-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   DVC-30 - DVC-80 - GL2 confused/neophyte (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/19502-dvc-30-dvc-80-gl2-confused-neophyte.html)
Brian Mitchell Warshawsky January 15th, 2004 02:09 AM
Michael wrote:
No it's not the same, the DVX100 has true progressive 24fps - no need to convert the video from 60i, and no de-interlace artifacts
How exactly would the respective images differ? I am unfamiliar iwth de-interlace artifacts.
It would be interesting to compare frame-grabs of each.
Brian
Stephen van Vuuren January 15th, 2004 10:49 AM
They differ in, one the incredible amount of rendering time it takes to convert all your footage to progressive :)
but they will suffer from lower resolution will introduces both softness, especially in wide angle, and jaggies with diagonal lines. You also can get strobing and other problems as unless you are very careful when shooting your 60i, you won't see 24fps motion artifacts until you are in the editing room. Shooting progressive lets you see it as you shoot.
Also, shooting progressive with 1/48th and 1/24th shutter speeds gets you a better motion blur than 60i and 1/60th shutter speed.
Finally, and most importantly, shooting 24p captures different moments in time than 60i - 60i can never "see" those same moments.
The DVC80 is for 60i shooters. The DVX100 is for progressive. Shooting DVC80 footage and deinterlacing it is like buying an desktop and strapping a portable generator to your back so you can carry the desktop around :)
Michael Wisniewski January 15th, 2004 12:20 PM
Check out 100fps.com (click here) It will explain and show what happens when you try to de-interlace 60i/NTSC or 50i/PAL video.
Brian Mitchell Warshawsky January 15th, 2004 01:44 PM
Great replies, thanks for the thoughtful answers.
Brian
Edward Kennedy January 17th, 2004 02:41 AM
<<<-- Originally posted by George Loch : This is silly. The GL2/DVC30 do not compare at all to the DVC80. As was mentioned, the DVC80 is a better competitor to the PD150 - feature for feature.
As far as waiting, if you have jobs tha you are missing out on then what's the point? Go get a DVC80 start bringing some income in. If it's a hobby then...can't help you there
GL -->>>
why so? not the silly part, but regarding features as the dvc30 is not out and i have yet to find any comprehesive information
George Loch January 19th, 2004 02:29 AM
Here are a few of the specs on the DVC-30:
http://panasonic.co.jp/bsd/sales_o/02products/products/ag-dvc30/ag-dvc30.pdf
Basically, the DVC-30 has the following hits compared to the DVC-80:
-1/4" CCDs
-no XLR audio builtin
-inferior zoom an focus controls
Are these deal breakers? for me they would be but, for some I guess not. The point is that it's basic specs put it in competition with the GL2 and TRV-950 not the DVC-80
GL
