Hmmmmm - maybe I dramatised a little ... What the heck - I knew what I meant! Maybe I don't expect to be taken too seriously?
Dear Michael, Rick, Steven, Charles, Mikko: Thank you so much for your passionate opinions and views. I guess we must all agree to disagree for the sake of free expression and unrestricted/uncensored flow of helpful knowledge and information. All your opinions are most welcome because it contributes to me making a decision whether to buy the Fig Rig or not. I really appreciate your inputs as it helps me avoid making unnecessary or costly purchases. Sometimes you could "afford" trial and error and you just "charge" it to experience but as much as possible, I would rather experiment with not so expensive gears and stuff. Again, thank you guys! Hope to hear from you when I need a review of another item, as we like to call it: FORUM SHOPPING. :-)
Sincerely, Jong |
I use a Fig Rig and a GL2 frequently for following conversations and really like it -- sure it gets heavy, but you can get in so much closer and really move around and be a part of what is going on, esp. with the shotgun mounted right to it. Most of the other handheld stabilizers I've seen seem kinda clumsy for that type of work.
I got the fact that the fig rig is like an apple and the other rigs are oranges, they are different, got it. What else in the same price range would work for running and gunning? |
how do you have any control over your cam if both of your hands are being used?? how would you pull focus?
Fig Rig I like it :) very much :)
I have used it with my HVR Z1 for some commercial TV spots one has been transfered to film and the others were for broadcast television (a furniture store)
All shots are kind of "reality" run & gun shots with lots of movements and I loved it and my customer also likedthe shots we got. We did very interesting and unsual steady shots and it is fun to work with, and a good piece of converstaion also (The customer didnt wnt to pay for the stedycam and after using the Fig Rig he was pleased with the results and the savings) I used it first without the controller and it was a little weird but then I bought the the Bogen 521PRO Zoom and focus controller and it really helps to use the FIG RIG Now I use it almost daily Here are some pics of the last production http://www.video.com.mx/precios/cineminutos.htm Ing. José María Noriega Director video@video.com.mx www.video.com.mx |
Fig Rig
Here's what I have to say about it. This unit is definately better than handheld if you are moving around. I am an owner and I can say that it does what it is supposed to. Is it as good as a steadicam device for walking shots? The answer is no. However, it is the best device I have found for non-steadicam shots. I am a run-and-gun videographer and I do not need a steadicam vest and support arm in my way. First, you must learn how to move with it. Elbows horizonal will produce the smoothest shots. You also must learn how to walk smoothly. Your arms will absorb a lot of the shock, but will not totally eliminate it. Practice makes perfect! I cannot stress this enough, practice, practice, practice! I am a wedding videographer and the Fig Rig fits a role that no other device will. For the ceremony, I use a custom made shouder mount with a waist support. During the reception, I turn to the Fig Rig. It allows me to move freely with a considerable amount of stability. If you are wanting to use the Fig Rig for weddings, and you need mobility and steadiness, the Fig Rig can't be beat. For an amateur film-maker on a budget, the same applies. Some may agree, and some may not, but I don't care if it looks like a steering wheel, the customer will appreciate the finished project when I am done with their video. I can't tell you how difficult it was for me to spend $300 for a piece of aluminum tubing shaped into a wheel. I removed this item from my shopping cart at least 3 times from BHPhotovideo.com before i actually broke down and bought it. I am glad I did. Hope this helps!
Thanks for those thoughts, Grady - they're more or less my feelings about the rig as well.
Robin |
Well my plan is to buy one in a couple of months to use at weddings. I have a lot of faith in my plan to use it to get those run and gun shoots such as the bride and groom walking to the car etc. My plan is to have all my tripods have the same plate so I can go from the fig rig to the pod and back and forth. There is that 30 seconds or so that I have been missing between the end of the ceremony and the bride and groom in the hallway etc. Although I will soon have two main cameras, so that shouldn't be a problem. But I do want the ability to pull off the tripod and onto the fig rig.
If that doesn't work I will install it in my Xterra. :} |
However, my curent setup is a DVRig Pro setup with VX2100, mic, PAG Light C6, LANC Remote, wireless, PAG battery on back of rig, with tripod mount. My question is, that I see how you mount accessories to the Fig Rig and mount it on a tripod. But how heavy would it get on your arms loaded up with wireless, light, shotgun mic, LANC, and what do you do with your PAG light battery pack (sling it over your shoulder)? It is good that you can have a variety of freedom and positions for moving shots, but with my DVRig, I can shoot all day pretty much fatigue free. I picture this doing a number on my shoulders and arms by the end of a long 6-8 hour shoot. So with this being said, would a Fig Rig be condusive to someone who shoots live events, like weddings, recitals and such, where a shoot could be as long as 6-10 hours? I figure that I could use the Fig Rig when needed and mount back on a tripod for lockdown shots and release again when needed. Mainly I wanted to find out how physically demanding on your upper body, would something like this be. Tthis from someone who has upper shoulder, neck pain. |
One question... Would you consider using the FigRig for Ceremony processionals and then just mount it to a preplaced sationary tripod for lockdown shooting? And after a long wedding reception shoot, are you fatiged? Currently I use a DvRig Pro in this manner for both the ceremony and reception, and it has served me well, pretty much fatigue free. But the Fig Rig would give me more mobility for moving shots than my DvRig, but fatigue worries me, as I have slight issues with my upper shouder-neck area. |
Do you have a picture of this? |
| All times are GMT -6. The time now is 12:34 AM. |
