6400k
I just ordered twp 6400K flourescent soft boxes for corporate work. From my understanding these simulate daylight or overcast light with a blueish hue. I hope I didn't make a mistake, as I also want to bring out beautiful skin tones. Should I try to balance the two by white-balancing with a light blue card?
Good GRACIOUS! 6400?? i hope you don't have to match to any other lights!
Generally, I try to buy lights in the 3200-3500k range to match tungstens, or in the 5600k range to match daylight. 6500k might match northern dawnlight in the winter... That's REALLY blue. I'm going to bet you'll be buying other tubes or looking to gel those lights with some CTO or bastard amber or straw to get them back down a bit. Skin tones took fine with most light as long as it's full spectrum. What daylight balanced light tends to do is help the camera be more noise free since most cameras seem to be balanced to daylight. I know when I have something critical to shoot, I am trying to shoot at or near 5600k as much as possible. I love the color I get with that. |
Should I draw that blue out with a light blue card, or should I swap the bulbs for warmer shots? I'll often be using these outdoors in twilight shots, but I want to do warm shots as well.
6400K could be very useful as cloudy or shade light is often equal to or above that. Many cameras use 6300 as their outdoor preset. Differences in color temperature at the blue end of the scale are often not as significant to matching as at the red end of the scale where small differences are pretty noticeable. Definitely plan on having different levels of CTO to make the lights warmer. I usually like to balance my cameras color temperature a little higher than the lights color temperature so the light looks warmer
After you use them a bit you will probably figure out whether you want different bulbs or gels to get the results you want |
That's pretty blue. Most daylight fluorescent bulbs like those sold for Lowel's Caselights and Kino Flos are 5500K. However, I actually ran across an office with incredibly blue fluorescents that checked out almost 7000K on my color temperature meter. So if you run into something like that, the bluer bulbs would be useful. I think that would be rare, and if I were you I'd get 5500K bulbs.
Exactly. There might be a place for 6500k bulbs, but I'd think it would be the exception rather than the rule. Kino's, Caselights, HMIs, etc., are all coming in around 5500-5600k. Most of the Fluo's I run into are around 4200K.
The good news is that it should be easy to get bulbs that color balance for 32k and 56k for your setup. You will need replcement bulbs anyway.
Just speculating. -gb- |
Hi Greg,
No actually the answer is much simpler than that. 6400K is the standard for daylight in regular commercial lighting around much of the world and especially China where all those bulbs are made these days. Regardless of CRI, most of the bulbs you find on the commercial market are either 2900K (commercial "warm white") or 6400K (commercial daylight) unless you custom order another color temperature and can make a huge order for thousands. So, whoever made that softbox just (probably) bought the default bulbs because they were less expensive and easier to find. I say probably because it could have been a willful decision but I can't think why you would offer 6400K when you know its not the photographic standard for daylight. It is interesting to note though that Osram standardized on 6000K for most all HMI bulbs they make. Philips and GE and most other HMI clone makers followed suit. So for some reason, perhaps related to fighting daylight (the slight extra blue would really help in punching through normal daylight), they standardized on something a bit higher than our normal camera 5600K settings that our equipment all is calibrated to. |
Makes sense to me and thanks for the additional info. BTW, you had two virtually identical posts show up so I deleted one of them.
-gb- |
Thanks guys.
Just received them. These suckers are insanely blue. I have a reflector with a gold option that warms up the reflection and I have a boom stand on order for the hair light. Solutions: 1. Plan on white-balancing to blue rather than white and buy only a slightly warmer hair light. 2. Buy a very warm hair light and use the gold reflector to balance the shot, white-balancing to white. 3. Spend $160 for 5500k replacements. Also, thoughts on the hair light? |
Easiest thing to do is buy replacement bulbs. Or, you could try some 1/4 or 1/8 CTO gels. That would be the cheapest way to go.
Hey, question: The two soft boxes are 18x32. I plan on using them side to side, with the reflector on the other side and a hairlight on a boom overhead (haven't bought).
The soft box bulbs are 125 watts, 110v, 6400k. What if I replaced just one of the bulbs with a 105 watt 4100K? Would that balance things out or create a confusing read? I could use the warm on for the face shots? |
I have a friend who has mixed daylight and tungsten bulbs half-and-half in Caselights for a result that's somewhere between 3200K and 5500K.
I'd love to see their work if you have a link.
Interesting. I thought it would be a better light for outdoors because of the blue. I plan on using it in a room without windows or any ambient light.
We used them today and they seemed a bit weak. The two combined are 1250watts. If I kept them, what hair light color would you recommend. Should I look for one with a dimmer? |
you really dont' want to mix color temps in one fixture. you'll see both colors ! not unless you put full diffusion on it to unify the light. however that still results in some loss. with bare bulbs and you'll see both and its ugly.
6500K + 1/4 CTO will get you to 5600K or so. what I have found is that 5600K+ bulbs are brighter then 3200K bulbs so adding some CTO should not be a problem. these days I shoot more 5600K because its easier - ok I've got HMI's and 5600K flo's, but even just full CTB on 1K tungsten works within reason. |
Thank you Steve,
I think you're onto something - especially since it will save me some money! It seems silly to have a white diffuser and buy a different bulb since I need to change the color anyway. (Truth be known, I didn't know what a CTO was). You mentioned a 1/4 CTO. What color should I get it in? I found a bunch of options at Color Correction Gel Sheets - CinemaGadgets.com. Thoughts? You guys are great! |
CTO is the color. Go to the Lee Filters site. Any pro equipment supply house will carry them, and most theatrical supply houses too.
Dup post, sorry all.
Just so you can be confident about what you're asking for... CTO is industry shorthand for Color Temperature Orange - the gel with a die profile that filters blue spectrum OUT of light passing through it. CTB is Color Temperature Blue - the gel die color profile that filters wavelengths that represent the orange part of the visible spectrum out of light passing through it. The key is that both these filters REMOVE part of the spectrum of light, so the more die used, the less overall light transmission you can expect. More gel equals less light all other things being equal. So it's important to understand that adding gels makes any light LESS efficient at throwing photons toward your scene. Same with diffusion. Spreading light across a surface diffuses it equally across the whole visible spectrum, but also impedes it. So using gels and difussion is necessarily is a balancing act. You need enough light origination so that when you subtract spectrum with your gels, you still have enough of the light you DO want to achieve the illumination you need. FWIW. |
I've seen the light. That's great info. Thanks.
| All times are GMT -6. The time now is 03:36 AM. |
