-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Datavideo DAC-70 Up/Down/Cross Converter vs Decimator MD-HX HDMI and SDI Cross Conver (https://www.dvinfo.net/forum/open-dv-discussion/536278-datavideo-dac-70-up-down-cross-converter-vs-decimator-md-hx-hdmi-sdi-cross-conver.html)
Josh Hayes September 26th, 2018 08:25 PM
Has anybody used both of these devices? My specialty is corporate conferences and has been for around a decade but I'm always behind the times when it comes to getting the feed of the slides from presenter who is speaking/presenting. For years I've either pointed a shitty cam at the projector to use for timing later once I get the powerpoint, keynote, etc.. slide decks for timing and match in post, or been handed digital videos files from house AV when the client has the budget. Now I want to start capturing the digital video files myself to save a ton of time so my goal is the Datavideo DAC-70 to Black Magic Video Assist. Has anybody used both of these?
Gary Huff September 26th, 2018 10:31 PM
Re: Datavideo DAC-70 Up/Down/Cross Converter vs Decimator MD-HX HDMI and SDI Cross Co
I was looking at getting a Decimator unit because most of the time when I run a signal into my Odyssey 7Q+, it is 1080p60. For a whole day's worth of sessions, that's a lot of content even in ProRes LT (ProRes Proxy quality was not acceptable). With the Decimator, I would have a passthrough for HDMI (the Odyssey won't pass audio through itself out of the HDMI out port) and I'd send a 1080p24 or 1080p30 signal for capture. The ProRes is still too large, but it would be less of a filling up of 1TB every day with 60p.
However, now I'm considering this device. This would record H.264 instead of ProRes (I'd probably set it to the max of 30Mbps), and you can pick to record at half frame rate. I'd have to test this, but I assume it means you'd get 30p H.264s instead of 60p, which would be fine. It would also record to cheap SD card media, which would be ideal.
I don't need the streaming element of the recorder, but I haven't come across any standalone solutions that are any cheaper.
Tony McGuire September 27th, 2018 08:00 AM
Datavideo do a recorder it is HDR-1 https://www.datavideo.com/product/HDR-1
I am looking at one and it seem to meet every thing I am looking for.
Nate Haustein September 27th, 2018 08:21 AM
Totally agree with finding a pro solution if that’s what you need. However, I’ve found a nifty little device that does what we’re asking - record a relatively low bitrate 1080p H264 file of slides. It’s also helpful because it can be used as a loop through between laptop and projector at smaller venues with no AV support.
https://www.amazon.com/dp/B01MYWBG1I/din02c-20
Press the button and it works! Plug in a 16Gb USB stick and it records all day. There are actually a lot of these types of units around, this is just one I happened to find for cheap locally. Perfectly timed slides DO change your life! :)
Gary Huff September 27th, 2018 11:27 AM
Nate, interesting find. It says it does not work with USB 3.0 devices, have you tried a 3.0 flash drive?
Nate Haustein September 27th, 2018 12:01 PM
Yeah, works fine with a cheapie Sandisk 16GB USB3.0 thumb drive. I stick a little 3.5mm mic on it as well to get sync sound.
Josh Hayes September 27th, 2018 01:50 PM
Yeah I went this cheaper route 2 years ago. Got 2 or 3 game recording devices and used them for a 2 day conference. At first I purchased two different ones and then compared them. I kept 2 of them after the conference and returned two. But there were a variety of problems with each of the gaming capture devices that made them unreliable. I can't remember everything that didn't work now which isn't very helpful here but I remember needing to plug a portable hard drive into it that had to be formatted to NTFS or it wouldn't work. Plus there was order of operations for turning it on, versus a signal being passed through, vs pressing record or stop in the right order, and I remember if the record didn't go properly it would skunk the drive. So I got them to work about 40% of the time but I constantly had to check the device and reboot and all this other stuff that just sucked. That's why I'm thinking about a more pro solution now, especially since I already have a Black Magic Video Assist.
Josh Hayes September 27th, 2018 02:34 PM
Got it. The decimator looks like the cheaper version of the DAC-70 and it appears to also take SDI/HDMI in and and can Output them as well. And sound is passed through also. I wonder then what the advantages of the DAC-70 has over the Decimator (if any) then?
That's a really good point about the ProRes LT Capture though. I looked it up on Black Magic's website (the BM VA has the same issue as the Odyssey) and at 1080P24 you get 3.47 hours of recording time on a 256 GB SD card. And you're right too that ProRes Proxy isn't good enough. It would be nice to have something in the middle with H.264 you're right. Perhaps the Datavideo NVS-30 that you and Tony mentioned is the best option. it's just that it's $300 more than the DAC-70 and $500 more than the decimator. Another option is to buy a 512GB SD card for $160 to get a full day out of it, and then just run the files through compressor for a day after the fact and convert them to H.264. Not ideal but cheaper. Though the thought of not having to spend the time to do that conversation is pretty appealing to I have to admit.
One thing about that NVS-30 is that it doesn't take SDI In. So in many cases we'd still need a little SDI to HDMI convertor to feed the signal coming from the house into HDMI. So that's a small cost increase as well but mostly negligible.
One thing I'm wondering though. If we get as pricey as $800 for the NVS-30 maybe it begs the question of why not spend $200 more and get the Black Magic ATEM Switcher, where we could capture the files in H.264 via Black Magic's native app and also have a live switcher! What do you guys think? Are there key elements to the ATEM that I'm missing that make it not do everything we need that the NVS-30 would do?
Gary Huff September 27th, 2018 08:59 PM
For me, I need something that's portable (I routinely do this out of state), and I almost always have an HDMI source. I'd prefer to have it the first thing straight from the laptop. I've personally not run into needing to convert SDI into HDMI, though when I was considering the Decimator, I was going to take SDI into an Odyssey. The issue is that it all has to be up front with everything because I really can't be lugging around 150' of cable for any potential length of runs needed from the front of house. That also takes my recorder out of the mix for anything else I would need it for.
For me, the ATEM requires a laptop. so now I have a laptop taken out of the mix or I have to travel with two machines. That's not idea, especially considering that, the majority of the time, it's just me. The NVS-30 is pricey (the HDR-1 is a bit better at $499), but it's an all-in-one solution. One box, does everything.
Josh Hayes September 28th, 2018 03:46 PM
Ah got it. For corporate conferences I'm pretty posted up so I don't need portability that much. And I'd add the extra luggage costs (if there were any) and stuff to the bill.
For me personally usually House AV wants to send me always via SDI and avoid what they consider the more consumer standard of HDMI (especially if it's a long run of cable). However my Black Magic video Assist takes either Mini-SDI or HDMI, and since I have HDMI cables already I'd probably go that route. Or I could just get an SDI to Mini SDI adapter I suppose.... So for me I'm having the house run me SDI cable from backstage 150 feet where I'lll have a couple cameras on sticks. But I can easily make room and add a laptop and whatever to the scenario. I always have one laptop with me anyway, so I'm set there.
I hadn't heard about the HDR-1. That's a little bit better than paying for NVS I suppose. Although I feel like maybe the streaming component might be awesome. Makes me want to pitch live streaming as a possibility to my clients. If I tested it and got everything weekend I could see that potentially increasing the budget.
For the ATEM I don't know enough about it yet. It's a dream of mine to have live edit setup. Very often when I'm filming conferences I hire an additional camera operator because the 2nd half of a day splits into tracks. That would mean potentially that I could have the 2nd camera op just run the standard wide, and tracking medium shot, and I could potentially live edit it. Have the first half of each day finished in real time! Once I started looking at $500 dollar solutions, all of a sudden the $995 ATEM doesn't seem as far away as a goal.
But I need to do research and find out more. Because I think it doesn't do any recording other than passing the signal through to my laptop at H.264 via their proprietary app. But maybe that's enough.... The main problem someone mentioned about a year ago was that supposedly it doesn't scale or allow multiple different formats like a 1080P 23.98 Camera Feed and 1080P 59.97 Slide feed. If that's true it's less useful and requires more hardware I suppose. It doesn't stream though and obviously it's twice the price.........
Gary Huff September 28th, 2018 04:49 PM
In my experience, the lack of proper bandwidth to livestream video at most venues (necessitating the use of a LiveU pack) and the dozen or so live viewers on average for most events that don't have the draw of say, a celebrity, means that clients will be unwilling to pay any extra for it.
Josh Hayes September 28th, 2018 04:51 PM
That could be the case that's true. I've only done it 2 or 3 times low budget status (one camera through a Black Magic Convertor) using Livestream and there's always issues with the internet.
Josh Hayes October 18th, 2018 02:51 PM
Believe it or not Nate, I'm thinking one of the cheap little recorders might be my best option after doing a ton of research on potentially bigger purchases like the the BM Hyperdeck Mini and stuff like that to go with BlackMagic Atem HD Switcher.
I think what I'll do is take the slides feed from the house and record it via the device you mentioned. Since it works as an output as well (something a bunch of the big dogs don't do), then I can pass the output through to my switcher. At which point I can still do a live edit with the connected cameras and that slide feed and record that final Program to my Black Magic Video Assist at Apple ProRes LT quality.
My main thing was I wanted a hardware solution that recorded the slides like I needed in case something went wrong with the live edit so I didn't loose the timed slide record. And that if did it without needing a laptop as well. Also the fact that you can stick a little mic on it for sync is awesome too. And you're saying USB 3.0 works as well?
How compressed are the slides btw? Do you have any problems with the device being for lack of a better term, wonky? As I mentioned earlier in this thread I had a hell of a time getting the several cheap recorders I got to work a few years ago. Hell, theoretically I could buy a second one of these and do an H.264 capture of the final program record as well (although the Atem doesn't have an HDMI Program Out so I'd need to convert SDI to HDMI to do that. But then I'd even have a low quality backup of the entire live edit. Have you tried to capture recorded footage with it at all? I'm curious about how heavy the compression is.
Steven Digges October 21st, 2018 12:49 PM
Gentlemen,
Your discussing something I have 20 years of experience doing so I will help if I can. Recording corporate meetings in a ballroom was my bread and butter for many years. I understand it from the meeting planners side, the AV side, and your side.
I do not want to tell anyone what they should do so please don't hear it that way. I have a formula for you may want to consider. I understand money matters to us all. Fortunately the rates to do this work properly are good enough to use the proper equipment and not worry about "a few hundred dollars" if you have regular gigs.
First, begin with the end in mind. The end goal is to deliver a quality product and do as little post as possible. I have done hundreds of these massive multi-day gigs and recorded as much as 40 hours of video to be delivered. Of course they are all not like that but many are. I can't even imagine going into post again and syncing multi-camera feeds, slides and audio again. For many years now my post production basically consists of titles and graphics only. Forty hours of raw feeds in post if you have to actually cut between sources can translate to countless days of your time and a loss in profit or an untimely delivery. The only way to avoid it is to edit live via a switcher. I suggest your goal needs to be avoiding or minimizing post-production. Yes it costs more but the reward can pay for itself on one gig.
Fortunately these days you don't have to pay big bucks for broadcast switchers like I have. Check out Rolands line of switchers. The name of the game when interfacing with corporate AV is versatility. You need to build an adaptable system that can handle signal flow of many types. That is where SDI, HDMI and scaling come in. My Decimator is a powerful and useful tool. Not just because it converts HDMI to SDI etc. SDI and HDMI are simply cable types and conduits for a signal. The Decimater is an amazing signal processing cross converter. That is it's strength. When interfacing with AV systems your going to get either SDI (most common) or HDMI feeds and the signal is going to be whatever they are sending to the projectors. The cost of switchers varies greatly by how many of the inputs have built in "scalers". You need a switcher with at lest one scaled input. The Decimator often works as an external scaler for additional inputs.
I am not going to bad mouth Black Magic (again) here but I will say why I won't recommend them for this type of work. It is safe to say they can be temperamental and don't play well with other kids on the block. They work well if you are building a system for yourself and will be working with a fixed set of signals every time. They keep cost down by building limited components on their lower end gear. I am encouraging you to consider adaptability and comparability with the AV video world.
Video guys tend to think of production as a two step process, acquisition phase and post. In corporate meeting video production you have the ability to almost eliminate the huge burden of reliving countless hours of all those boring meetings in your editing sweet. Once you have completed a gig live by sitting in front of your switcher you will never go back to multi-track editing again.
And yes, I have traveled with switchers to over 30 states for corporate gigs. Lugging one around is a small price to pay for the reward you get. Hope this helps, I do know you guys are discussing less costly options but if you have the gigs you can afford better gear. How can you afford not to spend most of your time editing?
Kind Regards,
Steve
Gary Huff October 21st, 2018 07:10 PM
It literally cannot, because the cost of the switcher is not the problem. The problem is the cost of at least one camera operator minimum, because you can't switch and follow the speaker at the same time.
I will say that I had the Blackmagic Cross Converter to do a straight HDMI->SDI to go out to an Odyssey and it didn't work with MacBooks, which is a huge must-have for me, so I'll be getting the Decimator if I decide to go the SDI route.
While I agree with this in general, I actually just did a shoot in which I was running teleprompter and using vMix to toggle in graphical elements that are typically done in post, including motion graphics. This worked pretty well, but again, with my process, the extra cost is in needing to have a second camera operator, especially when doing events out of state.
You don't even have to lug one around. The Odyssey 7Q+ with the Apollo option (or the straight-up Apollo unit)is perfectly suited for this kind of shoot, especially with a Decimator to send out SDI into unit at a matching framerate, the cost is in the second operator, which is ongoing. And second operators bring with them reliability issues or simple competence.
