-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Use P-TAP accessory with non p-tap camera battery? (https://www.dvinfo.net/forum/open-dv-discussion/521570-use-p-tap-accessory-non-p-tap-camera-battery.html)
Evan Platt February 9th, 2014 01:32 AM
Hi All,
So I'm upgrading my JVC GYHD110 (which is now for sale BTW) to a Canon XA10.
I have a few accessories - well, OK, a very bright light! that has a P-TAP (I believe that's the correct name? It plugs into a batteries4broadcast battery or the side of the HD110). But there's no such connector on the XA10 if I'm not mistaken (don't have the XA10 yet).
Is there a way to power the light with the XA10? Maybe with a special battery, or a 'battery pack'?
Derek Heeps February 9th, 2014 04:20 AM
Re: Use P-TAP accessory with non p-tap camera battery?
I suspect you're thinking of D Tap ?
You can see PAG batteries and adaptors so equipped on their website .
https://www.paguk.com
Evan Platt February 9th, 2014 10:00 AM
Thanks - maybe it is called D-TAP. I have a little 12 volt battery 'belt' was hoping to maybe power it from there (it has a cig lighter plug on it). Don't know if I can justify spending the $300 or more for that setup! :)
Don Bloom February 9th, 2014 11:10 AM
I've made a couple of different patch cables to power D tap accessories from cig adapter and 4 pin adapter power supplies. B&H sells male and female D tap connectors seperately, pick up some wire and I found cig and 4 pin plugs at Bescor (used to sell them don't know if they still do maybe B&H has them). A little soldering BAM....Patch cords. I've run all kinds of D tap accessories including a camera off of 12 volt Bescor batteries...Anton Bauer Ultra light, JVC HD100/110/200, other lights on light stands...
Do a little searching around I think you'll find the connectors you need.
