4K upgrade license received
But, holy moly do they make it difficult!
I created an account with eCsite and now just waitin for my password. For those that have received their license, how long does this usually take? |
Re: 4K upgrade license received
Dave
What URL did you use to find the registration page?? Everytime I go to the eCSite link I get a page that has no option to sign up & register (U/N, P/W, etc.) This is astonishingly lame Thanks |
This is the link from the instructions
https://www.ecspert.sony.biz/ecsite/...ulationsDirect Just agree to the terms then create your username. Once you're done, it will say they will email a password. Why do they make this so difficult? |
That worked great
All my prior attempts resulted in error messages- maybe the site was down earlier Many thanks |
I got my PW in about 5 minutes. But yes, they're not exactly showing their best high-tech face.
I finally got mine. I went through the whole process and the key doesn't work :/
Only thing I can suggest is make sure you put in the device ID correctly.
You can check this -- open the key file in a text editor (it's a text file, despite not being called .txt) and you'll see the ID in the first two fields (with a comma between the parts). Compare this with the device ID from the camera's "Options" menu. If the numbers don't EXACTLY match, that's the problem. (Don't go by the printed serial # on the bottom, because it could just possibly be wrong.) |
Nope. The file goes into the top-level folder of the SD card, and should be exactly as downloaded -- the name should be like
CBKZ-X70FXINSTALLKEY_20150707111234567 with no extension. Then put the SD card in the "A" slot of the camera, and you should be able to load it in the "Options" menu. If it doesn't work... call Sony, I guess, because I'm out of ideas. I suppose you could try a different SD card. Sorry mate, I would love to help.... |
Are you "double positive " that you had it in the A slot? Mine didn't work until I put the disk in the A slot. Then it gave me the option to install the update. This is the most bizarre update process that I have ever seen---waiting months and then days to pass around 30 byte data files...! It is staggering!
I haven't tried actually importing XAVC-QHD yet...to busy from an existing job. But I did get the install to work, and I verified that my camera can select and (apparently) record a 4K file. |
Wow just brought the footage into final cut. Wow! I know it's relatively low bit rate but it looks incredible.
Dave- what is the phone # that got you in touch with the right people at Sony?? |
Never mind...
I reregistered using a different username and email address and got a password in 30 minutes. All of the rest of it was smooth. Many thanks to Atticus Lake for his install video. Amazing experience :-/ Now we'll see how long it takes to get the check for the $300 rebate |
| All times are GMT -6. The time now is 01:30 PM. |
