Attach an ENG focus controller to a FF rig?
I'm researching the feasibility of a rig that would allow both cinematic documentary work and events coverage. Naturally, focus is ever more important, and then this idea hit me:
Consider a flex focus controller like the Canon FFC-15, FFC-200, FC-40. They're affordable, great for tripod work, and transfer the rotational motion not unlike a whip*. Now consider just about any follow focus unit with a whip socket. Can you marry the two? Sure the connections are not compatible, but it should be a simple mechanical solution. We may not even need additional gears. Has it been done before? Are there any available solutions to make it happen? (* If you're not familiar with the flex controllers, here's a closeup of the cable terminals: http://www.salesbaron.net/f/ABD011.jpg ) |
Drew are you thinking of keeping the FF on and being able to plug in a focus cable to where the whip or speed crank goes? I should work but I don't know how compatible all the gearing is.
Varizoom also makes something similar that could be used. http://www.bhphotovideo.com/c/product/234477-REG/VariZoom_VZ_FCF22_VZFCF22_Rear_Focus_Control.html -Garrett |
The Varizoom unit you mentioned is simply their own flex focus controller, comparable to the Canon/Fujinon/JVC units. |
| All times are GMT -6. The time now is 06:32 PM. |
