-   Photo for HD Video (D-SLR and others) (https://www.dvinfo.net/forum/photo-hd-video-d-slr-others/)
-   -   Why is 24mm, the 35mm equivalent of 4.3 on 1/2.3 sensor? (https://www.dvinfo.net/forum/photo-hd-video-d-slr-others/495903-why-24mm-35mm-equivalent-4-3-1-2-3-sensor.html)
Roberto Lanczos May 14th, 2011 05:35 PM
i'm a little confused here...
I'm going to take a P&S Canon powershot as an example to illustrate my confusion.
IXUS 220 HS
Sensor: 1/2.3" CMOS
Lens: EFL: 4.3-21.5mm (35mm equivalent: 24-120mm)
Now, if a 50mm lens equals 80mm on APS-C 1.6 sensor.
then why a 4.3mm lens equals 24mm on a 1/2.3 sensor,
and not 9.89, if 4.3 x 2.3 = 9.89 ?.
There's something i don't quite understand yet.
Could someone explain this for me?.
Thank you
John Wiley May 14th, 2011 09:10 PM
Re: Why is 24mm, the 35mm equivalent of 4.3 on 1/2.3 sensor?
Because in your equation you've mixed up sensor size and crop factor. You've inserted the sensor's diagonal measurement rather than the crop factor for a sensor of that particular size. The math you've used would only be accurate if a 35mm sensor was equal in size to a 1" sensor, which it is clearly not.
As sensor size decreases crop factor increases. I'm not sure how to figure out the crop factor for a sensor of any particular size compared to 35mm, though using the stats provided I would say that 1/2.3" sensor has a crop factor of about 5.58 (24/4.3=5.58 to the nearest 100th).
Vincent Oliver May 15th, 2011 01:51 AM
Lets not forget that a 24mm lens is still a 24mm lens regardless of which sensor size your camera uses. The camera is just applying a crop factor to the lens which in turn gives it the same angle of coverage as say a 36mm lens (using 1.5X ratio).
