Is the Sony Z280 good value in 2020
Looking at a second cam for my Sony Z90 and I keep coming back to the Z280.
Plan is the Z90 becomes the BCam and the Z280 takes over the main shooting roles, mainly outdoors in the Aussie Bush, sunsets, morning low light stuff, chasing cars etc... My Z90 is usable at 6-9db gain and it's a 1inch sensory, I'm wondering how the Z280 performs in low light. Doug I hope you are around to offer advice? I'm looking for feed back from users on the camera both good and bad. I need 4:2:2: 10bit Thanks in advance. |
Re: Is the Sony Z280 good value in 2020
The Z280 is still a great camcorder and I'm not aware of anything else that even comes to matching its performance. I use mine all the time and I'm always impressed by the results. I describe it as being an FS7mark2 with smaller sensors and a 17x f/1.9 lens.
It's one of the top three cameras I've ever used for low light. You'll love the variable electronic ND. AF face detect is almost flawless. The viewfinder rs beautiful and makes focising a breeze. I wish Sony wouldrelease a shoulder-mount version (like the EX3 was to the EX1). I would probably choose that version instead, but I don't see that on the horizon. In the meantime the Z280 gets 10 starts out of 10. I've sold enough stock footage from my Z280 to have paid for the camera. The only thing it is not good at is shallow depth of field. |
Thanks Doug,
It's a toss up between two cameras at the moment, the Z280 and the Sony FS5 MK II, Both different tools however priced almost the same. |
I forgot to ask Doug, what's the HD like on the Z280? the little Z90 I use in HD is great.
Cheers, S |
The Z280 looks great in both 4K and and HD. It's 10-bit 4:2:2 in both so everything about them is virtually the same except for resolution. But the Z280 is a full-stop better in low-light when shooting HD vs. 4K with all other settings being equal.
THe FS5 isn't anywhere near in the same league as the Z280. Not even close. If you want a comparable camera you have to look at the FS7. |
Thanks Doug,
Interesting info on the FS5 vs Z280. Yes the FS7 would be ideal however just out of budget on this one. |
A gently used FS7 is a far superior camera than a brand new FS5, and I hear the FS7's are going cheap these days. I'd like to sell mine because I'm not using it much anymore but I don't think I'd get enough for it. It is a buyer's market.
Yes a used cam might be an option and I have been searching however most have many hours and have seen a lot of work along with holding a heavy price.
What's the down fall of the FS5 M2? |
If I tried to make a list of all the FS5's shortcomings, I wouldn't even know where to stop.
There's no Cine EI shooting mode No LUTs No timecode in or out connectors No genlock No picture cache No shot duration counter No full-size "4K DCI" formats 4K UHD is limited to a maximum of 30 frames per second 4K is only 8-bit Slow-motion over 60 fps can only be recorded in short bursts There are no XAVC-I codecs There are no XDCAM or MPEG HD422 codecs You can't insert ShotMarks or Clip Flags Theres only one SDI output connector You can't use the SDI and HDMI outputs simultaneously It only has two channels of audio You cant control how audio is mixed in your headphones Theres no eyepiece or loupe for the LCD Monitor There's no way to setup custom clip naming Clip names cannot be displayed in the viewfinder You can't build your own custom User Menu You can't import custom User Gammas There's no way to export or import individual Picture Profiles Theres no way to use v-lock batteries There are far fewer menus for customizing the performance of the auto-exposure and auto-white balance modes There's no AUTO FOCUS ASSIST mode for overriding auto-focus on-the-fly No Auto-Focus confirmation indicator in the viewfinder No shockless Gain or shockless White Balance No dedicated buttons for switching Zebra or Peaking on or off Peaking is colored instead of the better edge-enhance type There's no waveform monitor It has far fewer options for Markers and no User Box marker No Clear-Scan shutter mode No special memory card slot for storing and moving user-generated data files in & out of the camera No external playback buttons on the body None of the Cinegammas provide 800% dynamic range like Hypergammas 7 & 8 on the FS7 And finally, the FS5 has far fewer paint menus for customizing the "look" of the camera's picture -- and the menus that it does have are completely different than the FS7 |
Right, that's one list of shortcomings.
Thanks for the advice. Cheers, S |
Piggy-backing onto Simon's question, if that is OK:
Is there any basis for hoping for a follow-on to the Z90? I've been holding off on getting a second one in the hopes of something in the same, compact form factor, but with updated specs such as 4k 60p (or better). |
Yes bill I was hoping for a version Z90M2 this year, if I don't go with the Z280 or do I dare say the FS5 (client wants this) I'll grab another Z90 so my other shooter can grab those shots where I'm able to.
Perhaps better would be a Z90 firmware upgrade like the X70 4K upgrade. I'd gladly pay for higher 4K frame rates.
That would be nice Bill. I love my little Z90, man has it shot some gigs over the last 12th months along with my A73, RX10v4, there's a lot I would like in a firmware update on the Z90 and a basic one would be a level, I emailed Sony....lol never heard back.
Sony PLEASE put a level in the Z90, just saying. Cheers, S |
these days I see second hand Z280's. Owning a panasonic DVX200 with a 4/3 inch sensor I don't know if the Z280 would be upgrade for me.
The DVX200 is already from 2015. I want better low light, better viewfinder and better autofocus. The 17x zoom from the Z280 is also better than the 13x from the dvx200. any thoughts? |
I'm a huge fan of the Z280 and love mine, but having never touched a DVX200 I cannot tell you how they compare. I have my suspicions, but they are not based on experience, so I will keep them to myself. But with said, there are no rivals in 2021 that can touch the Z280 so I'd be shocked if a DVX200 that was created in 2015 could hold a a candle.
thx Doug! I tested again my DVX200 in 4K 50P against my old sony FS100 with the 18-200mm F3.5-6.3 lens. I can't see the difference in image qualty between both on 55inch 4K tv.
The DVX200 was 4K downscaled to 1080p. In low light they perform equal in my tests. The FS100 with this slow lens was about equal to the older EX1 (could by PMW200 also) in low light I read somewhere in a old topic. So based on that and my experience with testing I think the PXW-Z280 is about equal in low light as my DVX200. |
Sorry Tom, your logic escapes me. How can you possibly compare the DVX200 to a Z280 if you don't have a Z280? How does the FS100 (very old camera) and a crappy18-200mm lens fit into the equation? What does the Z280 have to do with a FS100? Do you think because they both have a Sony badge on them that somehow they have something in common? They couldn't be more different. And the lens on the Z280 is f/1.9 through the whole zoom range. I don't get what you are trying to say. |
sorry Doug, I based my conclusion on this I found in old topics here:
In low light I've found the PMW200 fairly close to the FS's 18-200, but not as good if you are using faster lenses. I shot a wedding last weekend and used Alister Chapman's ASIA PP on the PMW200 and PP5 on the FS100 and they looked close enough for me. my conclusion: the Z280 has the same 3x 1/2inch sensors like the PMW200. I don't know off course how Z280 compares to the PMW200 in HD mode. The crappy 18-200 lens for me is decent but off course I have never filmed with a PMW200 or Z280. I apologize in advance for this |
Tom, no problem. I just thought you needed a dose of reality! The PMW-200 is a nine year old HD-only camera. It was a slight upgrade from the original EX1 -- that is now a 14 year old camera. Not only does the PMW-200 not have the same 4K sensors as the Z280, it doesn't have any of the modern electronics and processing power of the Z280. And as I said, the Z280 has absolutely zero in common with the FS100 except for the brand name. If you want to know how the Z280 compares to another camera you're going to have to use a Z280 for the testing.
I've owned an EX1, PMW-200, FS100, and still own a Z280, and I can tell you that the Z280 unlike any of them. Send me your DVX200 with a return shipping label and I'll do a comparison for you. :-) |
| All times are GMT -6. The time now is 12:25 PM. |
