To all the engineers out there!
Will you please create a device to connect a P2 port to any other computer via US2 or firewire? I don't want to buy that expensive hard disk from Panasonic, and my laptop has no PCMCIA slot!
-EDWIN |
Yeah, no engineering needed. Just plug thr camera in to the laptop via Firewire, and you can record full HD for as long as you'r laptop's hard disk(s) will allow.
Yes, and there are also cheap PCMCIA-to-USB2 adapters that would work as well. Have no fear, there will be many ways to get at the footage!
Still Unsuccesful!
Please, what will be affordable options (beside the camera itself) to plug my P2 cards to my ibook, emacs, imacs, etc?
All PCMCIA drives for desktop I found are all for PCs. |
Hoping for some clarification here. -gb- |
That was actually one of the big pushes for Panny's cheaper DVCPRO HD deck... that it would ingest through firewire... "JUST LIKE DV!" I actually don't know if that's an actual quote... that's just what I remember people saying about it when it came out. Oh how wrong they are... Nothing will ever be "Just Like DV"... it only gets more confusing and convoluted.
You can absolutely record straight to a laptop via Firewire. Everything from DV to DVCPro50 to DVCProHD 720p or 1080/60i/24p/30p. Firewire has 4 times the bandwidth needed for full HD.
To Edwin- Why bother with a PCMCIA slot on your laptop or desktop? You don't even need to remove the P2 cards from the camera! Just run a cable from the camera to the computer and download the footage from the p2 cards directly. If you're using a Mac, use the Firewire cable. If you're using a PC, use the USB2 cable. The P2 card(s) will show up on the computer as an external hard disk. Just transfer the clips from the HVX to the built-in hard disk, and you're good to go. |
-gb- |
Can the files on a P2 be accessed while the camera is recording on the other card? |
I think you would hit the hard disk's sustained transfer rate limit before saturating the Firewire connection.
Transferring DVCPRO-HD over HD-SDI would gain you nothing vs. transferring it over firewire. But DVCPRO-HD is the only high-def format that has been integrated with firewire (well, HDV obviously, but I'm talking among the established pro formats). No other HD format uses it -- HDCAM, HDCAM SR, D5, etc. You'd need HD-SDI capture boards to capture the other formats, but DVCPRO-HD can work with a regular $29 OHCI firewire card, to a regular 5400 RPM hard disk. |
Barry--Regarding Firewire output of DVCProHD in FCP, I had heard that there was a "recompression" of effects and the image when this happened, and that it was more desirable to go out HD SDI. Is this true?
Also, if editing HD in FCP, what are the options for real-time monitoring on a professional HD monitor (not the computer monitor). Is it necessary to have a separate card to do this? Thanks! Peter |
Thanks Barry. I think the effects or color corrected shots are specifically what I'd heard there would be recompression of, and this seems to be backed up by your post. How bad is this compression? Does anyone know? The idea of editing on a new Intel Powerbook and going straight out of FW800 to a deck is soooooo appealing, would be a shame if the image was seriously compromised.
Peter |
However, it's not really nearly as relevant as it once was -- we used to recompress and go out on DV tape, but in HD I suspect we're going to see acquisition and mastering being done in different codecs -- i.e., acquire in DVCPRO-HD, distribute in WMV9 or H.264 or MPEG-2, etc. So the recompression issue pretty much goes away, as you won't be often recompressing back to the acquisition codec. Quote:
| All times are GMT -6. The time now is 05:54 AM. |
