-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Question about Green Screen (https://www.dvinfo.net/forum/open-dv-discussion/488597-question-about-green-screen.html)
Kevin Lewis December 7th, 2010 04:04 PM
When I shoot green screen I typically use a Westcott background which I belive is a polyester blend. I light it with two tota lights and I get great results. My next green screen shoot is at a studio where I will be filming against a hard green cyc wall. Will I need to light the screen in a different fashion since its a wall and not material, or can I use the tota's as a normally do?
Seth Bloombaum December 7th, 2010 07:06 PM
As you know, a tota is a little brute of a light - a very hard source.
A painted wall might be shinier than your usual screen, but you should be able to tell this as soon as you look through the camera. If there is a shine, you'd move the totas further out to the side so that the reflection isn't seen by the cam.
Think of a shinier screen as a mirror...
If you've been able to cut your keys successfully, and if you'll be shooting a similar shot, it should work fine.
