Waveform and gain doubt
Hola guys, i have a question for you:
how do the waveform work exactly to avoid overexposure? The white stuff shoukd stay between the 2 big rectangles (on a total of four rectangles) right? Othe question: the gain should not be less than 400 iso right? Thank you so much |
Re: Waveform and gain doubt
que tal Marcus
The waveform will show exposure levels across the frame ranging from superb lack to superwhite. In the AF100's WFM, there are a series of dotted horizontal lines and solid horizontal lines... the solid lines represent, from top to bottom, 100%, 50%, and 0% IRE. Ideally white would be at 100% IRE, black at 0% (or usually 7.5%IRE). Simply enough, just keep the levels from going above 100% to prevent overexposure. Conversely if you want a sold white background and want to be sure you have a solid white background, then adjust exposure and lighting on your background until you have a solid line at 100%. If you want your subject to fall in the ~50% IRE region, then watch for its signature in that range of the WFM. Here's a video that explains WFMs in general pretty well: Hope this helps As to gain, on the AF100 I think 400 is ideal and 800 is still good. Depending on the scene file, 1600 and 2500 are still workable, 3200 is OK but starts to get messy. |
Thank you kevin!
I really appreciate your post! |
| All times are GMT -6. The time now is 06:00 PM. |
