BAD Wavy Effect
Can someone please tell me why I'm getting this horrible, wavy, colored effect on some my footage? You can see it the worst on the roof and windows. If you look at some of the windows it's like the blinds are moving up and down rapidly.
I used a Canon T2i (24p / 1920 x 1080), Canon 17-55mm 2.8 IS lens, The ISO was at 100, F-Stop 5.0. |
Re: BAD Wavy Effect
Ok, so after some more research it seems this is "Moire", but I mean REALLY?..... I can't film windows, roofs, and blinds.....? Does it happen on the 7D as well or is this just a t2i problem? Any help / suggestions are greatly appreciated.
Re: BAD Wavy Effect
The footage isn't interlaced, is it?
From what I've experienced, progressive footage is generally free of that artifact. Does it show up when you view the footage at full resolution on a monitor that's true 1920x1080? |
Re: BAD Wavy Effect
That's Moire - and pretty much all vDSLR's suffer from it terrible because of how they get video from their large sensors (they don't read every line generally - they skip lines, this causes greater aliasing, which causes greater moire.)
Basically, there is no fix - the cameras aren't actually designed with video in mind, and this is one of the results of that. |
Re: BAD Wavy Effect
There is a fix, buy a video camera or if you need big sensor shallow DOF an Af101 or an F3 ;0)
Re: BAD Wavy Effect
I use a GH2 and have no problems with Moire..
here is a video |
Re: BAD Wavy Effect
So people with DSLR's just deal with this? I just spent $1200 bucks on a lens and now I'm questioning whether or not it was worth it...
Anyone ever try a Caprock 2.0? |
Re: BAD Wavy Effect
Re: BAD Wavy Effect
Secondly, I haven't seen anyone using any anti moire filter, but one thing they are going to do is soften the image. That's guaranteed, so if sharpness isn't your main concern then you have options in terms of not getting moire - you just can't have footage sharply in focus on the sensor, with lots of parallel lines, and not have moire, - due to the practical limitations of the video design. A lot of people do just deal with it - because they haven't brought the DSLR to shoot video of subject matter where moire is going to crop up a lot. At the price you've paid for your camera, you've got a pretty decent stills camera that can also shoot lots of video subjects pretty well. That's something that you couldn't get only a few years ago. |
Re: BAD Wavy Effect
All very true Craig, thanks.
Re: BAD Wavy Effect
Hi Oliver,
I have seen some anti-moire filters popping up recently, you might want to check them out. I have had some more subtle problems in the past but haven't had a chance to test these yet: Now available: my DSLR anti-moire filter for FCP! Free download! Jorgen Escher "FREE" DSLR Moire Filter plug in FCP | Digi1080p I'm not sure what NLE you use, I believe these are FCP only.. Let me know how you get on! Cheers Mike |
Re: BAD Wavy Effect
Mike, I tried the plug-in and it didn't really do anything to help the wide footage. I had the Chroma Blur and Softening amount turned ALL the way up, and there was no noticeable difference. After further reading it seems this plug-in works best with micro-moire issues. The site says "This filter is less effective in removing moire appearing in regular and/or artificial patterns such as brick walls."
This plug-in DID however help me with some close-up shots of a computer screen that had really bad Moire and flicker. This is definitely a plug-in I will be using. Thank you. |
Re: BAD Wavy Effect
No problem, sorry it didn't help the big stuff.
I know it's too late to do on this project, but one work-around - which can even make footage look a lot better - is to take some images before/after shooting the video and use it as a matte painting. Obviously this only works when locked off and requires more work in post, but can look amazing. |
Re: BAD Wavy Effect
Mike, that sound interesting....Never seen that before. Any blogs / video tutorials online of that?
Re: BAD Wavy Effect
Ask and you shall receive!
Here is a good one: And here is one that isn't so much as a guide, but shows a similar technique combined with motion tracking: YouTube - VFX Shot 1 - Building Matte Painting MC |
| All times are GMT -6. The time now is 09:42 AM. |
