-   Panasonic P2HD / DVCPRO HD Camcorders (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/)
-   -   HVX time lapse test (https://www.dvinfo.net/forum/panasonic-p2hd-dvcpro-hd-camcorders/69333-hvx-time-lapse-test.html)
Dean Sensui June 11th, 2006 01:34 PM
HVX time lapse test
Did a couple of time lapse sequences as a test.
One is from Point Panic outside of Kewalo Basin, looking toward Diamond Head. The other is from Kawaikui Beach Park looking out toward Maunalua Bay.
http://www.hawaiigoesfishing.com/videos/timelapse.mov
Quicktime files, H.264 codec.
Rob McCardle June 11th, 2006 02:31 PM
Looking good, Dean !
How were you controlling the cam - built in timer or software ?
Stormy and raining here today - that footage makes me feel like jumping on the first plane outta here !
cheers
Dean Sensui June 11th, 2006 03:47 PM
Hi Rob...
The camera has a built-in intervalometer. Sure beats using an external controller, having to connect it to a laptop, etc. So it's very portable and easily set up. You can specify the interval from an easily accessed menu.
I'm still learning about the various settings on this thing. It certainly provides some good-looking source footage!
Rob McCardle June 11th, 2006 04:04 PM
Thanks, Dean.
Does the camera fire a burst (like most of the sd tape cams do) or does it actually record single frames ?
I would guess it does single frames with p2, but ... ?
tia, r
Dean Sensui June 11th, 2006 04:11 PM
[QUOTE=Rob McCardle]Thanks, Dean.
Does the camera fire a burst (like most of the sd tape cams do) or does it actually record single frames ?/QUOTE]
That's what I like about this thing: it's shooting single frames instead of bursts. So no need to go through a clip to winnow out individual frames for a time lapse sequence.
I'm thinking of setting up some sort of clock drive to allow panning while shooting a time lapse. But the clock drive has to be variable.
Rob McCardle June 11th, 2006 08:28 PM
Thanks for that, Dean. Very cool.
Just another nifty feature on this camera.
cheers, r
Chris Boyes June 12th, 2006 07:39 AM
Higher Res?
Hey Dean...
Shots look really great. I'm trying to prove to those with the funds that they should buy me this camera. I'm building up a shots library to show how awesome the camera is. Would you mind posting a high-res version of your clip?
Chris Boyes
Robert Lane June 12th, 2006 08:13 AM
Dean,
What was the rate of single-frame capture?
