convert MTS to mpeg 2
i have a sony HD camcorder and i'm trying to edit videos but i need to convert my mts file to mpwg2 so it doesn't lag and i also lost the converting cs given by sony. do u know any site where i can download a converter.thanks
Google "remuxts" .... top link will be a Japanese site,but if you scroll down you'll see a green link in English to the remuxts zip file.
This is a tiny, free program that losslessly remuxes transport streams to mpeg2 program streams - very fast. |
Might look here: mts converter - mts file converter, mts conversion
or just google "mts file converter," there are a bunch of listings / Battle Vaughan/miamiherald.com video team |
$39 though (versus free)
Download PavTube MTS Converter and test it.Its demo version converted the whole file, not just the first 2 minutes. Time and Functions without limited. |
converter vs proxy
You may want to instead consider a proxy, such as Gearshift (if it still exists) on vasst.com. This way you edit with the lightweight proxy, but render at full resolution.
Cineform also should be considered as an alternate codec. Again the aim is to ensure excellent quality. Otherwise, if your output is not HD, perhaps you should consider setting your camcorder to record in standard def and bypass the extra steps. |
Ok, this is a dumb question I'm sure, but I have to ask...
Why do you have to convert the MTS files? I have .M2T files, should I be converting these instead of change the file extension? What am I missing? |
This works well for me.
NewBlue AVCHD Upshift | Batch convert your AVCHD files into standard .M2T files. |
| All times are GMT -6. The time now is 03:32 PM. |
