-   Panasonic LUMIX S / G / GF / GH / GX Series (https://www.dvinfo.net/forum/panasonic-lumix-s-g-gf-gh-gx-series/)
-   -   GH2 40fps @ 4MP continuous ? (https://www.dvinfo.net/forum/panasonic-lumix-s-g-gf-gh-gx-series/485235-gh2-40fps-4mp-continuous.html)
Luke Tingle September 24th, 2010 01:54 PM
I've read on multiple sites (most having conflicting GH2 specs) that the new GH2 will shoot 40fps continuous at 4 megapixels. Does anyone know if this is confirmed.
Sounds too good to be true. I really hope it's true though, 4k image sequences realtime, forget about video codecs! I'm probably just dreaming though.
Les Wilson September 28th, 2010 06:33 AM
From the Panasonic website:
http://www2.panasonic.com/consumer-e...702#tabsection
Burst Speed SH: 40 frames/sec(4M), H: 5 frames/sec, M: 3 frames/sec (with Live View), L: 2 frames/sec (with Live View)
BURST SHOOTING: Number of recordable images 7 images (when there are RAW files with the particular speed)
Unlimited consecutive shooting (when there are no RAW files)
(depending on memory card size, battery power, picture size, and compression)
Luke Tingle September 28th, 2010 08:57 PM
Yes, I read those specs, hopefully consecutive really means unlimited. After further reading I found another panasonic spec sheet that states it's actually 3Mp @ 16:9, this equates to a 2k resolution.
Also live view is supposed to stay on during burst shooting. 2k at 40fps (24p after post) would be excellent unless I'm missing something. AVCHD mush and maybe aliasing would be less of an issue.
Andrew Hood September 29th, 2010 04:21 AM
Apparently the rolling shutter is very noticeable at this res and FPS. So probably good for slow moving things, fairly static shots, but not panning or motion.
But hopefully a good sign for where things will go with future generations.
Dave Eaton September 29th, 2010 05:20 PM
Keep in mind that no footage or tests to date are on production models.
Mike McKay September 29th, 2010 07:20 PM
Here you go:
YouTube - Photokina 2010: Panasonic DMC-GH2 2/2
Luke Tingle September 29th, 2010 08:15 PM
thanks, I knew it was too good to be true. The camera stopped exactly at 40 frames, useless... My interest in this camera just went even farther down.
Panagiotis Raris September 30th, 2010 12:34 AM
from what i read, it only shoots 40FPS for 1 second maximum at 4K. ill try to find the link.
