-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   Free Demonstration of 3...no 4 point lighting (https://www.dvinfo.net/forum/photon-management/74698-free-demonstration-3-no-4-point-lighting.html)
Guy Cochran September 1st, 2006 06:35 PM
You've probably seen the diagram of where to place light fixtures for three point lighting. How about seeing how it works in a 5 minute Flash Video?
Check out basic three point lighting with the Lowel DVcreator Kit 1.
- 750W Lowel Tota with Umbrella for the Key
- Bounce Reflector for Fill
- 125W Lowel Pro light for the Backlight
There's also a 4th light in the kit which can be used to light the background.
Check out the video here - http://dvgeartalk.com/
Of course you can use any lighting fixture instead of the Lowel lights, so the video should give you a general idea of where to place each of your lights to get this look. For example, a China Ball could be used with a Photoflood bulb for the key, a sheet of foam core for the fill, a halogen desk lamp for the backlight, and a Home Depot worklight for the background. The Lowel Kit is just cool because it all folds up into a small case for travel.
