-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   Huge problem! Need some help! (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/67125-huge-problem-need-some-help.html)
Geoff Brennan May 11th, 2006 08:06 AM
Hi there,
I work for a large television station in Toronto and we have recently switched over to P2 software and DVDPRO cameras. The problem I have is that the P2 Viewer/software gets interrupted when i attempt to install it onto my PC. Has this happened to anybody else? How can this be fixed? I have had a gentleman from Panasonic come in and says it is not the program, or the drive, both of which are working. The P2 drive can be read, MXF files can be taken over to my HD, but without the P2 viewer I can't format the P2 Cards! Please, help!
Geoff Brennan
Hans Damkoehler May 11th, 2006 05:46 PM
Could you clarify?
Originally Posted by Geoff Brennan
The problem I have is that the P2 Viewer/software gets interrupted when i attempt to install it onto my PC .... but without the P2 viewer I can't format the P2 Cards! Please, help!
Geoff,
Just trying to clarify here ... are you saying that the software fails to install? I assume the Panasonic rep has connected you with a new install CD?
If you just need to format the P2 cards you can do that within the camera (I think you have one from what I gather in your post) by switching modes on the back of the HVX.
Could you help clarify your question ... that may get you some more replies.
Geoff Brennan May 15th, 2006 07:58 AM
thanks for the info. I have spoken to the rep from Panasonic and he says that he thinks the problem is that i am running a 64-bit comp while the P2 viewer is believed to only work on a comp as high as 32-bit. anybody else have this prob?
Jason Boyce May 15th, 2006 12:47 PM
Put in a 32bit comp to format P2 cards? If that's all you need it for, a small machine and a KVM switch wouldn't take up much room.
