-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   has anyone put together HPX and Brevis? (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/107253-has-anyone-put-together-hpx-brevis.html)
Kaku Ito November 5th, 2007 06:15 AM
Me and my friend is thinking about getting Brevis35 for HPX and HVX.
What is the best possible way to setup Brevis35 with HPX?
Is there a way to connect Brevis35 directly to the bayonet mount of the HPX?
Dean Harrington November 5th, 2007 07:18 AM
Dennis Wood ...
Kaku I think it's a good idea and you would need to talk to Dennis Wood over at Brevis. There is an Oct. 19 mount for Lomo's on the Brevis so it's very likely some other set-ups are available.
Kaku Ito November 5th, 2007 07:32 AM
Hi Dean,
I just found out they are working on relay lens.
By the way, I have lots of tickets to InterBEE.
Dean Harrington November 5th, 2007 07:44 AM
interBee ...
How about I drop by and pick one up?
Kaku Ito November 5th, 2007 07:50 AM
I can give you a couple.
Dean Harrington November 5th, 2007 08:06 AM
sounds good ...
popped you an email.
Kaku Ito November 15th, 2007 03:10 AM
I'm getting the Brevis anyway, I will use it mainly with HVX200 but I could put it on HPX555 if I wanted to since it attaches with 82mm adapter ring.
I also purchased the step down ring for HV20, too. It should be interesting.
Dean Harrington November 15th, 2007 03:25 AM
good idea ...
I've been thinking the same thing for some time.
Leonard Levy November 15th, 2007 12:29 PM
I've tried to make it work on a 2/3" chip and it can't achieve decent focus.
That's probably why they're working on a relay lens. Maybe if you had some kind of specialty lens other than the standar zooms it might be achievable but I don't know.
Jon Wolding November 16th, 2007 01:33 AM
Philip Bloom got the Brevis working with his XDcam. But the point of the relay would be to avoid the cumbersome bazooka look.
Kaku Ito November 16th, 2007 03:45 AM
Leonard,
I just put it on to HPX555 and found out what you are talking about.
I will just use it with HVX and HV20 for now.
Me and my business partner are talking about negotiating with companies like Zuno to make a relay lens.
Jon Wolding November 16th, 2007 12:41 PM
Zuno? I couldn't find anything on a lens manufacturer associated with that name.
Kaku Ito November 16th, 2007 02:32 PM
Jon, zuno is the manufacturer.
Barry Green November 19th, 2007 12:31 AM
I believe Letus is planning on making a relay lens for the HPX500 to the Letus Extreme; perhaps the same relay would work for a Brevis or other adapter...
John C. Butler November 19th, 2007 11:17 AM
I don't see why you would really need one as 2/3" CCD's provide decent DOF on their own.
Kaku Ito November 19th, 2007 11:18 AM
Barry, thank you for the information.
By the way, I just came back from setting up for InterBEE and I passed by at panasonic and didn't look like they had anything for HVX200a.
Barry Green November 19th, 2007 10:00 PM
We just shot two short films back-to-back, one on the HPX500 and the other on an HVX200 with a Letus Extreme. Yes you can get beautiful shallow DOF on a 2/3" camera, but nothing like what you can get with a proper 35mm adapter. 2/3" matches the DOF of 16mm film, but doesn't match what you can get from 35mm film.
Noel Evans November 20th, 2007 01:56 AM
And to add to Barrys response. It enables you to use a cheap prime lens.
Seth Melnick November 20th, 2007 01:51 PM
Yes - being able to use an old set of nikons on my HPX500 would be simply lovely
Kaku Ito December 1st, 2007 07:35 AM
Since I started off with Pentax M42 lenses (because I have few lying around), I'm searching more on net auctions.
I guess M42 mount lenses are not that popular (?), they are cheap!
So, far I have 85mm, 55mm (F1.4) and bidding 200mm and 29mm at this point. Does anybody have good recommendation to buy?
One draw back is M42 won't offer as much variations as Nikon lenses, I guess.
Kaku Ito December 1st, 2007 08:20 AM
By the way, to make Brevis work with HPX and Fujinon lens, will the extension tube make it to be able to focus?
Jon Wolding December 2nd, 2007 01:31 PM
You'll probably only need the achromat and maybe one spacer ring.
Kaku Ito December 3rd, 2007 02:21 AM
I will try the spacer ring. Thanks.
Kaku Ito December 9th, 2007 10:51 PM
It was the same on EX1, too, I guess the acromat is too thick instead of needing a spacer.
Or does the spacer go to the 35mm lens side?
Kaku Ito December 13th, 2007 09:51 AM
I put the extra achromat ring and another filter thick spacer and now HPX works fine. The whole length is crazy though, wonder how it is going to be with the flip unit, it makes it even longer!
