-   Remote Lens Controllers (https://www.dvinfo.net/forum/remote-lens-controllers/)
-   -   501, 503 and Varizoom? (https://www.dvinfo.net/forum/remote-lens-controllers/1251-501-503-varizoom.html)
Nathan Gifford March 12th, 2002 09:00 PM
Hello to ya'll,
I am trying to figure out my next addition to my XL-1. Many of you really like the 503 video head from Bogen. I am wondering if the 503 is that much better than the 501? If I go 501 I could probably get on of those Stealth Varizoom controllers.
What does the group think?
Nathan Gifford
B. Moore March 12th, 2002 09:54 PM
Hi
I use the 501 with the bogen compact leveling head
(BG3502) on a bogen tripod 3221. as a combo they work well
Vic Owen March 12th, 2002 11:37 PM
I haven't used the 501 (I think that Chris has), but I'm using the 503 and it works well. Some don't like the counter-spring, but it has caused me no grief. I typically use the XL-1 with a Varizoom type LCD monitor on the XL-1.
Chris Hurd March 13th, 2002 01:10 AM
I had a 501, didn't like it, and changed up to a 503. Almost identical in appearance but quite different in handling. I'd still much rather have a Miller if I could afford it. There are several threads about this; do a search for "tripod"
My favorite VariZoom is the new version of the PG-L. www.varizoom.com
Nathan Gifford March 13th, 2002 09:29 AM
Thanks all
Glad all of you weighed in. Tickfaw is a tough place to find video heads. What surprises me even more is that the camera stores in New Orleans, do not stock either the 501 or 503 heads. Heck they DO stock the XL-1S and 3X lens: you'd think they would have at least a 501 to try out!
I guess I will make a decision today some time. If anyone else has comments send them along.
I hope Pro-Tape comes through on the 501 or 503...
Nathan Gifford
Nathan Gifford March 16th, 2002 02:39 PM
Bought 503.
After much soul search or rather sole searching...I decided on the 503. Since I will be heading to Houston probably in April, I hope to try out a varizoom while I am there.
Thanks to all,
Nathan Gifford
Chris Hurd March 16th, 2002 09:12 PM
You'll be happy with the 503. I consider it a big improvement over the 501.
Nathan Gifford March 17th, 2002 09:34 AM
I don't know about the 501 but its got to better than the 3130!
Nathan Gifford
Nathan Gifford March 19th, 2002 10:37 PM
503 with Bogen 3502 nice combo.
Wel Chris, et al,
The 503 (Bogen 3460) arrived today. It is nice head and a real improvement over the 3130. When you add the Manfrotto 438 (Bogen 3502) compact ball leveler it is a great combo.
The ball leveler works even better with 503. The 503 has bullseye level, which is in the correct position after mounting on leveler.
If you don't have both, I recommend getting them.
Nathan Gifford
P.S. Chris if you promote the 503, you really ought to add the 438.
Chris Hurd March 19th, 2002 10:51 PM
438 - thanks for the tip Nathan, I'll be sure to get one.
