sd card life
I have 10 sandisk extreme (30mbs) card that i have been using doing weddings. They are 16gb units, and I am now getting an error that they won't write to the card at high speed. When I do a speed check they are now running at 11-16mbs. I have only used them 6 times. What is happening?
Re: sd card life
Do you re-format them in camera?
Re: sd card life
no, on the confuser
Re: sd card life
Hi Paul
Always, always format the cards in camera, never via a card reader on your computer!! With regards to life cards supposedly can survive 10,000 inserts so I doubt whether we will ever use them that much!! What I do for pure safety sake is run 8 cards in my "current batch" ...every 6 months I retire 4 cards and keep the "newest" four so I have 4 brand new ones and 4 that are 6 months old. As I do weddings and Real Estate shoots I use the 6 month old cards for Realty work (if a card did fail I can simply re-shoot the house) and the most recent cards are assigned as wedding cards as they are definately not re-shootable!! Just for safety, when new cards arrive they are used during the week at Realty shoots to make sure they are 100% and then given the honour of becoming "wedding cards" It might sound expensive but my card purchases are tiny over a year compared to what I used to pay for mini-DV tapes every week!!! Chris |
Re: sd card life
Re: sd card life
Always reformat in-camera. Computers are way more standardized, especially on how they deal with storage. Camera's are the worst when it comes to external storage, and the FAT standard (or lack thereof) just makes it even more of a problem.
Re: sd card life
I've been using SanDisk Extreme Pro SDHC cards in my 60D. The camera may not really need the 45MB/s speed of the ones I have on hand, but I just ordered one of the new 16GB 95MB/s cards from B&H.
$59.95 What impresses me about these is the steel clad construction, temperature proof, and waterproof. Performance has been great. |
Re: sd card life
On the other hand, if your computer is a Mac, then you can use the OSX's native formatters, then reformat the card in the camera. |
Re: sd card life
But why don't you just format the new card in the camera in the first place? That's what I always do.
stelios |
Re: sd card life
Here is the potential problem:
Even if you always format the card in the camera, SD cards can degrade severely in performance after as little as five uses because some cameras perform only a quick format (they have no "low-level" or "full" formatting option whatsoever). The "Low-Level" format option on Canon's cameras works properly only with a fresh card or a card that had been secure-erased on a computer; with cards that have been previously used in the same camera, "Low-Level" is exactly the same as a quick format. (This is due to woefully insufficient battery capacity in consumer cameras to permit a truly full card format, which can take anywhere from several minutes to several hours.) In fact, I did experence this many times with every single one of my cards regardless of brand, model and capacity: For example, the write speed of one of my cards suddenly dropped from 20 MB/s all the way down to only 8 MB/s after using that same card only five times. This is because newer and larger-capacity SDHC cards are now using very cheap MLC NAND flash chips that have a rated life as few as 1,000 (or even 100) write cycles. One would have to go all the way up the SanDisk line to the top-of-the-line Extreme Pro 90 MB/s line just to even find an MLC flash rated to even 10,000 write cycles. And even when fresh, many of the so-called "30 MB/s" cards have write speeds that are far slower than the read speeds (again, this is due to the use of super-cheap but short-life NAND flash chips); for example, my 16GB SanDisk Ultra 30 MB/s SDHC Class 6 card has an actual benchmarked write speed of only 7.5 MB/s maximum. In other words, reliability-wise it's a race to the bottom, not to the top. |
Re: sd card life
According to my experience, memory cards are quite durable, though occasionally finicky when it comes to formats.
Re: sd card life
well peeps, its all sorted with the old 'format in the camera' trick. It has removed a fair bit of stress from me and the missus now not to mention keeping cash in my wallet. We bought 3 cards new each wedding just for the service and speeches to make sure that we got the coverage that we needed. Gees if its not the batteries, its the cards, now its my focus is a little out... I can't win.
Just because everyone is doing it heres a link to our latest Highlights!! Anna & Jordan's Highlights Video - YouTube |
| All times are GMT -6. The time now is 10:14 AM. |
