NEX + speedbooster + Sigma 18-35mm f1.8?
Hi guys,
I know that the nex Sigma 18-35mm f1.8 is not designed for full frame. I´m guessing this is probably because it won´t cover the entire frame, but do you guys think it would work on a NEX camera with the Metabones Speedbooster? I mean, the NEX sensor APS-C, even if the speedbooster "turns it into a FF". If this works it could be an unbelievable combo. Plus you could use it with the speedbooster for wider shots and then use it with a regular adapter for longer shots. |
Re: NEX + speedbooster + Sigma 18-35mm f1.8?
Speedbooster only works with full frame lenses.....so nope, won't work.
That is too bad, it could be an incredible combo.
| All times are GMT -6. The time now is 08:18 AM. |
