HC-1 AIS Shoe adapter
Hi Guys,
Much to my chagrin, I have discovered the HC-1 has that proprietary Sony Hot Shoe. Don't see many adapters out there except on a Euro Site. It was pretty cool; just fit into Sony hot shot with a standard cold shoe on top. Anybody know where I can get one of these? B&H has a handle with two cold shoes, which I bought for $9.95. But I really want to put a Rode Videomic on the camera itself. |
I have a custom made one based on a Kaiser cold shoe adapter. I think Adorama carries the Kaiser for around $20.
Tnx
Thanks Marc,
I am taking a look now. Best, Jack |
Shoes
Saw the kaiser hot shoe adapter; and reviews on the bogdan AIS adapter, but couldn't find a site for it.
jh |
links i found
i was researching this a while ago. i didn't try to build my own. here are some links i bookmarked though:
http://www.jcdv.com/shoeadapter.htm http://www.global-dvc.org/Sony%20HDV.htm |
tnx
Thanks, Fischer. Sites were very helpful.
Regards, Jack |
HC-1 Hot Shoe Adaptor
Hi,
I have a source in Southern California--took a V-shaped 2-headed cold shoe adaptor (a cold shoe on top of each leg of the "V" --one is an inch higher than the other).... ...and they custom-ground the base of this V adaptor to fit snugly into the Sony proprietary shoe....so you can now mount the Rode Video Mic on one shoe and say, an external light on the other....works fine. John Reilly jdreilly2@msn.com |
picture and price would be good.
Sony HC-I Proprietary Shoe Work-Around...
Gentlemen:
I apologize for the delay in getting back to you...(Mother's Day, etc.) Sorry, I don't have a handy picture of the bracket, but you can view it on the manufacturer's site: cool-lux.com It is the MD3000 light and sound bracket...solid, extruded aluminum, as I recall... color: black; weight: 1 lb. Listed at $30.00ea. Express Video Supply in Glendale, CA sells it for $34.95. So does Samy's. This is the bracket I had "modified" to fit into the Sony proprietary shoe: A video repair technician in Los Angeles charged me 2 hrs. labor @ $50.00 per hour to engineer, then grind the base of the above listed unit to fit my HC-1. I had no other viable options, so I found it to be worth it. Maybe you can source the same (or better) in your respective areas... Good luck, John Reilly |
I'm trying to mount an lcd monitor onto my hc1 (to flip the image from a 35mm adapter).
1) I don't know what monitor to get, but I'd like a small cheap one for under $100 if such a thing exists 2) is the hot shoe the best place to mount a monitor? 3) have solutions emerged for mounting monitors to the hot shoe? 4) i have a cavision rod support system. is that a better place to mount my unbought onboard monitor? |
| All times are GMT -6. The time now is 04:48 PM. |
