-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   How Bad Is Fake Widescreen On Consumer Cameras? (https://www.dvinfo.net/forum/open-dv-discussion/56532-how-bad-fake-widescreen-consumer-cameras.html)
Mick Foley December 21st, 2005 08:00 PM
Originally Posted by Michael Wisniewski
Yup, you're camcorder is recording anamorphic widescreen video. Now all you have to do is to format it properly for widescreen DVD output.
... basically tell your NLE/DVD creation software, that your video is anamorphic widescreen - fyi, your camcorder won't letterbox the anamorphic video for you, you'll have to burn it to a DVD or play it back on a computer or widescreen TV to see it displayed properly.
Visit our Premiere forum for assistance with your software.
Thank you so much Michael! :)
Mick Foley December 21st, 2005 10:06 PM
I just thought of something right now. I'm able to turn on the "fake widescreen" as well as the stretch kind at the same time. Would this mean I could have a 2.35 image?
Adam Woodworth January 3rd, 2006 08:55 AM
If the image fills the screen but looks squished like an old spaghetti western, your camcorder is recording true anamorphic 16:9 video. If the image is letterboxed, then your camcorder is recording 4:3 letterboxed video.
This is not necessarily true. For example, the Sony DCR-TRV33 and Canon XL2 shoot true anamorphic 16:9, and will display the video in letterboxed format on their LCDs.
Also, note that the Canon XL2 uses true 16:9 CCDs.
Happy New Year!
Adam
Mathieu Ghekiere January 3rd, 2006 09:06 AM
You mean cropping to 2.35?
You would loose much resolution... and with DV you haven't got much to even begin with...
But for watching on a usual television screen it can be enough.
Marco Leavitt January 3rd, 2006 09:08 AM
"This is not necessarily true. For example, the Sony DCR-TRV33 and Canon XL2 shoot true anamorphic 16:9, and will display the video in letterboxed format on their LCDs."
Ditto for Optura 60.
"I just thought of something right now. I'm able to turn on the "fake widescreen" as well as the stretch kind at the same time. Would this mean I could have a 2.35 image?"
I experimented with this on our old GL1 and it does indeed seem to work, but keep in mind with the pronounced resolution loss that you get that a 2.35 image isn't going to look so hot. DV in general isn't real well suited to wide panoramas IMHO.
Christopher Lefchik January 3rd, 2006 09:37 AM
If one used an anamorphic adapter (one of those that attaches to the front of a camcorder lens) plus the camcorder's built in true ("stretch") widescreen mode you could get high quality 2.35. Of course the problem would come in editing such footage. I don't know that any of the prosumer apps would understand such footage to properly process it. Any text one added wouldn't look right, etc., unless you added it after the letterboxing process (you'd have to add the extra letterbox bars so that your 2.35 footage would play back properly from DVD).
Boyd Ostroff January 3rd, 2006 09:42 AM
This topic comes up regularly, see the following:
http://www.dvinfo.net/conf/showthrea...&threadid=3069
http://www.dvinfo.net/conf/showthread.php?t=18917
http://www.dvinfo.net/conf/showthread.php?t=39732
http://www.dvinfo.net/conf/showthread.php?t=23390
http://www.dvinfo.net/conf/showthread.php?t=22798
http://www.dvinfo.net/conf/showthread.php?t=18905
http://www.dvinfo.net/conf/showthread.php?t=13696
Jim Rog January 3rd, 2006 08:01 PM
Hello
can the FX1/Z1 be up scale to 35mm without loss? also are these cams true widescreen? how can you tell?
Boyd Ostroff January 3rd, 2006 08:30 PM
By definition, high definition is widescreen (16:9). It should be a safe assumption that any camera which shoots HD (Sony HC1, A1, FX1, Z1, Canon XLH1, JVC HD10, HD100, Panasonic DVX200) all have native widescreen chips.
Look at the aspect ratio that they work in:
1920/1080 = 1.778
1280/72 = 1.778
16/9 = 1.778
Not really sure what you mean by "upscaling to 35mm without a loss"...
Jim Rog January 3rd, 2006 09:22 PM
Originally Posted by Ainslie Davies
If you are going to film then maybe your camera is true 16:9??? If not then the image produced by the camera may not be up to the massive scaling to 35mm
was quoting the last bit in this post
