Getting an ARRI Fresnel Wet?
I know the title probably strikes fear into everyones heart, but you have no need to worry.
What I got is this. I have a scene for a music video where I'm gonna have a dancer in a shower. The shower has a huge glass wall so you can see into it from the bedroom. We are going to completely fog the glass and I want to shine a back light into the shower. The light WOULD NOT be getting water on it, but it will be getting steamed up. Would any of you recommend a different light for this? Trying to stay cheap. |
You should be okay if keep the light on throughout the filming. The heat from the lamp will evaporate any condensation. However, keep any cabling and connections well away from any water.
We did some night exteriors using Redheads and Blondes while it was raining. I had checked with a gaffer in case this happened and his advice was to keep the lights on all the time, the heat evaporates the rain drops. Hearing from other gaffers, this seems to be common practise. |
We usually use a flexible metal material over lights in the rain, like a very fine mesh--sadly I couldn't tell you where to get it.
I think you should be fine in the shower with just ambient condensation around. Obviously as Brian said, keep the plug connections out of the water, and make sure there is a sandbag on the stand and the light is securely fastened to the stand. |
I guess the mesh breaks up the rain droplets without gathering the water over the lights.
Some gaffers use something they call 'celotex' and the part number is SG-3650. Its not metal, its fiberglass so there aren't worries with heat. You can get it in Chicago at Warp Brothers:
Screen-GlassŪ | Quality Plastic Products | Warp Bros. This can also be used as a scrim too. There may be a metal one too but I don't know about that one. |
I would recommend leaving the light switched on for 15 minutes or so after the moisture source is removed.
Any moisture which has entered the lamphouse, been driven off but recondenses in cooler parts of the lamphouse will hopefully be again driven off completely. Where this recondensation occurrs may be in an electical junction box if a passthrough grommet has deteriorated or if there is none there at all. If in use, the lamp subsequently gives off an electrical smell, it will be time to have the lamp checked. It will be likely a resistive conductive track has grown across between active and neutral at a cable connection point or the end of the cable at the same connection point has deteriorated insulation and a resistive electrical path between the individual wires has developed. Don't flog the lamp on in this state until it fails. There may be evenually occur a smoulder in the cable end which will give off a little smoke, which you may not observe. This may stain and ruin the reflector. Out here, there is a fine stainless mesh which is installed in house foundataions for termite control. It is called "termimesh" here. It might do the same job as Charles suggests. Big builders hardware stores might have it. |
Don't know why this entered my mind, and I don't even know if its relevant - but unless you have an UNUSUALLY large shower stall - with significant distance between the back wall and the dancer - I'm having trouble trying to understand how you're going to get any kind of back or rim light on more than the dancers head.
If you want the effect of a full figure silhouette blacked out - you're going to need a bright background almost as large as the figure itself. I'd think scouting a location with a SUPER high ceiling then putting a strong light as HIGH overhead as you can and bouncing it off the back wall would get you a better effect than mounting the light anywhere in the shower itself. And with a setup like that - the fixture would be WAY out of any water stream. Just off the top of my head. YMMV. |
This is the kind of stuff that scares the crap out me. Sorry, don't mean this directed at you personally. |
Do you really think it's okay to have a dancer dancing next to a C-stand holding an Arri Fresnel inside a shower? It's going to take more than sandbags and baby yoke adapters or whatever you use to attach a fresnel to a grip head to make this "fine." |
I like Bill's idea. Why place the light anywhere near the shower. Why not use a reflector and place the light a safe distance away? Doesn't have to be up high. Can be off to the side or down low. Pretty easy to control the spill with flags. Who cares if a reflector board gets wet!
Having said that, if the shower enclosure is fogged up, does the water actually need to be running for this particular shot? Perhaps you could spray a fogged up type effect onto the glass, or perhaps tape frost lighting gel onto the inside. |
Or could you use a polti type steam cleaner to add condensation to just the shower partition?
If you use the lights anywhere near the shower please be sure to use a ground fault interrupter (GFI) to protect your crew and talent.
Can't you use a battery powered light? Like one or two 100-200W halogen lamps with battery belts
I'm no electrician, but I would feel a lot safer in the shower with a battery powered lamp than with one connected to the 110V wall socket... |
Well the shoot is done,
The shower was very big I was using an ARRI rental, so my comment about staying cheap was just that I didn't want to rent some kinda fancy "made for water light" My gaffer (who I spent good money on) knew just what to do. :) We put the light high in the shower on a c stand boom and since the shower was large the dancers were not close to it all Everything worked out. |
Nice to hear and THANKS for the update ;).
Caleb
Glad to hear it worked out. With all respect to you and your gaffer I still do have to say that having worked as a lighting technician for 20 years on Canada's "wet" coast, you should have used a gfi (aka gfci). For future reference you can buy a plug and play 15 amp gfi at any decent hardware store. Light stands, c stands in particular can fail or get knocked over. Just saying this for future reference for you or others. It may be interest to understand how a gfi works. It measures the difference in amperage between the hot and neutral of a circuit which should be the same. Any difference indicates some current is grounding off which in a wet environment could be through the water. The gfi has a threshold of .025 amps which is the minimum needed for electrocution. |
| All times are GMT -6. The time now is 12:57 AM. |
