common aspect ratios
What are some common aspect ratios for DV and film? I know about 640x480 but don't really know any others. |
NTSC DV is typically 720x486
Aspect Ratios (the ratio of width to height of the screen) are slightly different, these are 1.33 for standard definition televsion/DV, etc 1.78 for HDTV, 16x9 video 1.85 for 35mm widescreen 2.35 for 35mm anamorphic |
NTSC DV is 720x480, not 486. PAL is 720x576. You have two
aspect ratios. Pixel & frame. Both PAL and NTSC frame aspect ratios are 4:3 (yes, even with the above figures if you take pixel aspect into account). Besides frame aspect we have pixel aspect which determines how a square pixel should look. PAL is 1.067 (ie, the pixel is 1.067 times more wide than it is high) and NTSC is 0.9 (ie, the pixel is less wide than it is high). Common frame aspects are 4:3, 16:9, 1.85 & 2.35. |
I was talking about this with a retired friend of mine. Well, I guess he has a lot of time on his hands because he emailed me a list of many common and not so common formats.
Format......... Variation.......................................... Aspect Ratio ..........Desc ............... Type ................. Dimensions Std 35mm Panavision Combined HR HDTV............... 1.33........................ TV 4:3............. TV Trans............... 0.617x0.464" Std 35mm Panavision ..........................................1.33........................ TV 4:3............. TV Trans................ 0.792x0.594" Std 35mm Panavision.......................................... 1.33........................ TV 4:3............. TV Safe Action...... 0.713x0.535" Std 35mm Panavision.......................................... 1.78........................ HDTV 16:9...... TV Trans................ 0.825x0.464" Std 35mm Panavision.......................................... 1.85........................ Widescreen 1.85 Projected............. 0.825x0.446" Std 35mm Panavision.......................................... 2.4.......................... Anamorphic....... Projected............... 0.825x0.69" Std 35mm Arri...................................................... 1.33.......................... TV 4:3.......... ...TV Safe Action......... 18.1x13.6mm Std 35mm Arri...................................................... 1.33.......................... TV 4:3.............. TV Trans ..................20.2x15.2mm Std 35mm Arri ......................................................1.78.......................... HDTV 16:9...... TV Trans.................. 21x11.8mm Std 35mm Arri..................................................... 1.85.......................... Widescreen 1.85 Projected.............. 21x11.3mm Std 35mm Arri .....................................................2.35.......................... Anamorphic...... Projected..................21x18.2mm Super 35mm Panavision................................. 1.33........................... Full...................... Gate......................... 0.98x0.735" Super 35mm Panavision................................. 1.33........................... TV 4:3 .................TV Trans.................. 0.706x0.531" Super 35mm Panavision................................ 1.78............................ HDTV 16:9......... TV Trans.................. 0.945x0.531" Super 35mm Panavision................................1.85.............................. Widscreen 1.85 ....Projected.............. 0.945x0.511" Super 35 Panavision ......................................2.4 ...............................Widescreen 2.4 ...Projected ..............0.945x0.394" Super 35mm Arri ..............................................1.33........................... Full ........................Gate......................... 24x18mm Super 35mm Arri............................................. 1.33............................ TV 4:3.............. TV Safe Action............. 22.5x16.9mm Super 35mm Arri .............................................1.78.............................. HDTV 16:9 ......TV Safe Action.......... 22.5x12.65mm Super 35mm Arri .............................................1.85........................... Widescreen 1.85.... Projected ..............23.5x12.7mm Super 35mm Arri .............................................2.35........................... Widescreen 2.35.... Projected ..............23.5x10mm Std 16mm Panavision ...................................1.33............................. TV 4:3.................... TV Trans................. 0.368x0.295" Std 16mm Panavision ...................................1.33............................. TV 4:3................ TV Safe Action...........0.331x0.248" Std 16mm Arri .................................................1.33............................. TV 4:3.................TV Trans..................... 9.35x7mm Std 16mm Arri ................................................1.33.............................. TV 4:3 ...............TV Safe Action........... 8.4x6.3mm Super 16mm Panavision .............................1.33.............................. TV 4:3 ...............TV Safe Action............ 0.331x0.248" Super 16mm Panavision .............................1.78............................ HDTV 16:9.......... TV Trans .....................0.47x0.264" Super 16mm Panavision .............................1.66......................... Widescreen 1.66.... Gate........................... 0.486x0.295" Super 16mm Arri ...........................................1.33.............................. TV 4:3............. TV Safe Action.............. 8.4x6.3mm Super 16mm Arri.......................................... 1.78.......................... HDTV 16:9........... TV Trans.................... 11.95x6.72mm Super 16mm Arri.......................................... 1.66.................... Widescreen 1.66........... Gate....................... 12.35x7.5mm Photographic 35mm.................................... 1.33.......................... 35mm ................Negative Image........... 32x24mm Photographic 6x4.5 ..................................... 1.33.....................Medium Format ......Negative Image ...........56x42mm Photographic 6x6........................................ 1.0...................... Medium Format ......Negative Image ..........56x56mm Photographic 6x7....................................... 0.85.................... Medium Format .......Negative Image......... 56x69.5mm Photographic 4x5..................................... 1.25...................... Large Format........... Negative Image ...........4x5" Video 2/3".................................................. 1.78....................... TV 16:9 ....................16:9 CCD Sensor ........9.6x5.4mm Video 2/3".................................................. 1.33....................... TV 4:3...................... 16:9 CCD Sensor......... 7.2x5.4mm Video 2/3"................................................. 1.33 ....................... TV 4:3........................ 4:3 CCD Sensor...........8.8x6.6mm Video 2/3"................................................ 1.78 ........................ TV 16:9 ......................4:3 CCD Sensor......... 8.8x4.95mm Video 1/2" ................................................ 1.33........................ TV 4:3 ........................4:3 CCD Sensor......... 6.4x4.8mm Video 1/4" ................................................ 1.33........................ TV 4:3 ........................4:3 CCD Sensor .........3.6x2.7mm Video 1/3"................................................ 1.33 ........................ TV 4:3 ........................4:3 CCD Sensor .........4.8x3.6mm |
Well.. what can I say but thanks a million for all the help.. I'm digging my new community... and so many Texans... reminds me of home in Austin...
thanks again. -BJ |
| All times are GMT -6. The time now is 01:03 AM. |
