GH3: best option for XLR audio inputs?
What do you recommend as an XLR input adjunct for the GH3? I know there is the DMW-YAGH for the GH4, but I don't think it works with the GH3 (?)
Re: GH3: best option for XLR audio inputs?
What about the Beachtek units Bill?? They are nicely made and you can get models that go under the camera like the Panasonic unit or ones that clip on the hotshoe and also give you extra accessory mount points
B&H have a nice selection |
I have the dr60 which can send recorded audio into a camera and record at the same time to it's own sd card as well, the quality that goes into the camera is not as good as what is directly recorded onto the tascam though. I think the dr70 does the same but is much less bulky then the dr60.
The DMW-YAGH should have worked on it's own internal batteries to be any success but it doesn't, you need a external powersource for it to function and I"m not sure if it will work on the gh3, I just saw that it has come down in price from 2000 dollar to 500 now in just one year, I"m sure they had to do that because it didn't sell well. If you only need XLR connectivity then a simple beachtek will do just fine. |
Here's a vote for the Tascam. It works. Is cheaper than the correct Beachtek (the cheaper models don't work well with the AGC of the GH3). And it records. Given the state of audio electronics these days, Beachtek is oddly producing expensive, out of date hardware that work well with camcorders but not with many DSLRs. I use the Tascam and it's a great unit.
sound devices mix pre-d and keep audio levels at minimum i.e.1 in order to reduce negate agc
It seems that the DR70 has only two outputs, a headphone and a line out. The DR60 has three outputs, two line outs at difference impedances and a headphone out. I have this model and with a Sescom line splitter I can send the audio to two cameras.
The DR70 is interesting in that it has built-in microphones that I would assume are a decent step up from the camera microphones. |
If you don't mind a little soldering there's always the Irig pre hack.
I used to mount my Zoom H1 on my GH1 and run the line out into the mic jack, when I upgraded to the GH4 I also got the H5, I can do the same thing, requires a ring to work properly, but its the cheaper solution for me.
Hi there
I've been using the Juiced link Riggy-Micro RM 202 on my Canon EOS 60d and it really is very good. Small light (smaller than the Beachtek) with good clean audio... I read before buying the audio was better too. Check out this review on DSLR Video shooter site..: This then would work great with a GH3. cheers Gareth |
i've been happy with the tascam 70d, i don't typically use it with the gh3 but the nice thing is that it has those extra inputs in case you need them.
| All times are GMT -6. The time now is 08:05 AM. |
