HC3 vs. HC1, which is better?
I want to buy a dv recently and I am hesitate between HC3 and HC1, so any advice is helpful! TIA.
The 'gaps' as I understand are: HC3: no ext. mic input, more 'consumer' orientated (less manual buttons, no zoom ring) BUT has a rather cool 3 second high speed capture which might be useful. HC1: external mic input, zoom ring, more 'fiddly' manual inputs. Overal for amatuer usage I would say the HC3 but if you are doing anything slightly more demanding the HC1. That's a 50,000foot view. I have the HC1 and it s a beautiful camera -for the time being... Nick. |
Hc1
I just sent an HC1 to Guatemala in the hands of researcher who had never picked up a camera before. She shot five hours; I am just starting to digitize, but the stuff looks very good.
It depends. You haven't given us enough information on your needs.
However, after demoing both units, my answer: HC1. It's the same chip and board as HC3, yet it has higher quality gear around it. You can tell the difference in fit, form and feel. The HC3 is wayyyy to light and hand motion will be more evident. The HC1 just feels more solid and confident. I like the focus/zoom ring. It's not pro, but it's feel is familiar as with pro cams, and much better than the HC3's fumbling little thumb-wheel. There is an iris rocker/switch. Although you won't know the F-stop, you can get by with using zebra in combination. You can get decent audio from a good quality mike for input. Even if it's unbalanced, a good external mike delivers much better quality than the built in unit. I actually purchased a somewhat used demo unit over a new HC3. It's that good. If you don't have a need for the above features, and just want to point and shoot family events. Then the HC3 will do. |
To summarize...
Get the HC1 if you want more manual controls. Get the HC3 if low-light performance is more important than controls. |
Get the HC3 if low-light performance is more important than controls....AND if you'll never want to use an external mic. Which is a BIG if, in my book.
HC1 in Guatemala 2
Looked at more of the Guatemala rushes. The video is very good, considering everything was shot on automatic. In addition the audio was pretty good, even when the interviewees were 6-feet or so from the camera. Not perfect studio quality audio, mind you, but if you are shooting Mayan ruins in the jungle, the sound is more than usable.
Jack, I've found the audio on the HC1 to be acceptable, I use wireless samsung UHF with audiovox lapel mikes. The set delivers a very clean signal. Any noise from the cam end of things can be gently filtered out in post. There are a few times where the audio warbles. (I'm not certain if it's an mpeg layer II issue).
The ambience in your jungle shoot may actually help with the mood and tone of the piece. I do allow a little background to remain, cutting out the entire floor, even if it doesn't cut into the voice, just doesn't sound natural. The more I use this cam, the more I'm willing to forgive it's shortcomings and finding it to be a very capable cam. |
It's not hard to imagine a Sony or 3rd party 1/8" adapter for the shoe (kit project anybody?), or a shoe wireless mic system (maybe even Bluetooth based) |
Go for the HC1, the external mic input is critical in most applications that go beyond home movies, on the other hand, yes, Sony has that accessory shoe for the HC3. Another consideration: if you care about A1 features that the HC1 does not have like: XLR audio inputs, Switchable manual/auto audio level limiter, assignable functions, peaking, quick-record from standby, timecode, and Black Stretch, then consider the HVR-A1. I've heard the HC1 is going away because it offers too much competition to the A1U, is this true?
I believe the HC1 was supposed to be a consumer model, point and shoot only. If you wanted Pro, you'd get the A1U.
Folks buying the HC1 for purely consumer use might have found it not so easy to use and a little bulky. I think the HC3 may have been a direct answer to consumer feedback. The bottom loading tape may have also been an issue, and requiring a complete redesign. Hence, the HC3. |
Well, audio controls falls under manual controls.
I don't know if I'd call the HC1 consumer. I believe it falls well within the prosumer category. It does give users a lot of manual controls (shutter speed, exposure, manual focus ring, white balance, etc.) that consumer models usually don't. In addition, the HC1's audio controls are quite advanced as well. |
Great Package
Hi Peter,
I totally agree with you. The camera is elegant in its simplicity. A pro or a novice can get good pictures. Very interesting about the sound. Are you running through a beachtek? JH |
The HC1 features manual audio levels and zebra stripes. Definitely designed for the more advanced videographer.
I HATE the proprietary shoe thing on the HC3. Otherwise its great for mom and pop to take to soccer games and get very nice HD footage. www.philipwilliams.com |
I'm using a samsung wireless UHF series ONE. The wireless receiver fits snuggly in the HC1's strap. See image link below (don't mind the 1/4 adaptor in the image, I couldn't find a short 1/8 straight cable): http://www.dvinfo.net/gallery/showimage.php?i=463&c=32 With that system I'm able to get enough seperation between noise(floor) and the speaker that I can run a filter in post. It's good enough. I also have an old Azden SGM-X shotgun which I'm currently testing. I've read that it sucks, but I'll test that and judge for myself. |
Good things come in small packages..
Very interesting rig, Peter. D U like the results?
JH |
I have the Sony 'zoom mike' that fits this specialty shoe and it's just barely OK in audio quality. I should really emphasize the 'barely' part of that comment. JohnG |
Jack, yes. The audio was acceptable. I have a small sound booth for VO, as the photo studio is right underneath a manufacturing room. In that room is a few vibrating/shaker parts feeders. These and their transformers present an ever present hum that feeds right into the audio. (Shoots that require live audio and speaking parts are done elsewhere).
However, I was able to filter out that noise in post as usual. The key is getting a quality mike. The samson UHF, when purchased new a few years back, ran about $600. It has noise cancelling circuitry. If the beachtek's deliver similiar quality, then it sounds like a deal. |
Fly it..
Peter,
I plan to mount the HC1 on a Merlin, and I want to keep it as light as possible. I am going to start with a Rode Videomic and see how it works. JH |
Sounds cool. I can't get over the weight of these things. I'm still thinking cheap miniDV, yet I'm getting 2x the quality.
I've carried mine rigged to a monopole for an entire day, without tiring out or getting sore shoulders. http://www.dvinfo.net/gallery/showimage.php?i=478&c=33 |
Peter - interesting rig. Could you expand a little about the handle arrangement pls? is the whole handle thing all part of the Varizoom lanc? or is that an accesory handle you've bolted onto the monopod and if so can you give the parts etc. appreciate it, cheers..
i have a sony zoom mic i bought ages ago (since superceded with others..) and only used it on 'gun' mode. Recommend most people do the same really as its too inconsistent sounding otherwise. |
Stu, It's a varizoom VG-PL. I bought that lanc control about three years ago. It also comes with hardware (the attached brackett) that allows it clamp (via thumb screws) onto bars of various shapes and sizes.
I purchased it with their original three-point shoulder rig, I think they still sell it, that also has an adobminal brace/pad. I needed it to carry the forward heavy XL1s (which is not a shoulder cam). It has focus and record buttons, a large zoom rocker, and finger tip wheel to control zoom speed. The all metal design and pistol grip style is very confident when holding the rig and helps keep it upright. Even holding it with one hand. |
It may be possible to modify / hack a Sony AIS mic to get the audio input you want, but to make such a device from scratch is prohibitively difficult because the pins are spaced very closely together, so one is best off making a modification. Global-dvc.org might be working on just such an adapter, according to the last time I talked to the site owner. |
In my new HDV Blog is a little hack for the ECM-HW1 BlueTooth mic..... and new comparison hdv-picture from Sony FX1 - HC1 - HC3
http://www.fxsupport.de |
Just a quick note...I tried out the HC3 recently and didn't notice much of a difference in terms of quality. The auto controls were a bit strange, but if you are in a 100% controlled situation, this can make for a great camera to do interviews, etc.
heath |
| All times are GMT -6. The time now is 05:41 AM. |
