anyone has tried this (cheap) neck brace for EX1/Z1?
eBay.ie: DV NECK BRACE CAMERA SUPPORT Sony Z1 EX1 EX3/Canon/JVC (item 350370947689 end time 27-Dec-10 14:10:51 GMT)
extremely cheap but I wonder 1) is it reliable? 2) is it comfortable? doesn't look like 3) will it stay still? gives the impression a heavy camcorder like the EX1r could end up wobbling left and right like crazy but if it really works it would be a bargain!!! |
It's a neck strap that supports a short monopod....
Will fatigue the neck, you'll get breath motions unless you are a shaman/swami, and it won't relly "hold" the camera, just take some weight off your hand, which will still have to keep the camera in position... You'd be better off with a monopod with one end stuck in your pants pocket or a purpose made belt holder. Not much more $, but solves at least two of the above problems. I have a couple cheap ultra compact monopods I use that way with smaller cameras and larger ones as well... fairly effective, and once again... CHEAP! |
| All times are GMT -6. The time now is 01:32 AM. |
