPEG2 hardware encoders and decoders at Barconet (see http://www.saeurope.net/products_barconet/index.asp). Like Jeff mentions there are a lot of parameters involved, but transcoding from DV to MPEG2 ML needs still some extra steps, like DV decompression to (at least) DCT level, interpolation (DVD needs 4:2:0!) and some more tricks and trade offs. In general it turns out that most consumer MPEG2 encoders/transcoders (HW or SW) cannot equal the original DV stream even if only I frame GOPs are used and even when connecting through components (RGB/YUV) vs connecting the original DV through Y/C.
kermie
Thank you and I think you are right in all you say, but my concern was how to get video off the DV tape and onto the TV cathode ray tube with least amount of degradation from what is on DV tape in digital form. As you and dre mention, going from DV to MPEG 2 even though all digital could result in "loss" from original DV signal depending on how good the encoder is.
Josh
Thanks for input and I think dre also touched on why transfer houses can give better quality dubbing due to better equipment like proc amps??
jeff
Thanks for input on hardware processors for MPEG2 encoding-- do you have any name brand recommendations?? I am in PC Win 98SE environment.
dre, throw me a another lifebelt
I was in deep water before and your helpful comments are a rope to help pull me where I can get my feet on the ground. But, when you get time, can you confirm my understanding please. Apologies to all for length of this, but dre is getting me close to dry ground and I really appreciate this.
1. What equipment is available to do a "direct conversion from DV into analog components (YUV) and input those signals into TV"?? at prosumer level cost. That would be the best thing to do. 2. Not clear on your color encoding comments. Is that the general lumenance and chromenance issues relating to how VHS and S VHS handle mixing those together--- i.e. the difference between VHS composite output and S-VHS (Y/C) output?? And is that what your later comment about pro copiers using "proc amps" to counteract S-VHS degradation refers to?? --they use some kind of processors to do a better job seperating colors from the S-VHS signal?? Or, my inexperience REALLY showing here, strictly speaking is there a seperate digital to analog conversion done by my camcorders D/A converter and than a seperate color conversion step also done by camcorder output converter and that "color conversion" step is where the problem lies with what my camcorder outputs?? And this is different from the inherent color conversion problems with VHS or S-VHS?? OR, is the output from S-VHS jack on camcorder just fine and there is some problem--as you put it-- with "the display color decoder performance" on the TV -- again the issue of how the color seperation issue with S-VHS is processed when signal is recovered to be viewed on TV. Bottom line, is there a quality problem with the chipsets or whatever consumer and prosumer camcorders use to convert DV digital tape data into viewable (on TV) analog output?? 3. In your MPEG 2 comments, not sure what you mean by "avoids the color encoding." Is that referring to lower quality color encoding from S-VHS vs MPEG 2?? I have at least read about different compression methods and amounts between DV and MPEG 2 (intraframe and interframe, higher compression with MPEG 2) and lumenance chromenance (but I thought MPEG 2 was 4-2-2 vs 4-1-1 of DV). I would use either an "onboard" DVD burner in computer so to keep signal digital at all times OR I wonder about using an external DVD recorder with firewire input to burn to DVD?? 4. Could you explain the comment about "performant MPEG 2 encoder set on low compression level." Is that referring to using hardware MPEG 2 encoder rather than software and using least amount of compression you can use and still be in the MPEG 2 format?? 5. I understand MPEG 2 does not equal DV "quality" due I guess to more "lossy" compression. However I am not sure from your last post if you are saying due to lossy compression of MPEG 2 I would be better off somehow using the S-VHS output from my camcorder (if I could figure out how to correct the color decoder thing) ??? Many thanks to all who have or will contribute to this. Just call me high bandwidth. |
Dennis, like I wrote., don't go through another conversion step. If you realy want "the best"(...and the most expensive!) buy a DV to component convertor (like DAC-2) or a pro DV VTR (like Sony DSR 15) and an RGB or YUV compatible TV (like many today) or a good projector and nobody will have a better DV image (if the footage is 100%). Also a projector (Marantz, ...) with direct DV 1394 input will give you the best possible from DV footage
Something like the Laird LTM-5500http://www.lairdtelemedia.com/produc...wire.html#5000 is near the tops for converting to component. There are more expensive convertors but you get into line doubling, tripling etc. The DAC-2 is a less expensive alternative. The LTM-5500 supports balanced audio, RS-422 serial control and in my opinion, slightly better picture quality (slightly better S/N ratio, to my eye). However it is probably 3 times the price.
Jeff |
Dennis,
Stop confusing yourself. It is actually quite simple in regards to the reason certain connectors will yield better results. Imagine a pipe, now the first pipe is the size of a straw(composite) and you are trying to put a cupcake through it. When it comes out it will be mangled. It will still resemble a cup cake and taste like a cup cake, but be mushed up and mixed together. Now you have a bigger pipe, slightly smaller in diameter than an actual cupcake (s-video). The cupcake is slightly mangled but much harder to tell, and if you touch it up by fixing up the sides of it with your fingers (television colour adjustments, sharpness controls) to most people at a glance it seems almost perfect. Now a pipe that is a little bigger than the cupcake (component) pops right through, nothing needs to be touched. That is what these connectors are like, while composite shoves all video signals down one little wire, you get a lot of degradation. (vhs is native composite). S-video however seperates the greylevels down its own line, and the colour down its own line, less problems, but still elements of the signal are being pushed together. This is also why s-video looks very shap, because the blacks/greys are prominent from their clean signal in contrast to the colours still being forced together. Then you have component, it has its own channel for greyscale, and two more dedicated for colour. Less has been mushed together, and this method (native to dvd) also presents pretty much the native signal or dv, hence the least amount of down conversion to fit into a little pipe, so will yield the best results. (but is only around %5 better than s-video in percieved quality) Rgb is 3 dedicated channels of red, green and blue and has to make up the grey scale from that pallete. The quality of the DAC in your dv camcorder is quite irrelevant in the end, these days almost all of them are of equal quality, the only time you will see a marked improvement (read maybe a %5 improvment) is when you start spending absolute $1000's on equipment. The s-video from your camcorder is fairly decent and represents almost the best picture from your dv footage. This is the same rule of thumb for dvd players, they do the same proccess and the s-video derived from their signal is a DAC of a native component signal into an analouge picture with its colour imformation brought together and greyscale pushed down the s-video cable. I hope this helps. kermie |
Thanks Jeff and dre
Makes sense, minimize conversions--S-VHS and either DAC-2, Laird or DSR-15 route. Just for comparisons, found Sony DSR-11 for $1999.00 at B&H (will continue looking for DSR-15); DAC-2 for around $650 and Laird website gives about $1800 (about 3 times as you said Jeff). Thanks again for guideance.
Kermie, food for thought
Thanks, Kermie, and let me digest your last note.
Dennis,
Going from DV "Tape" to component is a waste of time and a lot of money. For the best view from tape either go through firewire to your computer monitor(this requires you to deinterlace the footage) or just use the s-video output of your camera. As the 4:1:1 component signal from the CCD is compressed 5-1 in-camera before it goes to tape you will have that compression no matter what you connect your camera up to. As I said in your other similar post, unless you are doing all this for colour correction or testing broadcast safe colours it is all a waste of time and money. The s-video out it the simplest and cheapest way to get nice looking "uncompressed" video out of your camera for general viewing. |
Dennis, I don't think DSR11 has component output.
Adrian, do you know of a good deinterlacer/rescaler for computer viewing, I would be very interested... Y/C is indeed cheap and acceptable for general viewing. If you want "better", than you need component. Agree that the DV decompressors and NTSC encoders in camcorders are not bad these days (there are however differences in the encoder part and they all include the NTSC standard limits)) but that's not the only part in the chain. The (NTSC) decoder in yr TV is even more involved. These decoders, because they need to process also weak and noisy aerial signals, use bandwidth limited chroma channels resulting in color leakage and compromised Y/C delay shifts. Quite often, neither the chroma decoder input filters, nor the subcarrier rejector trap in the luma channel are not disabled in Y/C input mode..The differences between Y/C and component in PAL and DVD (both 4:2:0 based) are even more pronounced. |
The Canopus ADVC-100 has gotten great reviews. It's DV to Analog and vice versa, goes for about $300.00, but net/street prices are better. Analog out is composite or svideo. Have heard only good things about it.
Heres a link to the company site http://www.canopus.com/US/products/advc-100/pm_advc-100.asp Douglas Spotted Eagle used it during his VAST tour, had it hooked up from a 1394 port on a loptop to a television using Vegas Video. The picture looked great. |
ADVC100 is OK but no components out. Some camcorders have "pass-through" (1394 in > Y/C out)
No "magic gadget"
So, today I read on the Datavideo website--- "DV camcorders have S VHS sockets capable of high quality output." Thereby I think dashing hopes that "magic gadget" DAC 2 would vastly improve on conversion circuitry in camcorder and give vastly better S VHS output to TV and vastly better picture. Remember, I am new at all this so it seemed likely I was missing out on some great and inexpensive piece of equipment that would improve viewing my camcorder output on TV. It had seemed logical that camcorders would use inexpensive DAC's thereby giving low quality S VHS signal and hence sub-optimal picture when I plugged it into S VHS input on TV. Anyhow, thanks for everyone's patience and helpful input as you gently steer me in right direction (just shoot) and educate me. By the way jojo, I just printed out eight pages from Canopus which starts out saying they use "a proprietary Native to DV YUV color space" and "...Native to DV as all DV is YUV." Just wait till I finish reading that!!! Just kidding.
Dennis, the DAC-2 hasn't a better Y/C output than yr cam has. The "value" of the DAC-2 is it's component outputs (YUV)which is of course only relevant if yr TV has component inputs.
Sorry for my french, but this YUV discussion that it will make your footage look any better is a complete wank.
YUV at best provides a %10 better percieved picture, and that is purely subjective if you prefer a softer more vibrant picture vs a sharper more defined picture. Stop wasting your time about it. And another thing about the s-video worries, you think a company like sony or canon or whoever they oem their boards from is going to go to the trouble of making one better decoder over another, it is alot cheaper for them to produce one of good quality and produce it in high mass, hence better yields and less overheads. People here are getting it wrong all over the place, the dv footage onto your tape is already compressed, but it is still purely digital, it only becomes analog when passed through the dac. That is the only time!!!! Yes taking from your camera's s-video rather than your tv out on your vid card will look 100x better, that is because the s-video from your vid card is interpreted junk, not a real s-video signal, it is taken from rgb then interlaced then stuffed through a crummy codec and forced down a REAL cheap pathway. The only reason they put s-video on it, rather than composite is because the signal would look that bad in composite people would start complaining, and it is easy to put 1 plug and a composite adapter vs 2 plugs. kermie |
What does this mean for a fellow like me who has a simple VCR from the late 90s? I still say it's probably worth the 8 bucks to go to a transfer house.
Josh,
I really like the idea of burning s-vcd's for use in a dvd player. They are better quality than a vhs tape, cost less to produce, and never wear out. A liteon 48x burner (awesome brand and burner) is around $50 and blank cd-r's are like 0.20c each! and you are getting better quality than a VHS, it is a win win situation, plus you don't need any transfer house to drive to and spend time at. kermie |
Kermie, why would you think YUV has been "invented" and used by broadcasters all over the world? For the %10 better image? Did you ever see Y/C compaired to YUV ?
Dre, it allows you to do critical colour correction more easily and basicly represents a standard that is easy to get quickly from source tapes.
But for the home user it is almost usless, as we colour correct almost always in rgb on our computer screen. And yes i see YUV compared to y/c a lot, infact i had to do many comparisons with many different tv's when i was reviewing dvd's and dvd players. kermie |
I see more than 10% improvement between S-Video and component (at least to my eye). I see much less noise in component video. The noise becomes very apparent on bigger screens. If you have access to a component source (DVD, Betacam SP, etc.) feed the signal into a broadcast monitor and turn on the Blue Gun (blue only). Repeat with S-Video and composite video. The noise levels (and differences) will amaze you. This applies to NTSC video. My experience with PAL video is limited.
Jeff |
Kermie, I agree with Jeff. Maybe you need to compare on a somewhat "better" TV or projector. I suppose you live in a PAL land (like I do) and the differences are even more pronounced there. Do you know that PAL decoders reduce the vertical chroma resolution to 50% as compared to the original U/V values ? Do you know that Pal DL decoding gives an additional vertical chroma downshift of more than 1 line? Do you know that horizontal chroma resolution of a directly converted Pal DV or DVD (4:2:0) signal is twice the normal PAL chroma resolution?
Well what would you folks recommend for sending out to film festivals and the like? I was planning on making VHS copies, but CDs would be nicer.
VHS, even SVHS are clearely inferior to DV and (good) DVD copies.
So, if you can send "cd" use DVD. The best solution (if the native footage is DV), is still DV tape played back through YUV. |
Josh most festivals want a vhs for selection, and if your movie is accepted, then the sorta standard is betacam, and slowly becomming dvd.
If you get excepted time to go to a transfer house. kermie |
See, that's what I figured. So what am I spending money on a CD burner for?
cd burners are great for self dis. of your productions.
kermie |
The last issue of WIRED noted that this year DVD player sales have (est.) exceeded VCR sales or will certainly do so next year. You can now buy DVD players for under $75 at Wall-Mart.
It's hard to imagine that DVD will not quickly become the medium of choice for independent distrubition for all sorts of purposes, including festivals, in the very near future. |
| All times are GMT -6. The time now is 03:12 AM. |
