Re: New X70 samples
BTW, did you come across this post. http://www.dvinfo.net/forum/sony-pxw...-froze-up.html |
Re: New X70 samples
Re: New X70 samples
Yes, I hope so too.
Re: New X70 samples
Edgar, really great video, just how it should be taken like looking out through a window. Have a look at Amazing planet on you tube for a similar technique. Slow pans, straight cuts and virtually no zooming.
Are you planning to go 4K when available? Andy |
Re: New X70 samples
Edgar Vs |
Re: New X70 samples
Here is another video sample of Sony PXW-X70.
Shooting manually. Colors are edited in Sony Vegas. |
Re: New X70 samples
Re: New X70 samples
Thanks Ray - I think I started with PP5, but frankly these settings change so many things that IMO it doesn't really matter what you start with.
I still use those settings but have made a few changes. I don't set the Knee quite so low. Instead of 75% Point I use about 85. And, Saturation and Sharpness are pretty flexible, depending on how much of that you want to do in post. I have since learned that Crispening really controls the point where sharpness of small details kicks in, so higher Crispening actually softens fine details. Since I am going for more in-camera sharpness I now use Level +3 but Crispening at 0. I find this does not add artifacts or look over sharpened, although this is of course personal. |
Re: New X70 samples
Thanks David.....
As for the PP, I can clearly see your point due to lots of changes. I will give the changes you mentioned a try. Thanks again for posting and testing different scenarios of the PP's of the X70. You're a great asset to this forum. Ray |
| All times are GMT -6. The time now is 01:13 PM. |
