-   Panasonic DVX / DVC Assistant (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/)
-   -   squeeze or no squeeze? (https://www.dvinfo.net/forum/panasonic-dvx-dvc-assistant/38931-squeeze-no-squeeze.html)
Michael Buendia February 5th, 2005 12:36 PM
with the dvx100a, are there any advantages in shooting 16x9 squeeze mode over normal 16x9 (mattes) if your end project will end up in 4x3 format/letterboxed? do you gain any lines of resolution in squeeze mode or do you end up with 360 lines either way?
mb
Barry Green February 5th, 2005 02:29 PM
No advantage whatsoever. You will actually end up with slightly less resolution in your specific stated case.
Squeeze mode is for when your footage will be displayed on a 16:9 television. For your specific needs (a 16:9 image letterboxed within a 4:3 video stream, for display on 4:3 televisions) Squeeze mode would be the wrong choice.
Glenn Gipson February 5th, 2005 10:50 PM
Re: squeeze or no squeeze?
<<<-- Originally posted by Michael Buendia : with the dvx100a, are there any advantages in shooting 16x9 squeeze mode over normal 16x9 (mattes) if your end project will end up in 4x3 format/letterboxed? do you gain any lines of resolution in squeeze mode or do you end up with 360 lines either way?
mb -->>>
Squeeze mode will give you a wider field of view then simply chopping off the top and bottom of a 4:3 image (matte approach.)
Barry Green February 6th, 2005 02:54 AM
Incorrect. Squeeze uses the exact same width area of the CCD as Letterbox mode does. It just digitally stretches it.
The anamorphic adapter will give you a wider field of view, but Squeeze mode does not.
Peter Jefferson February 6th, 2005 03:40 AM
it really is wirth the added resolution by going anamorphic, on top of that the friggin lens ends up looking like a bloody panavision which is no bad thing ;)
but as mentioned, your field of vision is only strected vertically, u gain nothing horizontally.
Glenn Gipson February 6th, 2005 06:04 AM
<<<-- Originally posted by Barry Green : Incorrect. Squeeze uses the exact same width area of the CCD as Letterbox mode does. It just digitally stretches it.
The anamorphic adapter will give you a wider field of view, but Squeeze mode does not. -->>>
I compared squeeze mode on my 100A to the in-camera letter box mode, and I noticed a wider field of view. Maybe it's a psychological thing, but it was why I chose to shoot my comedy in squeeze mode. I'll test it out again, though.
Peter Jefferson February 6th, 2005 06:08 AM
line the edge of your frame up with a vertical object, like a door or pole youll notice that the width will not change.
One way to preserve SOME resolution, is to run the video track (in post) just on the edge of the action safe area (pan crop tool). This will shrink your footage a lil but you can save anything between 7 to 10% if shot correctly.
Glenn Gipson February 6th, 2005 06:21 AM
No need to test, you guys you would know more then me about this. I'm not that technical. But damn, if I would have known this before....
Arne Johnson February 8th, 2005 04:38 PM
What if you vainly hope that one day you'll be one of the 1% of people who get a film out? Is letterboxing still better? (obviously Anamorphic is best, but we don't have that option).
Barry Green February 8th, 2005 10:44 PM
Letterbox would be preferable to squeeze for a film transfer, yes.
Peter Jefferson February 12th, 2005 08:08 PM
if your going to letterbox, i would suggest doing it in post.. this will at least give u 20 odd % more framing, so u can correct or adjust framing in post if need be.
another thing, if u run 4:3 in a Vegas 16:9 project, it will NOT strecth your footage, instead, you can go into the pan crop of the clip and select 16:9. All it will do is CROP the tops and bottoms off.. it will not stretch your footage
I had to return my anamorphic lense due to the plastic securing thread being so damn plasticcy, that i knew it would be a continuing problem. I do all my 16:9 work in post now.. i shoot 4:3, wack on a 16:9 project and adjust the pan crop to fit 16:9, and THEN i change the aspect OF THE ACTUAL PHYSICAL CLIP to 16:9
I lose no resolution by doing this, apart from gettin the tops and bottoms chopped.. which im ok with anyway.. btu tahts vgas.. i dont know what u use..
Daniel Hollister March 27th, 2005 03:00 AM
I recommend using a matte in post. That way you don't see it stretched when previewing your video, and you don't have to flag it as anamorphic.
However, just a little advice in regards to the anamorphic - get it. Get it if you can afford it. Trust me.
The difference on paper doesn't seem like a lot to people. Some minor increase in resolution. But the difference when it's being displayed at full-quality on a television is really what matters - and I'm telling you from experience, it's amazing.
I've always watched my projects on a 54" HDTV. It's fairly easy to see grain or pixellation on that thing.
Without the anamorphic, the DVX is sharp, but it's not like razor-sharp. You can still tell it was shot DV, see some artifacts or graininess every now and then.
With the anamorphic lens, the footage looks RAZOR SHARP. The difference is huge, it's actually VERY noticable. I'm very glad I bought it.
Just my $.02, of course.
Jim McQuaid March 27th, 2005 01:41 PM
16:9 in post
No one mentioned it in this thread but another clear advantage of dong the 16:9 matte in post is that you can adjust the vertical cropping anywhere within the 4:3 image. I have found this invaluable and I like having the option to adjust the framing in post in case I did not exactly nail it in the heat of battle, especially for moving the camera.
Jon Fordham March 27th, 2005 08:29 PM
Well, no one mentioned the clear advantage of lighter compression that is gained by cropping in camera...
I strongly disagree with the practice of "doing it in post"!
Daniel Hollister March 28th, 2005 05:04 AM
Yes, "doing in post" is GENERALLY a bad thing to do, usually due to lower image quality as a result of altering your image.
HOWEVER, this is a case where it actually works the other way around. You add a matte in post, you can take it out. You add it in-camera, you're stuck with it.
Perhaps it's not a choice that will matter too often, but it is nonetheless a choice you have, and doing it in post does not in any way degrade your image quality - but gives you more options. I mean, what if you decided you wanted to crop this wide to 2.35:1 or something? You'd have to go in and do that in post anyway.
Jim McQuaid March 28th, 2005 07:54 AM
16:9 in post
I honestly have no idea what John was referring to with "the clear advantage of lighter compression." So let me explain what I think and you can educate me.
First of all, I am only looking at the miniDV result from the DVX. I'm not trying to make any general statements about other tools and processes, how it should work in HD or going to film.
Second of all, I'm only thinking of the standard camera setup, not the anamorphic adapter.
Within these limits, it seems to me that with most miniDV cameras and with the DVX, you can choose to lose resolution in horizontal or vertical by cropping or stretching. There are still only so many pixels to go around. And if I'm going to end up discarding (or interpolating) some pixels in the process to achieve the 16:9 ratio, I'd rather do it in a way that provides the greatest freedom for making choices (and undoing them if necessary).
That's why matting in post appears to be the best choice.
John McManimie March 28th, 2005 02:52 PM
I think what Jon Fordham is referring to is the 5:1 compression of DV. When you crop 4x3 video you are throwing away pixels AFTER the 5:1 compression stage so that 1/4 of the data space on the tape is unused. While the same number of pixels from the CCD end up in the frame, shooting 16x9 in camera allows those pixels to be interpolated across a much greater data space and should result in a better image. Of course, it might depend on your target - 16x9 or 4x3. If 16x9 TV is the target, I would think that in-camera cropping would be the better choice (from a quality standpoint --- you do, of course, lose the abilty to do things like re-framing).
Jon Fordham March 29th, 2005 01:45 PM
Jim,
John is correct. By eliminating the top and bottom areas of the image that are going to be cropped out in camera, the compression can focus on only the area of the picture that matters. Thus you get lighter, better compression which results in a noticeably superior picture.
I never have understood the idea of "undoing" or re-framing compositions. And I've never understood the fear of being "stuck with" a composition. I've met plenty of so called directors who can't make a decision to save their life. But I've never met a shooter that was too indecisive to figure out how he wanted to frame a shot.
If it's freedom you're worried about, consider that by achieving an image with lighter compression you'll have better source material to stretch and manipulate. Like you said, it's being discarded anyway. So throw them out to start with so that you have better material to manipulate.
Daniel,
If you're interested in doing 2:35, then the DVX with Anamorphic adapter can do it. By using the anamorphic lens AND the in camera letterbox on the DVX100, you'll get a 2:35 image when viewed on a 16/9 monitor or leterboxed on 4/3. If you have the DVX100A, you could also use the in camera squeeze with the anamorphic lens to achieve 2:35. With the squeeze mode you'll have to "double" the letterboxing in post.
