-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Recording computer screens (https://www.dvinfo.net/forum/open-dv-discussion/55664-recording-computer-screens.html)
Rob Parker December 7th, 2005 12:05 PM
Hello
I’m trying to edit up a software demo video. I’ve tried recording the image of my computer screen with my Sony FX1 as well as using “Snage It” screen capture/video recorder. Neither are producing the results I’m after, ideally I would like to obtain comparable resolutions and quality to the online flash demo’s here (http://www.phpbb.com/support/tutorials/)
Any Ideas?
Mathieu Ghekiere December 7th, 2005 12:48 PM
Does it help if you change your shutter speed?
Rob Parker December 7th, 2005 01:00 PM
yah, it helps a bit, what happens is a bit of a ghost image follows the mouse, which isn't the end of the world. Thanks for taking the time to post.
Rob
Jack Smith December 7th, 2005 10:00 PM
I have a slow connection so I didnt look at the link.Not sure what you want to do but if you need a shot of a computer sceen part frame one way is to shoot with a camera like XL1S with clear scan that allows fine control of frequency.Another way would be to green screen the screen and add video to it in post.
George Ellis December 8th, 2005 11:04 AM
Microsoft's Windows Media Encoder will also do screen captures in WMV format if that is an option. It may give similar results to SnagIt though.
Richard Alvarez December 8th, 2005 11:46 AM
Camtasia studio 3 might do it.
Mike Cavanaugh December 8th, 2005 02:45 PM
Have you tried using a LCD monitor for the demo? They do not have the same problems with flicker and scan lines that CRT monitors do.
Dennis Khaye December 9th, 2005 12:17 AM
The software companies that I've seen (think Autodesk and McGraw-Hill) capture their screens with software and the end up as bloated avi files. Need a pretty speedy box though. I use Fraps to capture FPS game time and the quality is excellent.
Graham Risdon December 9th, 2005 12:38 AM
The PHPBB demo is a flash movie - try BB Flashback for recording screen demos at http://www.bbsoftware.co.uk/bbflashback.aspx
I've used it for software demo CD-ROM's and it works well.
Hope this helps
Tim Ribich December 9th, 2005 04:33 PM
Camtasia will work
Originally Posted by Rob Parker
Hello
Any Ideas?
I use it a lot and it works great:
http://www.techsmith.com/products/studio/default.asp
Amy May December 10th, 2005 09:17 AM
Can you record from an LCD to a camcorder?
I am also interested in recording activity on the computer screen for a client and am trying to find a better way. My challenges are:
1) The software is being demonstrated on my client's computer so I'd rather not install video capture software on their system. I only have macs and the software is pc only.
2) I have a cheap scan converter, that I have hooked up to the computer in the past and then recorded onto miniDV with my camcorder. However, I am not thrilled with the quality.
The only possible solution I have come up with so far is using a LCD TV with a RGB video out that is hooked up to my camcorder (Viewsonic makes one).
The question is, is this possible and will there be any refresh or flicker issues? Has anyone tried it or do you have a better solution? Thanks in advance.
Steve House December 10th, 2005 09:52 AM
Check your camera's manual for something called "ClearScan" or something similar. It's a feature some cameras have that helps sync the camera's scan to a monitor's scan to get rid of the rolling strobe bar that otherwise results. You haven't said what camera you have so there's no way to know if your's has that feature or not.
Amy May December 11th, 2005 07:44 AM
I'm using a Panasonic DVX-100. Thanks, will see if that function exists.
Graham Risdon December 11th, 2005 08:05 AM
Shooting Computer monitors
If you're trying to shoot computer screens to video (as opposed to capturing a flash movie for computer display) there are a few choices:-
1. Get a good scan converter and match the output resolution of the computer to the scan converters best setting (usually lower res is better for SD as the scan converter doesn#t have to srop so many lines)
Result - OK, depends on scan converter
2. Shoot an LCD monitor - doesn't seem to flicker much, but needs to be carefully lit. Again the lower the res, the better the result usually...
3. Try the "PD150 trick". This involves matching the shutter speed to the scan rate. Don't know whether it would work on your Panasonic. A BBC PD150 training course at http://www.bbctraining.com/onlineCou...=5160&cat=2797 explains this well (about page 10 of the PDF) It works but takes a while to master!
Hope this helps
Amy May December 13th, 2005 03:50 PM
Thanks Graham, that is a good source for info. I tried videotaping the LCD screen of my iBook and the results were pretty good so I think I'll go the LCD monitor route. I let you know how it turns out even though the filming won't likely be for a few weeks. Thanks for all the ideas.
