-   Sony 4K Ultra HD Handhelds (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/)
-   -   X70 FW Update (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/525766-x70-fw-update.html)
Tim Akin November 16th, 2014 05:31 PM
X70 FW Update
Just noticed there's a new firmware version 1.02 on Sony support but haven't been able to find anything out about it. Anyone know anything about what this might be?
I downloaded it and looked at the PDF file but it's just instructions on how to install the update, not what it fixes.
Tim Akin November 16th, 2014 05:44 PM
Re: X70 FW Update
Found this VERSION 1.02 SOFTWARE USER UPDATE FOR THE PXW-X70 RELEASED - Tech Talk
Doesn't say much except it fixes the L&R channel swap and improves some other functions.
Wonder what "other functions" is.
Darren Levine November 17th, 2014 08:16 AM
Re: X70 FW Update
would be funny/demented if the update included grayed out 4k modes
sorry ;)
Ron Evans November 17th, 2014 08:19 AM
Re: X70 FW Update
Interesting as when the PXW-Z100 and FDR-AX1 came out they had the L/R audio channels reversed too !!! Some common firmware ?
Ron Evans
Paul Anderegg November 17th, 2014 09:28 PM
Re: X70 FW Update
Don't forget to save your camera profile settings to an SD card before doing the f/w update, because it will "blank" the camera to factory.
Paul
Tim Akin November 18th, 2014 06:02 AM
Re: X70 FW Update
Good info Paul, I'm still trying to figure out what else the update does before loading it.
Christopher Young November 22nd, 2014 07:36 AM
Re: X70 FW Update
it applies to cameras with v1.01 or earlier. The release states:
"VERSION 1.02 SOFTWARE USER UPDATE FOR THE PXW-X70 RELEASED
Sony has recently become aware that when recording in XAVC mode on the PXW-X70, the Left and Right audio channels are recorded swapped around.
Sony is offering a system software user update (Ver. 1.02) for this camcorder which corrects this phenomenon and improves other functions."
I've done the update and it does in fact correct the swapped audio track issue but as far as the 'other functions' comment well I have observed no changes in any other areas of the camera's functioning. Who knows I guess!
Chris Young
CYV Productions
Sydney
Ron Evans November 22nd, 2014 07:48 AM
Re: X70 FW Update
Chris the FDR-AX1 updated that fixed the left and right audio channel issue also changed the HDMI output to HDMI 2.0 to allow 50/60P output to TV's with HDMI 2.0 rather than just Sony 4K TV's. They may not say they have done this since the X70 does not yet have 4K !!!
Ron Evans
Christopher Young November 23rd, 2014 05:25 AM
Re: X70 FW Update
I read somewhere during my research and made a mental note of the fact that the X70 was already 3G SDI and HDM I v2.0 compliant but I'm blowed if I can recall where I read that. No doubt we will find out in the fullness of time.
The UHD 4k upgrade only played a small part in my decision to get one and that was from a personal curiosity point of view. No client of mine has ever hinted at 4K and I won't be offering UHD / 4k unless I see myself losing business because I'm not offering it.
I can see some good uses in house for 4k like re-framing etc but for me UHD doesn't fit any business plan for the next year or so at least. What appealed to me was the fact that here was a little unobtrusive camera that produced pretty decent HD footage and above all was very easy to work with in tricky locations. In general I can get certain shots with it that are all but impossible with the full size XDCam kit.
I am curious about the noise issues some posters have mentioned though. As yet I haven't come across any of the issues mentioned but then again I haven't been looking for them. The conference I shot last week was recorded with a line level feed into Ch #2 with Ch #1 to top mic and it's as sweet as could be, beautifully clean. Will have to investigate further though to see if there are any gremlins in the system.
Chris Young
CYV Productions
Sydney
Ron Evans November 23rd, 2014 07:43 AM
Re: X70 FW Update
I can induce noise on my NX5U, NX30U or FDR-AX1 by having a mic with 48volt on channel 1 and nothing on channel 2 but with this set to mic 48v and auto gain . With channel 2 set to line there is no noise especially if there is a line level input with manual gain as most of the time that is how they are set up. All the manuals say that if there is no mic inputs to set inputs to line level.
Ron Evans
Paul Anderegg November 23rd, 2014 01:55 PM
Re: X70 FW Update
At least 4K XAVC S will ingest into FCP X. :-)
Paul
Ron Evans November 23rd, 2014 07:29 PM
Re: X70 FW Update
Paul
That is true but for the X70 they may make the file format XAVC-L for 4K, 420 8 bit MXF just like the PXW-Z100 latest firmware release V3.0 just to make a difference to the AX100.
Ron Evans
Mike Griffiths November 24th, 2014 08:45 PM
Re: X70 FW Update
Tried to upgrade many times ( I'm in version 1.0) and I keep getting 'failed because of error in the process'
Tried all combinations, cards in, cards out, you name it. I've come from Panasonic where firmware upgrades work seamlessly. I've not been impressed so far with Sony's approach to software (the x70 is great!)
Does anyone have an idea what I should do now?
Paul Anderegg November 24th, 2014 08:57 PM
Re: X70 FW Update
First make sure your f/w file is proper for the region your specific model is designed for. Next, save your current camera profile to an SD card. Then reset the camera back to factory stock, and attempt the f/w upgrade again. Perhaps a current setting is interfering with the process, but just to be safe, you will have all your settings backed up to SD card if the reset/update fails again.
Good luck!
Paul
Mike Griffiths November 24th, 2014 09:13 PM
Re: X70 FW Update
Thanks Paul, but still no luck, I'll just have to live with it until another (? better?) firmware update arrives
Dave Blackhurst November 25th, 2014 04:58 AM
Re: X70 FW Update
Never had a problem with a Sony FW update... smooth and easy every time... Alphas, Cybershots, Handycams...never a problem if I followed the directions , which sometimes have some quirky steps. I find I leave the directions up after downloading the updates so I can go down the list of steps, and I'm a "who needs stinkin' directions" kinda guy!
Maybe a bad cable or connection? I seem to recall Sony strongly suggested using the USB cable included with the camera, and I know I've got so many USB cables running around I don't know what came with what! And there are USB cables that will "fit" at the ends, but are wired differently...
Just a thought, could be completely wrong, but thought I'd mention it.
Ron Evans November 25th, 2014 06:30 AM
Re: X70 FW Update
Another other need is to connect to mains power for upgrading most of the Sony camcorders and they can tell whether power is mains or battery. At least my NX5U and FDR-AX1need to be on mains powerto updte nd they can tell if it is not.
Ron Evans
Christopher Young November 25th, 2014 07:54 AM
Re: X70 FW Update
I had a similar experience on one Windoze box but it had a utility called 'USB Safely Remove' in place of the normal Windows safely remove icon. No way would this PC upgrade the X70. Moved to a another Win 7 box that was running the normal Win USB safely remove icon and hey presto it upgraded without an issue. Go figure!
Chris Young
CYV Productions
Sydney
Mike Griffiths November 26th, 2014 12:00 AM
Re: X70 FW Update
Thanks, I made sure I used the cable supplied with the camera. Have downloaded 4 versions including one from Singapore ( i live inThailand). not sure what Paul meant when he said ' make sure the version is for your region'
Mike Griffiths November 26th, 2014 12:19 AM
Re: X70 FW Update
Ron Evans
Tried that too, still no luck I'm on an iMac, I'll try on my wife's Win7 to see if that works
Mike Griffiths November 26th, 2014 01:58 AM
Re: X70 FW Update
Chris Young
CYV Productions
Sydney
Wow! plugged in my wife's sony Vaio win 7 and bingo first time!!! There seems to be a problem with the Mac version, don't know if anyone else had the same problem. I confirm using cables other than the supplied Sony one is not a good idea!
Christopher Young November 26th, 2014 06:44 AM
Re: X70 FW Update
Glad you got it sorted Mike.
Chris Young
CYV Productions
Sydney
Ray Paula November 27th, 2014 01:51 PM
Re: X70 FW Update
Just purchased the PXW-X70........How do you do the update? Anyone have instructions. Thanks, Ray
Mark Watson November 27th, 2014 03:38 PM
Re: X70 FW Update
1 Attachment(s)
It's all in the download.
https://www.servicesplus.sel.sony.co...eDownload.aspx
Ray Paula November 27th, 2014 05:24 PM
Re: X70 FW Update
Awesome....... Thanks for the links! Exactly what I needed.....Thanks again, Ray
