-   Sony 4K Ultra HD Handhelds (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/)
-   -   Z90 or Z150 (https://www.dvinfo.net/forum/sony-4k-ultra-hd-handhelds/534733-z90-z150.html)
Doug Carter September 29th, 2017 01:02 PM
Z90 or Z150
I was on the verge of ordering a Z150 to replace my X70 when the Z90 was announced; now I'm a bit torn...
Does the Z150 have any functional advantage over the Z90 or are they two identical cameras in different packages?
I do often wish for more dedicated controls that the X70 (or Z90) sports but unless there are feature or performance advantages, I'm not sure the Z150 is worth the extra weight to me. Mostly, I'm hoping for improved dynamic range.
Craig Seeman September 30th, 2017 08:43 AM
Re: Z90 or Z150
It seems the key big differences are much better and more flexible Auto Focus in Z90 and the ability to shoot above 120fps slow mo (at reduced resolution). The Z90 also will hav S-Log.
Paul Anderegg October 1st, 2017 09:51 PM
Re: Z90 or Z150
If you are used to shooting on a DSLR, the select the Z90...if you want such pleasures as a freaking iris ring, choose the Z150. :-)
Paul
Doug Jensen October 4th, 2017 08:40 PM
Re: Z90 or Z150
Originally Posted by Craig Seeman (Post 1936926)
. . . and the ability to shoot above 120fps slow mo (at reduced resolution).
I don't even have to see sample footage above 120 fps to know it is going to look like garbage.
Paul Anderegg October 4th, 2017 08:54 PM
Re: Z90 or Z150
192x108p 960fps video shot at 1/1000 sec shutter and 24db in the daylight could look good, you can't say for sure. :-)
Paul
Donald McPherson October 4th, 2017 11:53 PM
Re: Z90 or Z150
"Ouch" Is that because of shutter speed?
Paul Anderegg October 4th, 2017 11:55 PM
Re: Z90 or Z150
Typically as frame rates go up, resolution goes down...not resolvable details, but the actual 1920x1080 will become 1280x720, then 640x360, then 320x180 and so on.
Paul
Doug Jensen October 5th, 2017 04:40 AM
Re: Z90 or Z150
Shutter speed wouldn't have anything to do with image quality. As Paul said, the resolution goes down and compression goes up making a lethal combination if you care about picture quality. My judgement is based on similar Sony cameras that offer those high frame rates. Up to 120 fps I'll bet it looks great, but I doubt anything over that is going to be good enough for professional work. 120 fps is pretty good anyway and works great for most sports, wildlife, etc. You really have to have a subject moving pretty fast to need better than 120.
Donald McPherson October 5th, 2017 05:36 AM
Re: Z90 or Z150
I was thinking the higher the frame rate the higher the shutter. Meaning higher light required.
Doug Jensen October 5th, 2017 06:06 AM
Re: Z90 or Z150
But that concern would be the same for all cameras. Faster frame rates = faster shutter speeds = more light needed. But that alone won't affect image quality.
I don't know yet how good the Z90 is in low-light, but I'm certain it will be good enough to handle the needs of high frame rates. It's the compression and reduced resolution that are the killers.
Rob Cantwell October 5th, 2017 09:40 AM
Re: Z90 or Z150
At one point had looked at the FS5 but costing almost €5000 was beyond my budget, was considering the Z150 which is a good bit cheaper at €3300, then along came the Z90 which is just €50 dearer than the Z150.
Leaning towards the Z150, auto focus just isn't a selling point for me, got stung too many times with AF. Can't see myself using 120 fps very often and I presume you have to dig through the menu to get to it for me at least it's unusable.
The new Canons look interesting! maybe wait til next year to see have the prices come down to an acceptable level. Then I have all Sonys how to match them?
Decisions decisions!
Donald McPherson October 5th, 2017 11:33 AM
Re: Z90 or Z150
Do a Youtube google of Doug Jensen. He has a few videos up using the Z150 and also a great video tutorial explaining all you need to know about the X150.
Craig Seeman October 5th, 2017 02:00 PM
Re: Z90 or Z150
If you mean the X405 as far as I can tell it's still 8 bit 4:2:0 in HD whereas the Z90 or Z150 are 10 bit 4:2:2. In day to day use that's far more important to me than high frame rates especially if I have to any post processing (color grading, etc.) The X405 does have 4k (UHD) at 60fps but I'm not sure how important that is though.
Craig Seeman October 5th, 2017 02:04 PM
Re: Z90 or Z150
My guess is that Sony may handle the high frame rates the same way they do in the RX100 V.
If they kept 240+ at its native pixel size rather than fitting into 1920x1080, they might be useful as "insets" or, in the case of 240 for example, software good at scaling in post. Even that won't be as good as "native."
As to the buttons I'd expect that S&Q modes can be assigned to a button. We'll know as more reviews come out of course.
Doug Carter October 29th, 2017 12:38 PM
Re: Z90 or Z150
Aside from the lower resolution viewfinder, does the Z150 have recent enough hardware to keep up with the Z90? I.e. is the DSP and sensor the same or a generation older in the Z150?
Cliff Totten October 29th, 2017 08:39 PM
Re: Z90 or Z150
So it's absolutely no secret at all to "Sony watchers" that the Z150 is the next camera to be updated with the Z90's sensor, processing and 99% of it's firmware code. This all hit the RX10-IV a month ago then got ported over to the Z90 and of course the Z150 sucessor...may be a "Z170"?
So what will this "Z170" probably have? Of course, all of the guts and gammas of the Z90 but with a three ring lens. (all fly by wire)
But hold on,....You guys all know that the Z150 has fan cooling vents today. How about this,..."could" the "Z170" be given 60p 4k? It has an active cooling body, something no other 1 inch-type Sony camera has ever needed before. Hmmmm.
I would like to see Sony build off this Z90 sensor and processing combo with a "real" mechanical lens like a Fujinon EX1 lens with real gears and stops. If they can swing a constant f2.8, that would be fantastic. If they gave it 10bit recording that would make it a damn good ENG camera at $6,000 or so.
I'm pretty sure Sony would not be able to build them fast enough if they offered that for $6k.
CT
Doug Carter October 30th, 2017 04:46 PM
Re: Z90 or Z150
I think it was about two years from the X70 to Z150 announcement. Holding out for a "Z170" may not be the best solution for me. Hopefully, the Z150 image processor is new enough to support most, if not all of the Z90 purported firmware enhancements.
Cliff Totten October 30th, 2017 07:55 PM
Re: Z90 or Z150
I strongly suspect the Z150 successor will come at NAB 2018. They already have the vast majority of the work completed with the RX10-IV and Z90. It's just swapping out the motherboard and porting over the existing Z90 firmware programming.
Now, if they want to add 60p 4k and maybe 10bit, then yeah, that could require more work for Sony.
I suspect they will keep the current Z150 in place for a while after this "Z170" is announced.
The problem Sony has right now is the price relationship between the Z90 and more expensive Z150 is completely upside down! The Z150 has all the new phase detection circuits and SLOG-2/3 and touch screen....yet is significantly cheaper that the Z150. The only thing the Z150 has to fall back on is that it's larger has has 3 "fly by wire" lens rings and that is really not enough to justify it's higher price over the more feature packed Z90.
Sony,...at least give the Z150 SLOG! I mean,....damn,...how many Sony products UNDER the Z150 have SLOG?....NINE? Nine cheaper Sony cameras have SLOG below the Z150? NINE cheaper models??? NINE?????
CT
