I hope I'm not stating the obvious but your mattes will lift a lot easier if you pull your screen tight before you start shooting. Spring clips and some sand bags will be much cheaper than the post time.
Gabriel
Thanks for the links. Do you have a link to your video? Jason |
It was once up, but then I lost my host for the file. So no, sorry!
I should have another one come the end of april though. Your welcome! I hope you can make some use of them! Can't wait to see what you end up with... Also, what 3D tool are you going to use? Have you put thought into that yet? ~Gabriel |
Gabriel,
Im trying to figure out how to use 3DS max and some models from scifi3d.theforce.net. Most of the 3d work with be done in AE. Looking forward to seeing yours. later Jason |
| All times are GMT -6. The time now is 06:05 AM. |
