-   Open DV Discussion (https://www.dvinfo.net/forum/open-dv-discussion/)
-   -   Need multi-cam advice... have questions (https://www.dvinfo.net/forum/open-dv-discussion/56900-need-multi-cam-advice-have-questions.html)
Stephen Armour December 27th, 2005 10:15 AM
I'm preparing to do an interactive, long term, not-for-profit children's series (DV for now) in southern Brazil where I live. Since I do all the editing, as well as coordinate (direct/produce) things, I'm looking to gain some time by capturing all video as standard DV via firewire, to either a portable RAID array, or a single CPU, then transfer via Gbps Ethernet or Firewire to my editing suite later.
Here's the available equipment in this studio setup followed by my doubts:
2 DV cams (with XLR inputs for synced mic input)
2 HDV cams (1 with XLR inputs for synced mic input)
3 hidden, balanced super-cardioid mics (phantom powered) feeding into cams
1-UHF transmitter with headset mic for main talent (feeding into cam)
Now, my doubts:
1- though the sets are fairly small, the distances from cams to capture point could possibly exceed 30ft. Too far for IEEE-1394, right? How do I do it without a very expensive solution?
2- what is the best way to input those 4 streams of DV video/audio into a single RAID or multi-disk equipped CPU for transfer to my editing setup later?
3-Is it better to input each Firewire channel to a separate disk or to a fast RAID setup? I have a spare CPU with both IDE and 4 disk SATA RAID. Does each firewire input need a separate disk? If so, why, since DV capture is way below the speeds of those disks?
4- I normally edit in PPro 1.51 and plan to purchase Multicam 4-camera software to help with the multi-cam editing. Is this good, or unnecessary? Since there will be many cutaways/animations/visuals, is there a better way?
Okay you multi-cam pro's, I need some good advice...
Stephen Armour
ABE Prod.
Chapecó, Santa Catarina, Brazil
http://www.abeprod.com.br
Glenn Chan December 27th, 2005 11:58 AM
Hi Stephen, here's one approach that would work:
A- Record onto miniDV tape on each camera. During production, use a slate to aid in syncing the shots. In post production, you will need to capture from each tape. And then you need to sync up each camera, which is not difficult. It might be annoying if you have a large number of takes.
Capturing: If you want to speed up the capture process, you can have multiple computers capturing. If you capture to a firewire drive, you can simply plug the firewire drive into your editing computer.
Syncing: You can look online for pictures of slates. Basically the way to sync is to use the audio waveforms in your editing program. When the two parts of the slate hit each other it causes a spike. In case you don't have audio for some reason, you can sync things visually by findind the frame where the two parts hit. You can also write down what take is what, so in post you can figure out which take something is.
You don't actually need to feed sync sound to each camera... you could feed your 4 mics into two of the cameras. The last two cameras can use their on-board audio for syncing in post.
This is the cheapest and highest quality (highest quality since you can edit out mistakes), although it can take the most time.
B- Another approach is to do a live edit-to-tape (switching the video live as you record to tape). If you watch soap operas on TV, they shoot things in a way that makes things easy. The actors always have huge pauses in between their lines of dialogue, making cutting easy.
To do this you need a switcher/mixer... there are various posts on this.
This is the fastest, and can be the 'cheapest' because it's the fastest. But your camera operators do need to know what they are doing, and you have to make an initial investment in monitors and the switcher and the cabling.
C- I think there is some $100k solution for recording multiple inputs all synced. This would be the highest quality and fastest.
2-
Personally I would use Vegas and one of the third-party multi-camera tools or scripts. The VASST website has a free multicamera script somewhere, and I think there are some posts in the Sony Media forum about free scripts. VASST also sells their Infinitcam product designed for multi-camera situations (designed to save even more time).
The nice thing about Vegas is that you don't have to wait a long time for Premiere to build the audio waveforms (if it still does this). The building process is very fast in Vegas.
The takes feature in Vegas and the multicam tools available should make multi-camera situations really easy to handle.
But anyways, all the programs will do the same thing here. If you find things take too long in Premiere, then look at your options.
3- You don't actually need a RAID to handle this situation. If you want to play back 4 streams of DV (i.e. for anything like Infiniticam) I think one drive might actually be enough. Otherwise do a RAID with 2 drives, or have two independent hard drives with 2 angles' footage on each drive. The two independent drives will actually be faster, although file management is slightly harder.
Stephen Armour December 27th, 2005 12:43 PM
multicam questions - still hunting...
Thanks for answering Glenn. I have used your first suggestion in the past for multicam projects, but I am hunting info specifically for 4 DV firewire feeds to CPU, not to tape (except as backup). Please reread my post.
Since this is a very involved project, hopefully destined for broadcast TV here in Brazil, and I already edit using PP 1.51, I need something more specific for helping speed post production. This is not a "live production" and cannot be done with a normal video audio switcher.
The audio is easy to input with the DV streams (like you mentioned), however via firewire it is not, due to the distances (see my post again).
Here's what will probably be my final solution: use a spare CPU (I already have) with SATA RAID using the two onboard firewire inputs, add another IEEE-1394 board and input just 3 of the closest DV cams (two are actually HDV) directly to that CPU. Since they'll automatically be synced the moment I start capturing, sync is a no-brainer. I really don't even need that "clapper" or a flash, or clap or anything.
The most distant (fourth) cam will have to be captured to another CPU (or to my laptop). All this hassle is to speed transfers to my main dual-Xeon editing station, so I DON"T have to capture via DV tape later!
Maybe I'm just creating trouble with all this, but somehow the idea of constantly re-capturing from DV tapes leaves me cold. Especially given the difference in cameras. If you want trouble, just try that and you'll soon discover it is NOT the way to go!
Still hunting for suggestions...
Richard Alvarez December 27th, 2005 12:56 PM
HOw will you simultaneously capture three seperate DV/HDV streams to one Raid?
Don't know of anything that will do this. You can 'switch' between them, but then you don't have the unswitched material to work with later. This is essentially switching live to tape, which you've indicated you don't want to do. Switching between cameras requires synch generators.
You CAN capture to various hard drive devices, like FIRESTORE and then they are ready to edit from directly, but each camera will require a firestore or computer/storage device on it's own.
30 feet of firewire will need a 'repeater' that boosts the signal.
SO, to sum up. You'll need seperate hard drive/Capture solutions for each camera, as I know of NO software that will capture three cameras to one raid simultaneously, without switching. (Please correct me if I'm wrong someone.) Such solutions as FIRESTORE are likely what you are looking at. This leaves you with material ready to edit without re-capture.
You will need a 'repeater' for long firewire leads... however, if you have firestores docked on each camera, this is a moot point.
You will need an editing app that will edit multicam materials from dissimilar sources (DV and HDV) simultaneously in the timeline. (Don't know if PP does this, Avid does.)
Good luck.
Stephen Armour December 27th, 2005 02:02 PM
good question Richard. Answer: below
It's really pretty simple...if I can somehow figure a way around the (very expensive) IEEE-1394 repeaters. Here's how:
I will not use a RAID, but only the SATA drives. Each firewire input get a separate drive. Easy on the CPU, and the drives. Should easily handle up to four cams! The IDE serves as the boot and OS drive.
Just transfer the input later via Firewire. Easy.
I'm sure it'll work...now if I can reduce the distances to the 3 cams and CPU, I've got it figured out. This is WAY CHEAPER than 4 Firestore, which are unnecessary for studio work, only field productions.
Raptors would let me handle up to 8 cams easily, check the specs...
Transport from the studio to editing suite will be done via large portable Firewire drive for all four (or three...or eight) separate streams.
Marcus Marchesseault December 27th, 2005 04:33 PM
First, a question: Have you captured multiple streams of DV to one CPU before? Does windows recognize multiple cameras simultaneously? The total data throughput is not so high, but don't forget about latency. Computers are not always perfect about switching between tasks and I would be concerned that some of your streams would get lost in the shuffle.
When suggestion a solution to a problem, it is good to look at the situation as a whole. My suggestion would be to reduce the number of cameras used. Do you really have 4 qualified camera operators? Do you have sufficient cause to use all 4 cameras? Are the different cameras getting in each others shots? With small sets and many cutaways to graphics, I can't really think of a reason for more than two or three cameras. Honestly, I can't come up with anything other than a medium shot and a closeup shot with a third cam for a reverse-angle shot. Your life would be easier and your production better if you can limit your footage to that from three good cameras with three good operators.
Richard Alvarez December 27th, 2005 07:25 PM
Stephen,
What is your "CAPTURE SOFTWARE" that will allow you to capture all these streams simultaneously on one CPU?
Stephen Armour December 28th, 2005 11:23 AM
things are coming together...multi cam input
Marcus, that is definitely a good question and the answer is no, I have never captured multiple Firewire streams to one CPU before. I suppose if I had, I wouldn't be here asking questions about it...?
The reason I am even considering this, is because I have a good friend, with a private business, working on very sophisticated video projects for gov, industry and military. He works on a level that I seriously doubt anyone in any of these forums has worked (or is working). It was at his suggestion I am even considering doing this, and because of his experience in multicamera extremely high resolution capture rate video.
Now today, he's just decided to build a solution for me (pretty good bud...) that he's going to market with very soon. Linux box, embedded OS, multicam digital (4 inputs or even more + HDV and uncompressed digital too) video inputs, transfer for editing via Firewire (for now). Mostly will be for studios/sets, but he will make it tough for field too. Can change the capture codecs via CF cards and has hotpluggable HDD(s). This is all a spinoff from some "big" projects he's got going, so you can guarantee it'll work at gov/industry specs.
I'll be the guinea-pig beta tester for the 1st box, so will let you know what happens.
BTW, HIGH quality Firewire cables can be up to 10 meters no prob. Word from the guys that know...
Stephen Armour
ABE Prod. - Brazil
Richard Alvarez December 28th, 2005 11:31 AM
Okay, so that answers my question. No such software exists... YET.
Looks like your buddy holds all your answers... good luck!
Stephen Armour December 28th, 2005 01:37 PM
My buddy said the prob is "Windows". Get away from that, and poof***, gone are your multi-cam, multi-stream video probs! This solution will also have config and transfer of the data from the Linux box via LAN to Windows, however. So people like me can deal with Linux.
Looks like he'll offer it for what should prove very attractive for many, many pro's and prosumer's. I will try to post info here when he has a final price. This solution may be sold through retailers later, but lucky will be the ones getting in on ground floor, especially those wanting robust, but reasonable solutions for multi-cam work! Like me!
BTW - for Marcus: the reason for 4-5 cams is simple: since this is a truly "interactive/spontaneous kid's production", ANY camera/gaffer/lift movement would be highly distractive to 7-11 yr olds! These are not "little actors and actresses", but real live, normal kids. There will be two groups, switching off to vary somewhat from week to week, and to provide "no-show" coverage.
I can't totally eliminate the camera-people (one is a woman) obviously, but will try to keep them down to an absolute minimum. Curtains and props provide some cover from the distractions, but it's still a hard production to shoot. If I had my way, I'd have 5 cams (2 low>high, high>low, for over-the-shoulder shots, one cam on main talent, one cam for kid closeups, and one cam set wide a little nearer center stage, but without a cameraman) instead of 4. But greed and need have limits...I'll eliminate one over-the-shoulder cam just to relieve my editing load later.
For exactly the same reasons, I'll be using 4-6 mic inputs, then doing mixing later with FX and music. This is for broadcast TV, DVD and then streaming to a potential audience of 200 million people in 5 countries. Gotta get it right the first time and do it with a pretty sparse budget! And you thought miracles can't still happen? We'll see in a few weeks...
Dwayne R Smith March 19th, 2006 08:06 PM
Multicam shoot
I am going to shoot a recruitment video for the company that I work for.
I have a XL2 and a PD 170. I travel to South America for mission trips. This is the reason for the cameras period. Most of my work is live event for church functions, but I need to recover some on my investment.
Would it be sudden death if I bought A FX1 for the second camera instead of buying a second PD170 or XL2? Could the average joe or customer be able to tell the difference?
I bought the PD170 for the low light. But it lacks the features of the XL2.
The PD170 travels better. The FX1 has native 16:9 chips and is small like the PD170. Maybe shoot in HDV and downconvert. What do you think?
Thanks in advance
Dwayne
Daniel Wang March 19th, 2006 10:39 PM
a quick answer
HD downconverted looks cleaner to non-vidiots. (us) : "Hey did you get a new camera"
(Between a PD150, XL2, F900, and Z1) I'd just do a sit down with the client between the 3 cams, shooting outdoors scenes, color bars, horizontal bars, and complex lit scenes. See if they can tell, and base your decision off of that
Dwayne R Smith March 20th, 2006 09:23 PM
Thanks for your reply Daniel. No I didn't get it yet, I have to go out of town for a week and I don't want it to show up while I am gone.
Dwayne
Bruce Pelley April 19th, 2006 07:38 PM
Multicam editing:What are the PC software
options?
Once upon a time I had the luxury of doing real time,on the fly editing using a live switcher between several cameras,these days however...alas.. due to the present circumstances I need to learn to do it the painful and time consuming way,i.e on the computer at least for a while to come.My platform is a PC as my Mac is an aging one.I do not have vegas,premiere pro 2,final cut pro or anything of that stature which has an built-in multicam feature. I've only been able to come upon United Media's 4 camera program (well it's really a plug-in) which looks like it will do the job.Have any of you have hands on experience on this software or would reccomend any other similiar stand alone programs or plug-ins which would be a viable solution,a solid alternative to tedious editing?Thanks and I hope to hear from you.Any insight,comments, experiences or tips welcomed.
"The newbie in video digital editing land"
George Ellis April 20th, 2006 03:57 AM
Avid Liquid (previously Pinnacle Liquid Edition) does multicam in post. I cannot remember if it supports 9 or 16 different cameras. I have never used more than 3. My workflow includes logging (non-synced) tapes (it will do sync too and you change the logging style to select a specific camera), finding a common frame and setting a clip marker, then selecting all the clips, then select to create a multi-cam clip. It then gives me a dialog that I select sync on first marker. It creates a new clip in my bin. I then "play" the clip in the source viewer and it gives me a display with all of the clips. I click on the clips to change the camera. I usually take it to full screen to do it. If I make a less than optimal cut, I can undo the switch (it is a numbered marker). When done, and add it to the timeline and it is the switched clip.
I think I remember that Vegas does it too, but no experience.
Richard Alvarez April 20th, 2006 06:11 AM
Most of the NLE's have a multicam solution. Avid Liquid, and AVID XPRESS Pro will do it natively. Vegas has a plugin, as does Premiere Pro... so you have options.
Bob Grant April 20th, 2006 06:45 AM
Vegas with Infiniticam can cut upto 100 cameras although I've only used it for 2. Certainly not the same as working in a linear suite, I think only something like Video Toaster which runs multiple video streams would come close to the same experience. However I found doing the job with Vegas and the plug in pretty productive
Peter Ferling April 20th, 2006 01:06 PM
If your used to live-event on hardware, and now want to do it on a PC in software, the Video Toaster is the way to go. It has modules and software that mimic hardware, with the buttons and switches intuitively placed. The system comes with a hardware card that supports uncompressed and has things like real procamps, waveform monitors, etc. You can also get a hardware switcher with T-bar if you want touchy feely. Cool stuff, all on your PC. They also have a hardware input switcher, (I have the VT3 with the older SX8 input switcher). It's a very impressive setup for SD, simple event switching, and live web streaming.
VT5 is rolling out with HD support and sports an updated editor that supports all frame rates and resolutions up to HD. The beast wants heavy fire-power (i.e. dual-core opterons, etc)., so I've order a BOXX 7400 workstation.
Newtek also offers their Tricaster, a lite version of the VT in a shoebox form-factor and simplier interface for DV.
Gary Bettan April 20th, 2006 02:51 PM
Some very good advice here already. Just to sumarize
Avid Xpress Pro has real-time multicam switching. you can even do it with different format (ie DV & HDV) sourse material
Avid Liquid has multicam as well. Very similar tot he Avid implementation
The new Premeire Pro 2 has multicam as well. Once again, similar style to Avid. With one of thenew Matrox realtime cards (Axio LE, RT.X2), you can do real-time multicam with mixed formats
Vegas implements multicam via affordable plug-ins. Excalibu and Ultimate S both do a great job.
For live mixing of up to 3 cams, Tri-Caster is SWEET!
Gary
Videoguys.com
Peter Ferling April 20th, 2006 06:55 PM
Ditto on the Tricaster. I've rented one for a job some months ago. Had a two camera shoot and used the power-point as a third source from a video projector. I was able to record a live mix/feed of the show, editing on the fly, (cut's only) and burned a DVD at the end for archive.
Stephen Jackson April 21st, 2006 12:18 PM
I purchased a Tricaster last year from Videoguys. I used it on a 24 city music tour.
The machine is good but it has a few quirks. The machine froze on us too often when we're loading the artist's video clips and lower thirds. Once we got the last upgrade that problem diminished some.
One thing that I wished I did different was to have more time to learn about the machine. We had a hard time learning how to create our own customized lower thirds and bugs.
But the end result is It was a good investment and we're using it more often.
Matt Davis October 24th, 2007 06:53 AM
Cameras for low budget multicam
I'm moving into multi-cam shoots for a couple of contracts involving conference content, and will be using a Newtek Tricaster Studio (mostly for 16:9 and PPT compatibility). The intended destination is for the web.
I have a Z1 and HVX200, and can rent Z1s by the yard, but have been thinking about other options - especially considering remote cameras. The camera should be compact, good (that is, 'ideally better than a Z1') in low light, 16:9 native, able to output (not necessarily record) Standard Definition in both 4:3 and 16:9 for the Tricaster (so that's probably S-Video rather than SDI), and hopefully earn its living on single camera shoots too.
FX-1 or another Z1 is the no-brainer. Sony A1 is out as it's afraid of the dark. Canon A1 could be fun, I hear good things about it. Another HVX200 is possible, the images are lovely, but it's a camera that loves being the centre of attention rather than a team player. I really wanted an EX-1 but I'm not certain it outputs 4:3 SD on S-Video.
OTOH, what of the 'brick' cameras? Boxes with a lens w. remote controls at one end and some bracketry for a panel display at the other, in an attempt to be a junior studio camera? What of the 'roving eye' video conferencing cameras? The latter seem more expensive than the FX-1 and that's without the remote twiddler...
Richard Alvarez October 24th, 2007 07:15 AM
I don't know how you plan to set up your system, but I often to remote shoots with a tricaster, and two 'elmos' with a third camera manned by an operator. The elmos are capable of being remote controlled either by wireless or by wired connections (With a joystick.) We use these for cable broadcasts, so it's SD and 4:3. The Elmos don't output 16:9 however, so I'm not sure they will do what you want. Do you plan on having all three cams manned? Or are you looking for a three camera, 'two man' solution?
Matt Davis October 24th, 2007 08:30 AM
This would be a three camera, one cameraman situation (so the two unmanned cameras are doing wide and reverse/Q&A). I'm not knocking on the doors of full-on multicam, in fact trying to reduce the time/cost of shooting 2 cameras onto tape and editing in the PPT after.
Had to smile at the Elmo moniker.
What do you use for an Elmo? The Sony and Polycom cameras seem prohibitively expensive...
BTW, am planning to wire up the reverse angle cam using a couple of CAT-5 converters. Anyone tried those as well?
Matt Davis November 2nd, 2007 12:16 PM
<blush>
(slaps forehead)
And here was I thinking about the Elmo reference being a 'puppet', e.g. a remote camera. Boy, do I feel stupid. Just realised Elmo is also a brand that's all but disappeared in the UK (IIRC associated with Standard8 film projectors).
Richard Alvarez November 2nd, 2007 12:59 PM
Yup, ELMO is a brand of remote video cameras as well. They can run with infrared controllers, or with hard wired joystick controllers as well. And yes, I typically have one live camera operator, and two 'elmos' for a lot of shoots. The elmos can be 'preset' for six positions. So - I'll be at a conference, and put Elmo 1 on my left, Live CamOp center, and Elmo 2 on my right. I can preset Elmo 1 to get a nice wide cover shot of the table of speakers, then I can preset six 'close up' shots of each chair say. Maybe on Elmo 2 I'll have a different wide cover shot, maybe a shot of the audience say... some shots of the presentation models or charts... whatever. Each of these presets can also be adusted WHILE LIVE if you want... but they are not smooth. You can zoom, pan, focus... whatever.
http://www.touchboards.com/elmo/PTC-100S.asp
Between switching, calling shots, paging through powerpoints and presenting lower thirds, and controlling the Elmos... I'm busy as a one armed paper hanger.
BUT like I said, this is SD for cable mostly, and I don't know if Elmo makes a 16:9 cam. I doubt it.AND they are NTSC and 4:3 so they won't help you much in the UK I'm afraid.
So really, if you're down to using two small mini-dv cams that DO shoot 16:9 as your cover shots, you are more limited unless you mount them on a remote controlled HEAD... which is another option.
Andrew McMillan November 6th, 2007 10:01 AM
low budget multicam system
Alright so I want to make a 3 or 4 camera system. I have a dsr 300 and an mx-50 laying around here and a jvc dvm 600 recorder (do everything machine). So I thought may I should buy more dsr 300's of ebay for about $3,500. I would also either need to upgrade the switcher with that bob rall modification or get a low end datavideo switcher. Honestly I am not a fan of the fx1 like cameras, there image quality in sd is just kinda muddy looking to me.
So should I go looking for the dsr's and mabey a pd 150/70, or should I look for some older good cameras, or look at some 1/3 cams.
I am realy looking for most picture for my buck.
I like tally alot maybe the dv camplex or the datavideo intercoms, just a thought.
Mike Cavanaugh November 6th, 2007 11:46 AM
Your limiting factor with the equipment you mentioned is the MX 50 which will not switch DV signal, so the best you can get is S-Video output from the cameras. If you are looking for cheap - look at decent used s-vhs or Hi-8 camera with good glass. They will pass a good signal (provided your runs are <100') and save you bucks over looking for a DV cam. If you want your cameras to do double duty, then DV is the way to go.
Andrew McMillan November 6th, 2007 01:40 PM
Yeah, hense the upgrade or just get the datavideo switcher. I looking for some good quality cams, something like more dsr's or some beta sp's, or hdv. Any sujestions?
