-   Panasonic DV / MX / GS series Assistant (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/)
-   -   nice tiny 3-chip (https://www.dvinfo.net/forum/panasonic-dv-mx-gs-series-assistant/26313-nice-tiny-3-chip.html)
Frank Granovski May 20th, 2004 11:39 PM
nice tiny 3-chip
What else, the GS200. What a nice little cam!
My wife wanted to buy it on the spot!
But is ain't no Japanese Domestic such as the GS100 and the old MX3000. :-))
It may be tiny, but it's still puffy.
Justin Boyle May 21st, 2004 03:58 AM
The biggest query i have about this camera is whether or not the image stabiliser is worth using since the chip resolution is so high. another thing guys, because this cam is only using a portion of the ccd will that mean that things such as barrel distortion will be reduced because this generally only occurs at the corners of the ccd.
Justin
Frank Granovski May 21st, 2004 04:12 AM
I never tried the cam. There was no battery in it nor did I have a miniDV tape with me. I just looked it over, felt it, and put it in my hand...nice fit. :-))
Graham Bernard May 21st, 2004 04:24 AM
"The Rubber Biscuit!" de do de dooo . ..
Frank, like the "palm-grippy" stuff on the body? Is it rubber or what? Neat idea . . you think you've seen it all . .then . ..
G
Frank Granovski May 21st, 2004 04:29 AM
Like I said, it looks and feels like a nice cam but it does look puffy for its tiny size. It must be the square-ish box-like shape.
Tom E Young May 21st, 2004 05:28 PM
I did see small Panasonic with 3 ccds but I can not remember the model. I did see dv953 and I think it is better and the gs400 will be more better but I have not seen the gs400 because it is not out yet.
Frank Granovski May 23rd, 2004 04:29 AM
...but I have not seen the gs400 because it is not out yet.
That certainly does explain why you haven't seen one. :-))
Kamal Tailor May 23rd, 2004 07:20 AM
the GS200 was released in Japan quite some time ago, but was only just released world wide, it is the same body as the GS70 just the internals are different, apparently the CCD's are the same as the GS100 or the MX500 or something like that anyway
