-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   Britek Softbox - POS? (https://www.dvinfo.net/forum/photon-management/62526-britek-softbox-pos.html)
Travis Cossel March 10th, 2006 01:25 AM
Okay, I just got my brand new Britek lighting system in today, and so far it all looks pretty good.
However, the softbox that comes with the kit won't keep it's form. There is no built-in tension in the supports of any kind, so when you place the softbox on the light, the top struts just fall down OR the bottom struts just slip out of their fittings OR BOTH HAPPENS.
I'm getting pretty frustrated. Anyone who has a Britek softbox have any tips or workarounds for this problem?
Neil Camero March 10th, 2006 02:01 AM
it's good that you brought this up because i have the same exact problem. followed the directions but just can't figure it out.
Rick Jones March 10th, 2006 09:03 AM
The way my softboxes from Britek mount are similar to other softboxes I've used in the past, execpt the hole that you put the supports moves instead of being in a fixed location.
This is how mine works...
The ring has 4 mounting posts that have a slip joint. This slip joint allow you to move the position of the mounting post. You pull the slip joint of the mounting post and position it so all 4 post point straight up when the ring is on the ground. Now place the 4 wire supports. Now place the black portion of the softbox onto the supports. (There is a sleeve in each corner that the wire fits into) Now this is the tricky part, you now have to move each mounting post until it's pointing straight out horizontal with the ring. The slip joint of the mounting post slips into the hole to keep it in place.
I'm gonna try and give you a mental example of what I'm explaining. Picture your hand. Now straighten your fingers. Now pull all your fingers until they're touching each other. This is what it looks like while you're mounting the softbox. Now spread your fingers out. This is the position the mounts should be in when you spread them out. This keeps the tension on the box.
Now you mount the white face on the softbox.
It's a little tricky at first and takes some practice to get the best feel for how best to move the posts while holding the softbox in place but once you figure it out, it goes fairly quickly.
Good Luck!
Rick
K. Forman March 10th, 2006 09:41 AM
So Rick... you are saying that the soft box isn't a POS, just confusing and difficult?
Meryem Ersoz March 10th, 2006 09:55 AM
i have one of these, and they're actually quite good, just confusing and difficult (where's my winkie smilie emoticon????).
if i remember correctly, i had to do a web search on assembling the softbox, and there were some good instructions put together by an equally frustrated group of people. was it over on dvxuser, perhaps? i don't remember precisely, but the info is available online to help you get it together. i'm thinking dvxuser, but do your own web search, and you should cough it up. if i can assemble this, anyone can, because i'm an idiot at the mechanics of things (which is why it would be useless for me to attempt an explanation myself). but someone, somewhere has done it. the directions they supply are terrible. do the web search.
these work great once you get them assembled. i keep one of mine fully assembled at all times so that i can refer to it whenever i have to reassemble one.
Rick Jones March 10th, 2006 10:06 AM
I would consider myself very mechanical and it still took me a few minutes to figure it out. The directions didn't help. But once you get it figured out, it works well. You just have to manhandle it a bit. Don't worry too much about breaking the supports, they're made to bend. The slip joint is the hardest thing to get into place.
All my other softboxes for my flash heads have to be sort of strong-armed into place. Just the nature of the beast I guess.
Rick
Aaron Ferguson March 10th, 2006 11:13 AM
Just wait until you have to take it apart for transport! That is even tougher (in my opinion).
Rick Jones March 10th, 2006 12:12 PM
I find that to take it apart, if you push a corner down, hold the support wire down with one hand and slip the softbox off the support wire, then it comes apart easier. It's much harder trying to get the slip-joints out while they're under pressure.
Rick
Travis Cossel March 10th, 2006 12:28 PM
Just got a reply from Tom at Rostronics (where I ordered the lights). The mistake I was making was that you have to move the support holders back into their original positions (into the original slots). I wasn't doing this because I didn't want to break anything.
I haven't had a chance to try it yet, but I'll bet it works.
Travis Cossel March 10th, 2006 04:29 PM
Okay, finally got a chance to try out Tom's advice. It works. Once you have the softbox assembled, you have to pull the supports back into their original slots. The support wires will bend, but that's okay.
I found it easiest to work on one support, then move to the opposite support. Trying to do 2 at the same time didn't work very well. Hope that helps!
Jason Varner March 11th, 2006 01:51 AM
Do it on the floor.
Trying to manhadle one of these things on the stands will bring a tear to your eye. The first 3 are pretty easy but the 4th is a real ball buster and it's way too much leverage for a lightweight lightstand.
Travis Cossel March 11th, 2006 05:23 PM
I just got done shooting with the kit today, and it all went pretty well. No complaints on the lighting.
My only complaint would be that afterwards, I found it impossible to take the softbox apart. The tension in the rods and the angle of the supports is pretty incredible. I'm just going to leave it together I think, even if it is a pain to store and transport that way.
Jean-Philippe Archibald March 11th, 2006 08:08 PM
You have to put the softbox on the floor, sitting on the ring. Then, you have to push on two opposites support wires at the same time. This way you will be able to change the position of one holder, releasing the pressure on all the wires.
This is pretty easy to do after you acheive it one time... I now have some Chimera softboxes and the way to assemble an disassemble them is almost identical. You will get it!
Travis Cossel March 11th, 2006 08:16 PM
Maybe I'll try it again then. Must be like assembling one. It's a pain, but once you do it, it's easier to do it again.
Ben Freedman March 11th, 2006 08:46 PM
Ya. I have some of these and some Lowel Rifa boxes too...
The Rifa's go up and down in about 30 seconds with no bending or hassle at all. But, they are WAY more expensive.... Get what you pay for, I guess...
So, I leave my cheapies set up in the studio all the time, and the Lowells are packed up ready for travel.
Best,
- Ben
Mark Burlingame March 23rd, 2006 11:31 AM
I have the 500W britek kit and bought an extra softbox so I have 2. Initially they are difficult but now that I have put them up and down quite a few times it's really not that difficult or time consuming. They just take some practice and willingness to try a few different ways to assemble them. Here is my trick to taking them appart. first take off the diffuser and place the hood on the floor face down (mounting ring up) then push down on the ring next to one of the slip joints just enough to take the tension off the slip joint then slide it out. the rest come pretty easy after that.
Considering the price I think they are really great. Also, I have only one slightly bent support rod, the rest aren't bent at all, although I don't think it really matters. Mark
Ash Greyson March 23rd, 2006 01:49 PM
I agree, the first several times it was a TAD difficult but I can get them up/down in under a minute now. The Arri softboxes I have are just as hard. Lowel are the best but, as mentioned, are much more costly.
ash =o)
