I am searching for a long Sony HVR-A1E footage, is there anyone avalible?
Hi!
There is alot of clips out there that barely begins before it is over so there is quite hard to get a satisfying impression of what the camera can perform. So is there anyone that have / know a site that have a longer footage, something like 5-10 minutes with a bitrate of about 20-30mbit/s? Would love to see one. Thanks |
Hello Jesper,
Perhaps the Sony HDV Shooters' Club will help: http://bssc.sel.sony.com/Broadcastan...rs/index.shtml Dorothy |
Manual Audio
I've been playing around with the manual audio functions on the A1 and noticed that I'm not able to set channel 1 to auto and channel 2 to manual. Is this correct? My Z1 is able to do this, but not the A1. Or am I doing something wrong? Can anyone shed some light on this?
HVR-A1U and Focus Enhancement FireStore FS-4 Portable DTE Recorder
I am curious if anyone out there is using the HVR-A1U with a Focus Enhancement FireStore FS-4 Portable DTE Recorder with their camcorder and if so, have you had any problems using the FS-4 and how do you like it? If you do have a FS-4, what kind of projects have you used it on and do you also record to tape simultaneously as well for back up purposes? Looking at going this route versus getting a VTR deck to cut down on wear and tear on the camcorder heads. Any information, pros or cons or opinions are welcomed.
Suggested settings: A1U Beach setting
I am going on vacation to Tahiti, and haven't had time to learn all the best settings for bright sandy beach scenes!
Any suggested settings I can print out and take with me? Thanks in advance. I have the Sony WA, circ.polarizer, haze filter, NTG-2. Tim |
HVR A1 - mic/camera noise
I bought a Sennheiser MKE 300 to use when I need to go lighter with the HVR A1 and don't need the XLR module. It works great UNTIL I mount it on the shoe on top of the camera. I found that there is a vibration/hum that the mic seems to pick up from the camera. When I remove the mic from the mount it records fine which suggests this is a physical vibration problem (rather than electrical). Has anyone else experienced this and any ideas on how to fix it??
I don't have this problem with the XLR module. Unfortunately I don't have another non- |
HVR A1 - mic-camera noise
[SORRY I HIT THE POST BUTTON BY ACCIDENT BEFORE FINISHING. HERE IS THE COMPLETE POST!]
I bought a Sennheiser MKE 300 to use when I need to go lighter with the HVR A1 and don't need the XLR module. It works great UNTIL I mount it on the shoe on top of the camera. I found that there is a vibration/hum that the mic seems to pick up from the camera. When I remove the mic from the mount it records fine which suggests this is a physical vibration problem (rather than electrical). Has anyone else experienced this and any ideas on how to fix it?? I don't have this problem with the XLR module. Unfortunately I don't have another non-XLR mountable mic so I can't double check this problem. However I tried the MKE 300 on my Sony PDX 10 and it works fine - i.e. no vibration/camera noise. Thanks for any ideas! |
A1 on a Glidecam 2000
Has anyone tried balancing the A1 on the Glidecam 2000? If so, any tips? Thanks,
Bill |
Interval Recording to Tape?
Does anyone know how to do Interval Recording (Time Lapse) to tape using the A1?
nightshots with my A1
Here are some clips I shot with my A1. I'm still trying to figure out how to get the "lines" out of the video. In this I deinterlaced the video and it's still there. Anywho, I tried shoting this with no gain, there is even a walkway that I shot with a shutter speed of 4. If you have any tips please share.
Thanks Shedrick http://www.yousendit.com/transfer.p...627968fd304c2b1 |
Link doesn't work.
A1 - Timecode issue
In the REC RUN (record run) time code mode the A1 continues with the same time code sequence each time you hit record, but starts over when you turn the camera off. On one tape the TC can start over at 0 a dozen times or more.
This makes it impossible to do batch captures in FCP. If you log in a particular start and stop TC for capture, that range can exist mutliple times on the tape and FCP will just grab the first one it finds. The free run option appears to run the TC whether or not you are recording, but that is not what we want either. Used a VX2000 previously which kept the same TC sequence for the entire tape. Am I missing something? Any got this to work? |
Lens hood for Sony Telephoto VCL-HG2037Y Lens
Hello!
From what I read, almost all the HC1/A1 owners buy the Sony Wide angle VCL-HG0737Y Lens and purchase the LH77 Cavision lens hood for it. Does anyone ever use a similar lens hood for a telephoto lens? is there any point in doing so? I'm considering getting a LH77 but obviously it wont work with my Tele VCL-HG2037Y Lens since the Tele lens is a few mm larger in diamter then the wide angle. I'm wondering if the Cavision LH80 would fit with this Telephoto lens, where I'll have to buy an step down adapter for the LH80when using it with my wide angle VCL-HG0737Y lens. Any comments about this setup? Or is anyone already using this? Thanks!! |
HVR-A1U in the DC area
Hello,
Does anybody know where I could see/try the A1U in the DC area? thanks Andrea |
Pls check this out..
I live in the DC area and bought an A1u 2 mos. ago . contact me off list with any questions. Camera was not available locally; I had to order from B&H in NYC sight unseen.
Great little camera. chris |
A1 XLR adapter
I got some stuff stolen out of my truck and my XLR adapter happens to be one of them. Does anyone know where I can purchase another one? Possible send me a link to go to?
Outside of contacting a Sony authorized repair house, I'm not sure that there is anywhere else to send you. This is not a part that you can buy separately via the retail channels, AFAIK.
Yep i'm pretty sure it's a "Sony purchase" only part.
Around USD280 if i recall correctly. |
workflow A1 - FCP - 24p
Newbie question... Can someone get me started on the work-flow for a documentary film, that on the high-end may be feature film worthy in the quality of the story at least...
Camera - HVR A1 NTSC 1080i60 Mac Pro with FCP 5.1 Suite From capture - what is the exact work flow... ie were do I ideally convert/pulldown 1080i60 to 24p and how? I'll likely be using Nattress. Thanks in advance. |
a little sample of a1u in low light(concert)
Hello
I just did a few films with the a1u and the supplied microphone,try the 3 films some crowd were added with imovie.All the videos were done with imovie hd. Its vry confortable to work with the touch screen for audio control when you are next to the stage.more movies will come next week. You can wath it on youtube.com and write(search for) actuvid Sorry I don't know how to make a link. |
Step-Up Clamp for A1U?
I found this kit at B&H that looked like a pretty good deal for the Sony HVR-A1U and some accessories. One of the accessories is a VCL-HG0737Y High-grade Wide Angle Conversion Lens. I also want to be able to use this with a ProPrompter which clamps on the lens. The thing is, the lens does not seem to have threads for a step up ring to accomodate the proPrompter.
My question is this: is there a clamp on step-up ring that would work with this, or would I be better off looking for a different lens? >> Camera Kit Here EDIT: >> Here is the lens mentioned above |
audio recording format problem
Hi
I am playing my xdcam into my a1 (using it as a deck for transfer on the go onto dvcam tape) but for some reason it always switches into 32khz mode when I am assured that the xdcam always records in 48khz. is there some setting i am missing? Phil |
HVR-A1U Macro Lenses
I just picked up a set of Raynox macro lenses for my HVR-A1U and have been playing around with them. The models are DCR-150, DCR-250, MSN-202, and MSN-505.
I know each one has a minimum focus distance (133mm, 90mm, 30mm, and 17mm respectively) where getting any closer to the object being filmed will prevent you from focusing properly. Is there any reason to not simply use the one with the smallest minimum focus distance (MSN-505) all the time? Does anyone have any suggestions for doing macro work using the A1U? |
HVR A 1 comparisons and user reviews
Hi there i am seriously considering purchasing the Sony HVR-A1P for the sort of work i do needs a smaller field mobile camera but in HDV.
I currently use my good old reliable Canon XL1 S but with the sort of work i do and kms i have to walk with the camera (dirt bike racing) around the bush or venue a much smaller or lighter camera in HDV is needed as i have found the XL1 by the end of the day too heavy filming off the shoulder. Can anyone give me their impressions of the HVR A 1 or whatever name it is given in overseas and especially how it films using both tripod and out in the field off the tripod. Also any other recommendations in the HDV range of cameras with the same mobility would also be appreciated. Also does the HVR A 1 allow for protective UV lens attachment as well as this is another necessary evil in my line of videoing with MX, Enduro etc. |
Nic, I too am looking at one of these cameras. I'm having one last look at everything next week at DMF before I buy the week after. From looking around these threads I have seend the camera with a UV filter on it so my guess would be yes.
I have decided to go with a Panasonic AGDVX100AE instead i think i have made a good choice here for what i need it for but thanks for the reply mate no worries.
Problems with FCP recognizing A1U
Hi Forum, thought I'd throw this out to you guys too:
I've got a Sony HVR-A1U, I've been messing with it, along with a "CitiDisk" HDR that works great. Been able to use FCP 5.1.2 DV-NTSC settings fine for capturing or tranferring .mov files in the HDV-DV mode. NOW, I just started playing with the FCP native HDV editing project, and shot a bunch of animals in HDV. I used easy set up for HDV, selected the Sony HDV firewire for input, and I get an error message that the camera is not recognized. So, I trashed prefs, checked capture settings ( HDV,etc.) reset the camera, tried new FW cables, checked the front FW port of my G5, No such luck. I INSURED the iLink conversion was OFF and that the VCR was on HDV or AUTO, nothing seems to work. Any advise here? Thanks Mark Westman |
Do you have a PCI Firewire card in the G5? Seriously, I had added a FW card and it prevented me form using HDV, but not DV. I don't know why, so I just removed the card and it worked.
Be sure to have the camera off when connecting to or disconnecting it from the computer. Also, you should have the camera ON and in VTR (or playback) mode before you start Final Cut, do the quick setup and I think it should work. Unfortunately, if Final Cut is running, you need to close it before you turn on the camera. |
Thanks Jeff....
I do not have a PCI firewire card, and I found out on the apple forum that it was a QT bug...which I fixed....and then did figure out that the system needs to be restarted before capturing.
Thanks! mark |
more problems with final cut 5.1 not recognize a1u
Obi wan kenobi you are my last hope,I read the other thread by Mark about connecting the a1u and the good procedure.I did it all and it still not working.
My firewire is connected and it goes in hdv in.I am working with macbook pro.thanks in advance |
A1U and VX2100 Batteries?
Just bought the A1U, yay! Are batteries on these two cameras interchangeable? I have several batteries for the VX and don't want to start over if I don't have to. Anyone know?
Sorry, the A1 uses the same batteries as the PDX-10 and TRV-950, which are smaller than the VX/PD series batteries. The batteries from your VX would fit an FX1, FX7, Z1 or V1 but not an A1...
Dang! Ok, thanks a bunch!
Intercutting Z1 and A1 tips please
I believe there are several Z1 owners who have acquired an A1 as second camera.
How are you going at making the footage look the same - any tips for camera set up on either? So far, my footage has looked "fairly" similar, but with a slightly different look, presumably caused by the CCD/CMOS difference. I wouls love to hear any ideas on making the footage as intercuttable as possible. |
can hvr-a1u export to tape from NLE?
i was wondering if this was capable in premiere pro 2.0 with the a1 and if it does does it only do 60i or can you export as 30p?
Yes, you can export to the A1u from Premiere Pro, but the A1U doesn't accept 30p, so no...you can't export 30p from PP to the A1. You can also export 24p from Premiere, but the camera won't accept 24p without pulldown. In other words, export settings must match the capabilities of the cam receiving the stream.
Need 35mm adapter for A1U
Can someone recommend a decent priced 35mm adapter for the A1U? I have about $200 to spend. If not in that price range, how about one for the VX2100?
downconverting from a1e
this one is quite frustrating. I previously had a sony fx1 and was pleased in any ways apart from portability. Therefore changed to sony a1e and to my big, big surprise there seems to severe problems in downconverting from hdv to dv. That is: i shoot in rec format 1080i (Shutterspeed set to 1/50 , using tripod) , use i-link (1394) and downconverting when exporting to premiere pro 1.5.
Even during the capture sequence (project settings PAL DV) I see interlacing lines and coarse pixelating in the monitor window. That is before further processing in PP. I have never seen any reports on this forum making this an issue previously and wonders why am I to have such a problem. Any suggestions ? |
Sony HVR A1
Thought I would put up three clips I took with my A1, they need to load, rendered in Vegas 7, flowers, hummingbird, and birdbath
http://www.hughmobley.com/Untitled-111.html http://www.hughmobley.com/Untitled-11.html http://www.hughmobley.com/Untitled-1.html |
| All times are GMT -6. The time now is 03:07 PM. |
