-   Sony ENG / EFP Shoulder Mounts (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/)
-   -   Sony PMW-320K/L (https://www.dvinfo.net/forum/sony-eng-efp-shoulder-mounts/476564-sony-pmw-320k-l.html)
Alister Chapman April 13th, 2010 04:53 AM
Just a correction about the sensor. It is the EX3 sensor.
There was a little bit of confusion as some of the spec sheets give the impression that the 320 is more sensitive, but that is due to the faster lens, not a sensor upgrade.
Tim Polster April 13th, 2010 08:42 AM
If it is the EX3 sensor, that makes it a bit tougher sell for Sony.
The EX3's price is at $8,300 so the 320 basically being the same camera means from a consumer's mind its price should not be far away from the EX3. Especially with the same sensor in the $6,000 EX-1.
Also, Panasonic is jumping up and down how the new HPX-370 outperforms the other guy's 1/2" chip model. New sensors with a bit of a boost would have silenced that standoff.
It would seem there would be no improvement in the skew behavior given the same sensors, but that is still possible. Overall, it looks like price is going to be quite important for this camera.
Heath McKnight April 13th, 2010 03:17 PM
I never thought I'd see Sony do a 2/3" HD camera with interchangeable lenses under $60,000! This is terrific news. Hot dog, indeed! And that includes the PMW-350.
Heath
Andrew Stone April 13th, 2010 06:18 PM
At this point bringing 50 mBit down into the prosumer mainstream would gut Sony's pro line sales. They are already pushing the envelope as is evidenced by the comments on this forum.
I am wondering if this time period will mark the true beginning of the commoditization of pro video gear. It is conceivable now that what we consider all the qualities of "broadcast quality" video will be available for $15,000 within a year or so. That being: 10 bit, 4:2:2, +50 mBit, full HD raster imager, 2/3" imager. All possible at the present rate of feature creep. +120 frames overcrank and ramping slowmo are things that are probably off in the distance.
Just musing.
Tom Roper April 14th, 2010 12:18 PM
When you get into the shoulder mount class, the costs start adding up quickly, batteries, chargers, viewfinders, lenses, nanoflash, and you give up a few things as well, like image stabilization. Just my opinion but I don't see the point, if not to go the full step to 2/3 inch. You could buy an EX3 and EX1R for about the price of adding an image stabilizer alone to a shoulder cam, which is probably only available to 2/3 inch models anyway.
For me, I would pass on the HPX370 and the PMW-320. To be fair, neither was around when I bought the PMW-350, but it was all about the 2/3 inch format for me. The kit lens on the PMW-350 is pretty useless when zoomed from the shoulder to more than 50%, needs a sturdy tripod.
Steve Phillipps April 14th, 2010 01:03 PM
Ramping has been around for ages, in the original Varicam and now in the current ones. And before that, of course, in film cameras like Arriflex and Aaton.
Steve
Frank Casanova April 14th, 2010 11:49 PM
You're right..just checked it out at NAB...The 320 is listed at $14,800. It is the PMW-350 with half inch chips instead of the 350's 2/3 inch chips at over $18K. These cameras are aimed primarily at news operations which want the heavy shoulder mounted camera that you can literally throw around. They both have slots for SxS cards AND SDHC cards. However, it is more than twice the price of an EX1...so that means your EX1 is still the best bang for the buck by far.
Ahmad Husni April 21st, 2010 02:30 PM
Hi all, this is my first post.
I'm excited about this as well, especially the XDCA-55 & XDCU-50 option. Brochure stated that you can control this camera from 100m distance, which is the max length. But as they using multicore 26-pin cable for power, two pair of BNC cables for the signal and return video, a booster will help you solve to extend the range and I guess the multicore cable could extend way more. But, when Sony option to put in the multicore cable here instead of triax, it would be expensive to spend on the longer cable unless you go for a used one. Spending so much just to power up for camcorder?... huhu...
Comparing head-to-head with HXC-100 triax system, I just hope the new PMW-350 + CCU setup will not cost as much. If it's much cheaper, the PMW-350 setup have a recording advantage over the HXC-100 but with less operation distance. Imagine if Sony can do this setup with triax... yeahh.. they can do it, they just don't want to.
Link to the brochure is here :
https://pro.sony.com/bbsccms/assets/...a_cu_v2461.pdf
Daniel Melius September 9th, 2011 04:31 AM
Re: Sony PMW-320K/L
I have 2 EX1R's and the 320K with lens is not over twice the price of the EX1R. I got my EX1R's on bhphoto for 6300 in 2010. The PMW-320K is listed on bhphoto and everywhere else for 11900 with lens. On the other hand for a mere 7000 dollars more you could go with the PMW-350 for 18900 with lens with the only difference being the 2/3 sensors. To me its all about having one good shoulder mount camera with all the proffesional controls on the outside of the camera and can't afford to pay 19000 on one camera. So its 5600 more than the the Sony EX1R with only similarity being the 1/2 inch sensors or 7000 more with only difference being the sensors. The min illumination rating for EX1R is listed at .14. For the 320K it is listed as .05 lux so that would seem to be a tremendous advantage in low lighting situations. The 350K beats them both with .006 lux but to expensive of a camera for me. I would say the 320k lux rating is closer to the 350 than the EX1R is to the 320K. I already got a great deal of money tied up in sound devices 788T and 6 schoeps microphones along with wireless to consider the PMW-350. After all I've got to match up b camera footage from my two EX1R's to the 320K.
For a special event and wedding free lancer like myself the 320k camera is all the camera I will need to impress clients and future clients just by the outward looks of it as it compares to the EX1R cameras. Even if it films the same exact way as the EX1R, I want the controls and impressivness of one good shoulder mount camera and the 320k fits the bill without having to fork out 7000 dollars more for the 350.. I also need at least one camera to time code sync to my 788T as the EX1Rs have no way of doing this by themselves.
Ron Fabienke September 10th, 2011 11:38 PM
Re: Sony PMW-320K/L
deleted..... question in wrong section.... sorry
