How about budget SI-X mini ? at DVinfo.net
Go Back   DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
2/3" 1080p IT-integrated 10-bit digital cinema w/direct-to-disk recording.
Old August 25th, 2007, 03:34 AM   #1
Why not release mini SI (camera head only) based on good 1/2,7"-1/3" cmos image sensor ?
We can see now how good image from Canon HV20 1/2,7" sensor.
In most cases HV20 with 35mm adapter and HDMI output to CineformHD is very comparable to SI2K samples :)
P.S.What business is better : sell 10pcs of SI2K at $12K or 1000pcs (1/3") at $2K ? ;)
Serge Victorovich is offline   Reply With Quote
Old August 25th, 2007, 09:04 PM   #2
Personally I'd think a version with a larger (35mm) sensor would be more interesting. Sensor size or more to the point photosite area, is the most significant parameter affecting image quality. Also using a smaller imager is not going to significantly impact manufacturing costs. The costs of machining lens mounts isn't going to change and the price point that you're talking about is what a lens mount alone costs.
Old August 26th, 2007, 03:20 AM   #3
Bob, i agree with you about 1" sensor.
But in 35mm digital pro area more cams and strong competition:
Panavision, Arri, RED, NoX...
SI need to make full range of camera head: 1/3", 1/2", 2/3", 1"
Time to have products similar to oldstyle 8mm, 16mm, 35mm, 70mm :)
Instead of film celluloid we have now the digital negative -CineformRAW.
About price and quality...Bob, look at samples from Elphel camera.
Only drawback of this fpga camera is compression.
With CineformRAW this modular tapeless camera can kill those hdv/avchd camcorders ;)
Old December 5th, 2007, 09:29 AM   #4
I'd love to see a 1/2" (or maybe APS-C sized -- 24mm x 15mm) SI mini with an HDMI port that could be used with the proposed Cineform CF flash recorder. Bring it in around $5K?
http://www.prolefeedstudios.com/blog/
Documentary for the masses!
Brian Standing is offline   Reply With Quote
Old December 5th, 2007, 04:04 PM   #5
It sounds attractive however the MINI head doesn't do the de-bayering or much in the way of image processing. It feeds out RAW data to the recording device. About as close to a digital negative as it gets.
Converting that digital negative into something that could be encoded into mpeg-2 would destroy all the advantages of recording RAW and require some serious processing. That processing needs a lot of power to be done in real time. That power means heat and big batteries. This seems to be the stumbling block at the moment for the industry as a whole. Advances in silicon might change this in the medium term.
Old December 5th, 2007, 05:01 PM   #6
I thought the SI recorded to Cineform codec, not RAW. Am I confused?
Old December 5th, 2007, 05:46 PM   #7
you are right and wrong. SI records to Cineform RAW.
Noah Yuan-Vogel is offline   Reply With Quote
Old December 5th, 2007, 10:16 PM   #8
Ahhhh... now I get it. Thanks for the clarification.
Old December 6th, 2007, 07:35 AM   #9
Hi Everyone,
Good thread . . . yes, the "big deal" is that the Mini doesn't have on-board recording and it doesn't have on-board control surfaces either. There's a couple TTL inputs, etc., but that's not enought to give you comprehensive control over the camera like we give you inside of SiliconDVR.
While theoretically a pre-debayered HDMI port version could be constructed with a FPGA implementation, but it would 1) not be RAW, 2) probably not support the "fancy" stuff like 3D LUT's, etc. without a bigger FPGA, and 3) the CineForm device would not give you any control over the camera as it's only a recorder, so there would have to be a control surface of some type.
Adding "intelligence" to the camera head in the form of another FPGA, with then the associated graphic overlays or feedback screen, or something of that ilk starts getting things a bit more complex. I know technically it would be doable, but not for $5K, at least not the way things stand right now, especially with the physical construction of the camera head (it's machined, not cast, so per-device prices are not cheap).
Jason
Jason Rodriguez is offline   Reply With Quote
Old December 7th, 2007, 04:39 AM   #10
Jason, do you know about Sumix camera head based on same altasens sensor as SI2K and coming soon Cineform SOLID DVR?
Both devices are anounced at price less than $2K each.
IMHO, same silicon of SOLID can be used to capture CineformRAW also. Shoot to digital negative (Cineform RAW) same way as film but with mp4 or mpeg2 low res proxys for preview. All LUT's in post...
Old December 7th, 2007, 08:03 AM   #11
I'm very aware of the Sumix camera. They do some very nice work and sell at a great price. I've also been participating in the CineForm thread on this site, so I'm aware of their developments as well.
Some notes I see from the current developments:
1) Sumix's camera is not using the same sensor as us at this point in time.
2) I don't see a HDMI output on the Sumix or a Gigabit port on the CineForm recorder, so there will have to be some device to mesh this disparate connection/protocol/signal mis-match.
3) The CineForm recorder does not actually control the Sumix camera head, so even if there was a way to record the RAW stream output to the CineForm SOLID, there is no way to actually send commands to the camera head to change settings such as shutter, frame-rate, resolution, etc. The Altasens sensors are quite configurable, and there would need to be some separate serial interface, or specific development on CineForm's part, to control the camera head. Since each camera head typically "talks" a different serial control language based on the way the serial interface is implemented, this would make the support for the Sumix head extremely targeted, and therefore volumes will be low compared to the generic SOLID that CineForm is working on right now. Either that, or someone will have to work on some type of break-out box or CCU-style unit that will take the gigabit input, output RAW over HDMI, and then offer a control interface for the Sumix itself. This new device won't be "cheap", especially if volumes are low. I would estimate another couple thousand. But now you have three pieces to the puzzle and a lot of cables, etc. In fact, I bet it would probably be cheaper for whoever would make this CCU to simply license the SOLID electronics from CineForm and then build a single box just for the Sumix.
The point I'm making is that for the quality people are wanting, at this point in time, a total cost of less than $5K for the camera and recorder is not feasible without compromises being made somewhere along the line either in the recording codec, the mechanical quality, or the comprehensive feature-set.
I think someday this sub $5K price point will be realistic, but not right now. Not when you have multiple devices involved. It will probably take an all-in-one device with higher volumes to get the price-point down that far.
Old December 7th, 2007, 11:39 AM   #12
I like to dream of super prosumer priced cameras, but lets get realistic.
A complete large sensor HD camera below about $10,000 is impossible for the units we are discussing here. And if you try to get this to $5,000 you can't afford to use CCD and the software and development will have to be free. It will not happen. I have spend quite a lot of time trying to find a way to make it possible at that cost and there is really no way today.
Even if it becomes possible in the future when every part (except ccd) will cost 1/2 as much, this will not happen for marketing reasons. In 5 years you will still have to spend $8,000-$10,000 to get highly compressed CMOS based camcorders with some manual control and the sensor sizes will be 1/4 or 1/3". Even now, large sensor CCD and 3x1/3" sensors is considered very professional. Who would put a superior system against those? A dreamer and a bad businessman I guess.
A $3,000 portable uncompressed HDMI (also capable of good lossy codecs at extra cost) HDD based deck will probably appear soon. But what are we going to use with that? 1/3" tiny pixel cmos or 3x960x540 1/6" or 1/5" ccd? These will gain practically nothing from the better recording quality. We are talking about $4,000 to $8,000 cameras for using this recorder and it will still be tiny 1/3" CCDs and small noisy 1/4" CMOS. The total cost will be $10,000.
What about workflow cost? Storage, capable HDD for multitrack, capable cpus, software, etc?
Anyone realistic with $30,000-35,000 in his pocket can go for an acquisition/editing package and actually get quality video.
I also don't understand the point of looking for something that does not exist and probably never will. There are many solutions on the market and some of the affordable ones produced ok results even for feature filmmaking. The camera is never the limit in creative uses of video.
John Papadopoulos is offline   Reply With Quote
Old December 7th, 2007, 02:46 PM   #13
Yes, but you can have the sumix mounted to a custom made box with a computer inside and record the same quality of footage as the SI2K. This was actually how the SI2K started and what it actually is in it's core. A camera strapped to a computer. Will it be the same in terms of usability as the SI2K+DVR? No. But it will cost less than a 1/5 and get you the "same" quality of image, resolution and post flexibility.
Michael Maier is offline   Reply With Quote
Old December 7th, 2007, 03:57 PM   #14
Getting from the point of writing images, to a dependable video camera with controls that make sense and behave properly, is a very long journey. You can get software that writes video to a capable storage subsystem at very low cost and camera heads are from $1000 to $10000 depending on sensor size and technology and most come with recording software and SDK. The debayer will usually be a joke, it might have serious implementaation issues (bugs) or be unusable in real time preview. Sometimes the debayer will loose half of the sensor resolution vertically and horizontally, the frame rate will be innacurate and practically anything except what you had in mind, you will have no audio and it will not be portable or battery powered or anything resembling a camera in actual use. There are lots of engineering issues and these have to be solved by someone. The same applies to GUI, software, codecs etc. You can easily spend 1/3 and get nowhere and 1/2 and get close with numerous usability issues after hundreds of hours of testing, ordering components and development. Time is not free. Development cost of a working camera with off the shelf components can be 100,000s of USD in engineering time. The markup in thse devices represents exactly that, engineering time and the assurance that it will do the job. Most people will not pay 1/3 for something that will not do the job, because that 1/3 is money down the drain. That's what we call turnkey. Engineers can always build something to do the job, but no sane man can normally justify the cost for building only a couple of cameras, even if he/she has the engineering capacity.
Old December 7th, 2007, 04:21 PM   #15
Hi Bob,
Size is generally not connected directly to performance. The majority of development money from sensor manufacturers goes to small and medium sized sensors. This has a nice result, 1/3" interlaced sensors are leaping in performance once in a couple of years, but larger sensors show little progress. The 2/3" sensor could have 60 ot 70% of quantum efficiency and the larger sensor will have 20% on 25% in some series. This could easily be 2 or 3 stops of difference in the blue color of a bayer sensor. Larger pixels are usually more noisy. The only advantage you will positively have is shallow DOF capability with a disadvantage in low light when you need the DOF to get the shot. And that's if you can afford lenses with the same relative apperture with the ones you are using in the small sensor.
Even if the large sensor comes with identical resolution and you increase size in both directions by 2x, same as going from 1/3" to 2/3", the theoretical advantage is only 6dbs of signal/noise performance and it is usually reduced by the smaller quantum efficiency of the large sensor and the availability of lenses with large apertures. You can get f1.0 lenses for up to 1", but above than you have to use very expensive lenses with much smaller relative apertures. The large sensors have advantages in light gathering but they also have a lot more dark noise so they need the light to saturate and get a good signal per noise performance. And if you are stuck with f2.0 lenses on the large format, a pixel that is 1/4 the area on a sensor with identical resolution using f1.0 has identical light gathering and shallow DOF capability.
Once you go over 1/2", the difference in the performance of larger sensors is not that impressive.
  You are here: DV Info Net > High Definition Video Acquisition > HD and UHD ( 2K+ ) Digital Cinema > Silicon Imaging SI-2K
