-   Photon Management (https://www.dvinfo.net/forum/photon-management/)
-   -   Interviewing chairs (https://www.dvinfo.net/forum/photon-management/89115-interviewing-chairs.html)
Greg Quinn March 16th, 2007 03:32 PM
Interviewing chairs
Sorry if this has been covered before, but is there a particular kind of chair that's favored for interviewees? I've just bought in a couple of Director's chairs for this purpose.
John DeLuca March 16th, 2007 03:42 PM
It really depends on a lot of things. Generally I prefer a professional posing stool used for still photography. See link below. A directors chair should work fine for most apps though.
http://www.owens-originals.com/Brand...g%20stool.html
Gints Klimanis March 16th, 2007 04:00 PM
Thanks for the posing stool link. Which doi you use ? I'm concerned about creaking from heavier models, such as 260-300 lbs.
Also, is it better to avoid the foot rest to reduce foot fiddling choices ?
John DeLuca March 16th, 2007 04:17 PM
Hmm, I see your point with heavier models. The 'heavy duty photogenic' model without the foot rest is probably the strongest. The ones I have are actually very old (from the 80's), but very strong. Never had a problem with creaking, but I would call the company just incase.
Greg Quinn March 16th, 2007 05:27 PM
The company that sold me the director's chairs said they've tested them to 800 pounds stress. I would have though having a back to the seat would be good since it helps the stabilize the interviewee's location, no?
Gints Klimanis March 16th, 2007 05:42 PM
You're right about stabilizing the interviewer's position. I'm also interested in a backless chair to remove the distraction of the chair backing in upper body shots.
John DeLuca March 16th, 2007 05:58 PM
I agree, a stool will isolate the subject better during an interview.
Also, a chair or stool creaking under weight is different than completely failing. It’s important to note that anyone in the 250-300 pound range could vary well creak most stools or chairs. Maybe you could just instruct the talent to stay as still as possible during the interview.
Kevin Randolph March 16th, 2007 06:56 PM
Wd-40?
WD-40? I thought that was what you used to eliminate creaking...
Graham Risdon March 17th, 2007 01:13 AM
For what it's worth, (and it may seem obvious) but avoid swivel chairs!! Office have loads of them and most people are comfortable in them, but don't realise how much they move about - the camera of course does!!!
Sorry if this is a bit obvious!!
Nino Giannotti March 17th, 2007 06:16 AM
The simplest of the solutions is usually the best. You can’t beat a folding chair from Walmart, even the best one will only cost you less than 30 bucks, the back of these chairs is narrow enough that will be hidden by the subject. Director chairs are good and comfortable but the fabric seat and back is not rigid enough and most of the times the subject will sink or slouch down. They are very good in situation where you have more than one person on camera in a talk-show style conversation where the viewer’s attention is not concentrated on one single person.
A proper chair will dictate the body upper posture and make a world of difference particularly on challenging subjects.
For Several reasons I would strongly discourage the use of photographic stools for video interviews. Those are good for photography where you take individual poses and you need something that moves quickly and without much effort. Interviews take long continuous time, you need the subject to be comfortable and not to move even slightly, particularly if you are on a tight shot. A back support will hold the subject in place, also without a back support the subject after a few minutes will become uncomfortable and start slouching.
Nino
www.EFPlighting.com
