-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   Nightime outdoors - "pink" tinted street lights... (https://www.dvinfo.net/forum/photon-management/33661-nightime-outdoors-pink-tinted-street-lights.html)
Matthew de Jongh October 19th, 2004 04:58 AM
ok i am doing a short that is 50% night exteriors in a small city.
the street lights area a light pink color.
i'm having a hard time making the pinkish ting go away, suggestions?
i'm using a dvx-100a if it helps, the existing light is pretty consistent the pink street lights + very white lighting from the storefront windows.
the pink background streetlights are ruing an otherwise very pretty shot of the dark downtown backgrounds.
matthew
Stephen Schleicher October 19th, 2004 07:35 AM
well you could white balance under the pink lights, of course that will have the effect of turning your subjects green-ish...
What is wrong with pink light? Can you not hide the lights by selective composition and then use the lights to rim your subject or light your BG?
Last resort - ask the city to shut the lights off for 10 minutes while you get your shot???
Cheers
Matthew de Jongh October 19th, 2004 11:05 AM
the problem with the pink lights is that they are so powerful that it colors the entire area around them for at least 100-150 feet.
if the lights were off main st. in northampton mass would be a little bit dangerous, even at 2am there is a bit of pedestrian traffic and it is a town where there are no lights on main st. and pedestrians absolutely have the right of way.
i'll have to play with some more white balance tricks.
i was hoping there was something i was missing.
matthew
Charles Papert October 19th, 2004 06:18 PM
Matthew, from the times I shot night exteriors in Northampton, I don't recall the streetlights being a problem, but I didn't rely on them as my source of illumination. It's better to use tungsten lighting units and allow the background to go warm (I think of them as being more orange than pink).
Someday I'll have to post the music video I shot about 10 years ago at the old Bay State bar on Pearl St., we had about a hundred people dancing on the street outside right around 2 a.m... (the band was the Big Bad Bollocks, I think they still play around there).
Matthew de Jongh October 19th, 2004 08:44 PM
i am using some lighting on camera, it is supposed to be a dark thrilled type thing, the weird thing is that the pink street light light seems to carry forever and it paints the street so to speak for a couple hundred feet from each light.
its raining a lot up here right now but when it stops i'm going to go back up for another night and try some more things.
the biggest problem is that i only have limited power to run lights...
matthew
Charles Papert October 19th, 2004 09:07 PM
Thrilled...you mean thriller, right?!
Sounds like you don't want on-camera lighting if you want a low-key look.
Now, for years folks have dreamed of not having to spend hours lighting night exteriors to get them to expose with any detail...sounds like you are frustrated by having this be the case?!
I think if the pink color is an issue for you, the best bet is to cheat the white balance as Stephen suggested. White balance under the streetlights, then you'll need to experiment with gels on your lights to get the color neutral. Your best bet is to get a lighting swatchbook with samples of all the color correction gels, and shoot some tests. Here's one way to do it: head down to Noho and do the white balance, then scoot home (rt. 47?) and set up your camera with a monitor, then hold a selection of gels in front of the lens. Whichever makes the image look "right" will be the one you need to buy a few sheets of to place in front of whatever lights you will be using for the shoot.
Yeah, it's raining in LA too, big old storm. Last time I came to Northampton was exactly two years ago: tried to hit it during foliage season, but it rained the two nights I was in town. Oh well.
Matthew de Jongh October 19th, 2004 10:23 PM
thanks for the suggestions.
i keep meaning to get one of those swatch books, i have a sample of gels from NRG 12"x12"
i am planning on bringing my sony 14" ntsc monitor and a ups and run that in the back of the jeep to see what it really looks like.
the thing is the stores are lit so well at night that it is almost too bright!
the things i'm trying to light are the one actor and a car that is following him when it goes down some alleyways etc.
sort of a christine like movie but much more thinking less blood and cliched.
so far the lighting is just a mini-frezzi on the camera and i have another one that i can use with a battery to highlight specific scenes.
matthew
Matthew de Jongh October 20th, 2004 12:04 AM
ok i am kind of embarassed to post this link...
keep in mind, this is just a VERY rough test, we did it in less than an hour, it was basically a lighting test and a location scout that we ended up editing.
think of it as 1/4 of a storyboard that was done with a video camera.
just trying to get a handle on what shooting at night is like in a variety of light and locations.
http://www.cluelessandlark.org/scary...hase-small.wmv
and later on there will be a
http://www.cluelessandlark.org/scary...ase-medium.wmv
matthew
Charles Papert October 20th, 2004 02:15 AM
Matthew:
Looking good!
I would repeat what I mentioned earlier: ditch the on-camera light. If you can figure out a way to power it separately from the camera, do so--but just don't light from on or directly behind the camera, it's a cheesy TV news-look. For atmospheric night lighting, use a half-light from the side or backlight from the rear, and if you need to see facial details or into eyes, go ahead and use some front fill but make sure that it is 1-2 stops under key (i.e. underexposed) to look natural. But in general, you don't want your actor walking towards camera and getting brighter as he goes.
For the car down the alley shot (as soon as you said "alley" I figured you'd be using that one by the Haymarket!), have a backlight playing on the wall of the alley. For the angle you chose with the car roaring after him, I'd place it just out of camera range down low and to the right (near Starbucks, yeah? You can see I'm having fun with Northampton nostalgia, forgive me!) This will pick up some nice sparkles and texture on the brick walls, and make ominous shadows.
Personally, I think the city looks natural in the background with the sodium vapor street lights--I wouldn't worry about correcting them out. I'd just warm up your film lights a bit (maybe 1/2 CTO) and then color correct the whole thing a bit bluer, to taste.
I don't know if you had this planned, but in terms of your actual shots, I'm seeing a great moment with a closeup of the car's headlights as it plays across the parking meters etc.--very interesting shadow and light action. It happened in several of the wide shots. As a closeup, it would make a nice insert into the sequence, adding tension.
Rob Lohman October 20th, 2004 05:35 AM
One other thing to add: if the color is really bugging you in the
end and you can't get rid of it while shooting you might be able
to fix it with color correction in post (make sure you do lots of
good tests with this if you want to go down this road).
With an NLE like Vegas/Premiere Pro you might be able to change
just this color without effecting other colors (with enough time
and work from you).
Stephen Schleicher October 20th, 2004 06:49 AM
I agree with everything Charles said. The test shoots look great so far, I like the sodium coloring of the background. I do not like the light mounted on camera effect.
For the most part the "natural" light in the environment should be enough light your scene quite well. If you need additional lighting for the dark alley, you might want to place your light(s) above and out of frame to simulate alley door lights. I think using a blue gel might give you a pleasing mix with the orange/pink lights from behind.
Cheers
Matthew de Jongh October 20th, 2004 06:54 PM
thanks for all the feedback...
the camera light is not locked to the camera, the battery is external and i have two of them, so putting them somewhere else wouldn't be a problem.
when you mentioned putting the light across the alley from the car, do you mean so that the light hits the brick wall corssing the path of the car when it comes down the alley?
i love the idea of the closeup of the parking meters, i had something in mind in the way of a closeup/parking meters, but what direction did you see that shot coming from as far as camera placement/direction of car and light placement?
thanks for all these tips, i'm leaning a lot!
this is my first attempt at any artificial lighting. everything else i have done has been either documentaries, or one short that was shot documentary style. all very run and gun.
matthew
Charles Papert October 20th, 2004 08:57 PM
<,when you mentioned putting the light across the alley from the car, do you mean so that the light hits the brick wall corssing the path of the car when it comes down the alley?>.
yup! having it low will throw the car and the guy's shadow up high across the wall, or if you don't like that, just raise the light up on a stand. You'll likely get a hot kick from the reflection of the light, but by moving it around you'll find a way to bury it. If you really want to go for it, see if you can wet down the walls of the alley!
<<i love the idea of the closeup of the parking meters, i had something in mind in the way of a closeup/parking meters, but what direction did you see that shot coming from as far as camera placement/direction of car and light placement?>>
On your tape at :46 and 1:00, you can see the pattern of the headlights as they move past the meters etc. I'm just suggesting a tighter version of this. You could design a shot that your actor passes through, seeing his feet, and then as he leaves the frame this lighting effect is visible in the background. Or just shoot it separately
Matt Irwin October 21st, 2004 05:51 PM
Matthew,
If the pink/orange sodiums are driving you nuts, I've found that full CTO and full Green in front of a tungsten source will balance pretty close to sudium vapors. Personally, I don't think the streetlights in your footage look that bad at all.
Matthew de Jongh October 21st, 2004 10:12 PM
i guess the biggest problem is that i don't have enough artificial light to cover the areas that are pink.
with the cto and the green that you mention, wouldn't that require throwing enough light to overpower the local lighting?
matthew
Stephen Schleicher October 22nd, 2004 06:35 AM
I believe matt is referring to your portable light kit. Instead of throwing off white light, the correcting gel will make it look more "pink".
Then if you white balance, everything will be white including your sodium vapor lights. You would probably also need to cover the windows of the stores.
I think the concensus among most people that have responded is that you should leave the sodium vapor lights alone. I think they look appropriate for you case scene. You are in a city, people expect there to be street lights and most of us live in cities where we have the orange/pink glow of sodium vapor and have become accustomed to seeing them.
I would focus on lighting your subject with your available light to get your subject lit just the way you want.
To relate a story to you...
Several years ago, I was working on a noir project where the detective was picked up by police while outside at night. Most of the people working on the production thought this would be a tough shoot to do because they were worried about having to rig alot of extra lights. I said "Bah", we'll use natural street lights. By lighting the subject only with sidewalk lamps and overhead streetlights, the shot looked EXCELLENT. The only thing that would have made the shot better would to have watered down the streets to get light reflections.
If you can use colored fills or mount your light kit in places to create pools of light for your subject to run through, then I think you will be fine. The extra background light only adds to the overall look to your piece.
Cheers
Stephen Schleicher
www.mindspring.com/~schleicher
Matt Irwin October 22nd, 2004 11:52 AM
Stephen- I couldn't have said it better myself.
I as well would leave the streetlights off-balance, though it really just depends on the look you want. Your footage is looking good. I would just focus on moving away from the on-camera light. Instead of lighting from the front, light from the side or back. Stephen's suggestion of using pools of light is an excellent call, I've also done stuff like that and have been very pleased.
If you are really pressed for cash and you need a decent soft source for cross key (or whatever), maybe think about halogen work lights (not the best, but very affordable) bounced into a 4x8 of styrofoam. Of course, there are many ways to do just about anything, so just experiment and you'll find a method that works.
Matthew de Jongh October 23rd, 2004 05:53 AM
i actually have a fairly decent assortment of small lights, two lowel lights and two mini frezzi's
i just need to be more creative in how i use them.
using the lowel's in this location is harder because of lack of power but i'm going to try using some large ups's to power the lowel's.
tonight i'm going to go out and try the suggestions out and see what else i can come up with especially in the pools of light department!
the footage i posted was the first artificial lighting i had ever used so i'm still just experimenting.
matthew
Matt Irwin October 23rd, 2004 03:48 PM
I'd like to hear how the UPS works. Just make sure you only turn the lights on while you're rolling though. I know that a car or boat battery with a power inverter works very well. I've run a 400w HMI on a car battery and got about 1 hour total run time.
As far as you lighting technique goes, the best thing to do is experiment and make a lot of mistakes :) It's only uphill from here. Happy shooting!
