one more question
My first cam was a Kodak. I was about 6 or younger when I got it. |
sorry jeff but i don't agree with you there. i believe that leica does design the lenses. The cost of a good quality leica lens would come when the manufacture the lenses. i would say that they would design the lenses (R&D cost) but they are probably made in japan or some asian country where it is cheaper. We've already talked about video lenses and have already come to the conclusion that they wont be as good as 35mm lenses but at the resolution that our cams take it doesn' matter a lot. If they are using aspheric lenses then there shouldn't be any barrel distortion. i just hope that they aren't using the plastic lenses. either way i am not dissapointed with my mx-500 at all and the only draw back are the low light problems.
Justin |
That's a good point concerning plastic lenses. I keep reading about that they are used in consumer cams---but which ones? Perhaps they're only in puffed plastic cams? Seriously, I would like to know which cams use plastic lenses---not that I think they are no good, but certainly not as good as high quality glass I would think.
I definately don't like the idea of plastic lenses. i think probably the worst thing with them is they do restrict light. i think though that this is not the biggest problem for the mx-500 concerning low light./ i do believe the problem is the ccds. The fact of the matter is that i am happy about my pana at the moment and no matter what anyone tells me the footage wont change and neither will my opinion of the footage if someone tells me that the lens is rubbish or similar. I would however worry if the outer element was plastic of course i would just take more precautions. either way i don't care about the technology of any cam as long as it takes good pictures and at the end of the day i think mine does.
Justin |
hmmmm i'm just waiting for them to make futher developments in producing Carbon glass(diamond) as opposed to silica glass, it's most likely to be purer than silica glass, and a hell of a lot lighter and scratch resistant
they've already found away to make Diamond Wafers for IC's instead of using silica wafers, and the method they use apparently allows them to make diamond glass in what ever shape and size they need =) Diamond glass, Yeah baby YEAH!! |
lets come back to the sweet spot =)
to use tha tables correctly we need to have the correct info in the spread-sheet. 1) film resolution (l/mm) = 80 147 This is for Velvia. Velvia resolves 80 l/mm at contrast 1.6, 160 l/mm at contrast 1000. I logarithmically interpolated the l/mm at contrast 30 because my USAF resolving power chart shows this contrast. since we will be using CCD, how much should be this value? someone said that it's 30, but to give the best imageshould be at least 90? what do you think? 2) lens base resolution (l/mm) (for model 1)= 80 A reasonable default value, for the center of the lens' image circle. Shouldn't this value be higher? 3) diffraction constant 1500 Used to characterize diffraction as a function of fstop. I have no idea about this one =/ those two that follow should be the same? 4)lens aberration base (l/mm) (for model 3) 50 Used in a heuristic formula for lens aberrations. 5)lens aberration factor (for model 3) 3.5 Used in a heuristic formula for lens aberrations. |
D_mn. Most of those are my favourites as well.
Which OM do you like best. I'm thinking of buying an OM4 as a 2nd cam, and maybe selling my FM2T and also going with a F5. (Leica's too pricey for me, especially the lenses.) Do you like mechanical shutters? Did you have a Rapid Winder for your M3. The guy who makes them is a friend of mine. He just lives 3 blocks down the hill from me. |
No, but a winder would have been nice. I'm not sure it would have worked with the double stroke model. I had two F5's but I didn't like them, they were too big and heavy. I shot more with my N90 than either F5. The F5 anniversary is a cool camera though.
I was heavy into the OM series for about 10 years or so. I prefer TTL flash, so the OM 3 would not be my favorite user camera. My favorite user OM camera would have to be the Black OM 4. I had both the Black and Ti versions and I didn't care for the champagne color of the titanium. I like mechanical shutters, but I need TTL flash for the fill flash work I do. Unfortunately mechanical shutters don't work with TTL flash. Oh well, can't win them all. |
Exactly. I never seem to be satisfied when it comes to still cams, and there never seems to be that perfect one. Thank goodness we have Panasonic video cams. :-))
| All times are GMT -6. The time now is 08:46 PM. |
