oops :)
I also forgot Bluefish4:4:4 too. Their cards also directly support input and output of DPX files. |
Jason, thanks for the response.
"In the case of the Kinetta, Drake, Obin's camera, etc., though, the files are already digitized on the hard-drive of these cameras, so you don't have to worry about that. The only issue is to have them in a Quicktime or AVI file format that can support 10-bit or greater RGB 4:4:4." That is the part where I really get lost. If I were to use one of those cameras, I wind up with a hard drive with 10bit log files on it. What do I use to then transcode those log files into an AVI or Quicktime format which I can edit in FCP or Avid? Once they are transcoded, is there any need to go back to those log files for an 'online,' or are my Quicktimes treated as the 'masters' from that point on (for color correction, etc)? I'm just trying to understand the workflow, before I find myself in a position where I may have to use it. Thanks. |
In the case of Drake and Obin's camera there should be software with the
camera that facilities transforming the original files to other file formats etc. From what I understand the Drake camera is still 8 bit though... Just a higher resolution / uncompressed (not sure if it is "true" uncompressed with Drake). |
Thanks for the reply Rob.
I also found out in the meantime, according to a friend of mine, that AE can read DPX files...which means in theory I guess you could use AE to render out Quicktimes (although that would be pretty time intensive). |
| All times are GMT -6. The time now is 06:39 PM. |
